[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Wed Dec 22 11:09:32 EST 2010
changeset 50ff17114a26 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=50ff17114a26
summary: describe the order of the colors in the summary
changeset 34b4c42ff3ff in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=34b4c42ff3ff
summary: set color independently of time in SetHeaderPtr
diffstat:
src/laspoint.cpp | 7 +++++++
src/utility.cpp | 4 ++--
2 files changed, 9 insertions(+), 2 deletions(-)
diffs (36 lines):
diff -r 568d04ecfacd -r 34b4c42ff3ff src/laspoint.cpp
--- a/src/laspoint.cpp Tue Dec 21 21:42:24 2010 -0600
+++ b/src/laspoint.cpp Wed Dec 22 10:09:22 2010 -0600
@@ -236,6 +236,13 @@
try
SetTime(p.GetTime());
+ catch (std::runtime_error const&)
+ try
SetColor(p.GetColor());
diff -r 568d04ecfacd -r 34b4c42ff3ff src/utility.cpp
--- a/src/utility.cpp Tue Dec 21 21:42:24 2010 -0600
+++ b/src/utility.cpp Wed Dec 22 10:09:22 2010 -0600
@@ -467,13 +467,13 @@
<< tree.get<boost::uint32_t>("summary.points.maximum.userdata");
os << std::endl;
- os << " Minimum Color:\t"
+ os << " Minimum Color (RGB):\t"
<< tree.get<boost::uint32_t>("summary.points.minimum.color.red") << " "
<< tree.get<boost::uint32_t>("summary.points.minimum.color.green") << " "
<< tree.get<boost::uint32_t>("summary.points.minimum.color.blue") << " ";
os << std::endl;
- os << " Maximum Color:\t"
+ os << " Maximum Color (RGB):\t"
<< tree.get<boost::uint32_t>("summary.points.maximum.color.red") << " "
<< tree.get<boost::uint32_t>("summary.points.maximum.color.green") << " "
<< tree.get<boost::uint32_t>("summary.points.maximum.color.blue") << " ";
More information about the Liblas-commits
