[Liblas-commits] hg: fix up some liblas::Point header assignment stuff introduced...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Dec 21 16:44:03 EST 2010
changeset 4cf422b7140a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=4cf422b7140a
summary: fix up some liblas::Point header assignment stuff introduced by the last few days of performance tweaking
diffstat:
 src/detail/reader/reader.cpp |   5 ++-
 src/laspoint.cpp             |  51 +++++++++++++++++++++++++++++--------------
 src/utility.cpp              |   1 +
 3 files changed, 38 insertions(+), 19 deletions(-)
diffs (154 lines):
diff -r f7e0d60d2e06 -r 4cf422b7140a src/detail/reader/reader.cpp
--- a/src/detail/reader/reader.cpp	Tue Dec 21 08:40:29 2010 -0600
+++ b/src/detail/reader/reader.cpp	Tue Dec 21 15:43:55 2010 -0600
@@ -134,6 +134,7 @@
     m_header_reader->read();
     m_header = m_header_reader->GetHeader();
+    m_point->SetHeaderPtr(m_header);
     Reset();
@@ -159,7 +160,7 @@
     if (bNeedHeaderCheck)
-        if (m_point->GetHeaderPtr() != m_header)
+        if (m_point->GetHeaderPtr().get() != m_header.get())
@@ -222,7 +223,7 @@
diff -r f7e0d60d2e06 -r 4cf422b7140a src/laspoint.cpp
--- a/src/laspoint.cpp	Tue Dec 21 08:40:29 2010 -0600
+++ b/src/laspoint.cpp	Tue Dec 21 15:43:55 2010 -0600
@@ -190,7 +190,7 @@
     boost::uint16_t wanted_length;
-    if (header)
+    if (header.get())
         wanted_length = header->GetDataRecordLength();
     else
         wanted_length = m_default_header.GetDataRecordLength();
@@ -200,8 +200,10 @@
     boost::uint32_t sum = std::accumulate(m_data.begin(), m_data.end(), 0);
     if (!sum) {
-        m_data.resize(wanted_length);
-        m_data.assign(wanted_length, 0);
+        std::vector<boost::uint8_t> data;
+        data.resize(wanted_length);
+        data.assign(wanted_length, 0);
+        m_data = data;
         m_header = header;
         return;
@@ -213,9 +215,12 @@
         // layout is likely changing as a result of the
         // schema change.
         Point p(*this);
+        m_data = data;
+        m_header = header;
         SetX(p.GetX());
         SetY(p.GetY());
@@ -239,6 +244,10 @@
         // FIXME: copy other custom dimensions here?  resetting the
         // headerptr can be catastrophic in a lot of cases.
+    } else
+        return;
     double x = GetX();
@@ -849,17 +858,18 @@
     if (f == ePointFormat3)
         index_pos = index_pos + 8; // increment to include position of Time.
     std::vector<boost::uint8_t>::size_type red_pos = index_pos;
+    std::vector<boost::uint8_t>::size_type green_pos = index_pos + 2;
+    std::vector<boost::uint8_t>::size_type blue_pos = index_pos + 4;
-    assert(red_pos + sizeof(Color::value_type) <= m_data.size());
+    assert(red_pos <= m_data.size());
+    assert(blue_pos <= m_data.size());
+    assert(green_pos <= m_data.size());
     red = bitsToInt<boost::uint16_t>(red, m_data, red_pos);
-    std::vector<boost::uint8_t>::size_type green_pos = index_pos + 2;
-    assert(green_pos + sizeof(Color::value_type) <= m_data.size());
     green = bitsToInt<boost::uint16_t>(green, m_data, green_pos);
-    std::vector<boost::uint8_t>::size_type blue_pos = index_pos + 4;
-    assert(blue_pos + sizeof(Color::value_type) <= m_data.size());
     blue = bitsToInt<boost::uint16_t>(blue, m_data, blue_pos);
   return Color(red, green, blue);
@@ -872,7 +882,7 @@
     // std::size_t index_pos = 13;
     PointFormatName f;
-    if (m_header) {
+    if (m_header.get()) {
         f = m_header->GetDataFormatId();
     } else {
         f = m_default_header.GetDataFormatId();
@@ -885,6 +895,13 @@
         throw std::runtime_error(msg.str());
+    if ( m_data.size() == ePointFormat0 || f == ePointFormat1 ) {
+        std::ostringstream msg;
+        msg << "Point::SetColor - Unable to set color for ePointFormat0 or ePointFormat1, "
+            << "no Color dimension exists on this format";
+        throw std::runtime_error(msg.str());
     using liblas::detail::intToBits;
     std::size_t index_pos = 20;
@@ -896,9 +913,9 @@
     intToBits<boost::uint16_t>(value.GetRed(), m_data, red_pos);
     intToBits<boost::uint16_t>(value.GetGreen(), m_data, green_pos);
diff -r f7e0d60d2e06 -r 4cf422b7140a src/utility.cpp
--- a/src/utility.cpp	Tue Dec 21 08:40:29 2010 -0600
+++ b/src/utility.cpp	Tue Dec 21 15:43:55 2010 -0600
@@ -128,6 +128,7 @@
                 liblas::Header header;
                 header.SetScale(hdr->GetScaleX(), hdr->GetScaleY(), hdr->GetScaleZ());
                 header.SetOffset(hdr->GetOffsetX(), hdr->GetOffsetY(), hdr->GetOffsetZ());
+                header.SetDataFormatId(hdr->GetDataFormatId());
                 liblas::HeaderPtr h(new liblas::Header(header));
                 min.SetHeaderPtr(h);
                 max.SetHeaderPtr(h);
More information about the Liblas-commits mailing list
