[Liblas-commits] hg: 5 new changesets
liblas-commits at liblas.org
Mon Dec 20 22:58:50 EST 2010
changeset 1463eaa99e36 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1463eaa99e36
summary: use inequality test
changeset 0ef24cb72063 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0ef24cb72063
summary: remove liblas::detail::reader::Point... unnecessary and adds at least one extra copy of stuff
changeset dea3bfa6b160 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=dea3bfa6b160
summary: only ask for time and color if our schema says we have it
changeset 8918fb8d2a00 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=8918fb8d2a00
changeset 8a23d7247e87 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=8a23d7247e87
summary: collapse reading of actual point data into liblas::ReaderImpl, eliminating extra copying and setup
diffstat:
include/liblas/detail/reader/cachedreader.hpp | 1 -
include/liblas/detail/reader/point.hpp | 88 ------------------
include/liblas/detail/reader/reader.hpp | 9 +-
include/liblas/utility.hpp | 4 +
src/CMakeLists.txt | 1 -
src/detail/reader/cachedreader.cpp | 5 +-
src/detail/reader/point.cpp | 83 -----------------
src/detail/reader/reader.cpp | 48 ++++++----
src/utility.cpp | 121 +++++++++++++++++++------
9 files changed, 133 insertions(+), 227 deletions(-)
diffs (truncated from 600 to 300 lines):
diff -r da97381c72bd -r 8a23d7247e87 include/liblas/detail/reader/cachedreader.hpp
--- a/include/liblas/detail/reader/cachedreader.hpp Mon Dec 20 12:39:27 2010 -0600
+++ b/include/liblas/detail/reader/cachedreader.hpp Mon Dec 20 21:58:37 2010 -0600
@@ -43,7 +43,6 @@
#define LIBLAS_DETAIL_CACHEDREADERIMPL_HPP_INCLUDED
#include <liblas/detail/fwd.hpp>
-#include <liblas/detail/reader/point.hpp>
#include <liblas/detail/reader/header.hpp>
#include <liblas/liblas.hpp>
// boost
diff -r da97381c72bd -r 8a23d7247e87 include/liblas/detail/reader/point.hpp
--- a/include/liblas/detail/reader/point.hpp Mon Dec 20 12:39:27 2010 -0600
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,88 +0,0 @@
- * $Id$
- * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
- * Purpose: Point Reader implementation for C++ libLAS
- * Author: Howard Butler, hobu.inc at gmail.com
- * Copyright (c) 2010, Howard Butler
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following
- * conditions are met:
- * * Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided
- * with the distribution.
- * * Neither the name of the Martin Isenburg or Iowa Department
- * of Natural Resources nor the names of its contributors may be
- * used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
- * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
- * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
- * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
- * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
- * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
- * OF SUCH DAMAGE.
-#ifndef LIBLAS_DETAIL_READER_POINT_HPP_INCLUDED
-#define LIBLAS_DETAIL_READER_POINT_HPP_INCLUDED
-#include <liblas/lasversion.hpp>
-#include <liblas/lasspatialreference.hpp>
-#include <liblas/detail/fwd.hpp>
-#include <liblas/lasheader.hpp>
-#include <liblas/laspoint.hpp>
-#include <liblas/lasschema.hpp>
-// boost
-#include <boost/cstdint.hpp>
-// std
-#include <iosfwd>
-namespace liblas { namespace detail { namespace reader {
-class Point
-public:
- Point(std::istream& ifs, HeaderPtr header);
- virtual ~Point();
- liblas::Point& GetPoint() { return m_point; }
- void read();
-protected:
- typedef std::istream::off_type off_type;
- typedef std::istream::pos_type pos_type;
-private:
- // Blocked copying operations, declared but not defined.
- Point(Point const& other);
- Point& operator=(Point const& rhs);
- std::istream& m_ifs;
- HeaderPtr m_header;
- liblas::Point m_point;
- std::vector<boost::uint8_t>::size_type m_record_size;
-}}} // namespace liblas::detail::reader
-#endif // LIBLAS_DETAIL_READER_POINT_HPP_INCLUDED
diff -r da97381c72bd -r 8a23d7247e87 include/liblas/detail/reader/reader.hpp
--- a/include/liblas/detail/reader/reader.hpp Mon Dec 20 12:39:27 2010 -0600
+++ b/include/liblas/detail/reader/reader.hpp Mon Dec 20 21:58:37 2010 -0600
@@ -43,7 +43,7 @@
#define LIBLAS_DETAIL_READERIMPL_HPP_INCLUDED
+// #include <liblas/detail/reader/point.hpp>
// boost
@@ -54,7 +54,7 @@
-typedef boost::shared_ptr< reader::Point > PointReaderPtr;
+// typedef boost::shared_ptr< reader::Point > PointReaderPtr;
typedef boost::shared_ptr< reader::Header > HeaderReaderPtr;
class ReaderImpl : public ReaderI
@@ -90,7 +90,7 @@
boost::uint32_t m_size;
boost::uint32_t m_current;
- PointReaderPtr m_point_reader;
+ // PointReaderPtr m_point_reader;
HeaderReaderPtr m_header_reader;
HeaderPtr m_header;
@@ -99,6 +99,9 @@
std::vector<liblas::FilterPtr> m_filters;
std::vector<liblas::TransformPtr> m_transforms;
+ std::vector<boost::uint8_t>::size_type m_record_size;
+ bool bNeedHeaderCheck;
private:
diff -r da97381c72bd -r 8a23d7247e87 include/liblas/utility.hpp
--- a/include/liblas/utility.hpp Mon Dec 20 12:39:27 2010 -0600
+++ b/include/liblas/utility.hpp Mon Dec 20 21:58:37 2010 -0600
@@ -87,6 +87,8 @@
liblas::Point max;
liblas::Header m_header;
bool bHaveHeader;
+ bool bHaveColor;
+ bool bHaveTime;
class LAS_DLL CoordinateSummary
@@ -111,6 +113,8 @@
liblas::Point max;
bool bHaveHeader;
+ bool bHaveColor;
+ bool bHaveTime;
LAS_DLL std::ostream& operator<<(std::ostream& os, liblas::Summary const& s);
diff -r da97381c72bd -r 8a23d7247e87 src/CMakeLists.txt
--- a/src/CMakeLists.txt Mon Dec 20 12:39:27 2010 -0600
+++ b/src/CMakeLists.txt Mon Dec 20 21:58:37 2010 -0600
@@ -138,7 +138,6 @@
set(LIBLAS_DETAIL_READER_CPP
detail/reader/header.cpp
- detail/reader/point.cpp
detail/reader/zipreader.cpp
detail/reader/cachedreader.cpp)
diff -r da97381c72bd -r 8a23d7247e87 src/detail/reader/cachedreader.cpp
--- a/src/detail/reader/cachedreader.cpp Mon Dec 20 12:39:27 2010 -0600
+++ b/src/detail/reader/cachedreader.cpp Mon Dec 20 21:58:37 2010 -0600
@@ -142,9 +142,10 @@
throw std::out_of_range("ReadNextPoint: file has no more points to read, end of file reached");
- m_point_reader->read();
+ // m_point_reader->read();
+ detail::read_n(m_point->GetData().front(), m_ifs, m_record_size);
++m_current;
- *m_point = m_point_reader->GetPoint();
+ // *m_point = m_point_reader->GetPoint();
if (!m_transforms.empty())
diff -r da97381c72bd -r 8a23d7247e87 src/detail/reader/point.cpp
--- a/src/detail/reader/point.cpp Mon Dec 20 12:39:27 2010 -0600
@@ -1,83 +0,0 @@
- * $Id$
- * OF SUCH DAMAGE.
-#include <liblas/detail/reader/reader.hpp>
-#include <liblas/detail/private_utility.hpp>
-// boost
-#include <boost/array.hpp>
-// std
-#include <cstring>
-#include <sstream>
-using namespace boost;
-using namespace std;
-Point::Point(std::istream& ifs, HeaderPtr header)
- : m_ifs(ifs)
- , m_header(header)
- , m_point(m_header)
- , m_record_size(m_header->GetSchema().GetByteSize())
-Point::~Point()
-void Point::read()
- assert(m_header);
- assert(m_point.GetHeaderPtr());
- assert(m_record_size > 0);
- if (m_point.GetHeaderPtr().get() != m_header.get())
- m_point.SetHeaderPtr(m_header);
- detail::read_n(m_point.GetData().front(), m_ifs, m_record_size);
diff -r da97381c72bd -r 8a23d7247e87 src/detail/reader/reader.cpp
--- a/src/detail/reader/reader.cpp Mon Dec 20 12:39:27 2010 -0600
+++ b/src/detail/reader/reader.cpp Mon Dec 20 21:58:37 2010 -0600
@@ -63,12 +63,13 @@
: m_ifs(ifs)
, m_size(0)
, m_current(0)
- , m_point_reader(PointReaderPtr())
+ // , m_point_reader(PointReaderPtr())
, m_header_reader(new reader::Header(m_ifs))
, m_header(HeaderPtr())
, m_point(PointPtr(new liblas::Point()))
, m_filters(0)
, m_transforms(0)
+ , bNeedHeaderCheck(false)
@@ -85,13 +86,8 @@
// Reset sizes and set internal cursor to the beginning of file.
m_current = 0;
m_size = m_header->GetPointRecordsCount();
More information about the Liblas-commits
