[Liblas-commits] laszip: 3 new changesets
liblas-commits at liblas.org
Wed Dec 22 15:51:35 EST 2010
changeset 3e5e0ec93ea6 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=3e5e0ec93ea6
summary: pass streams by ref, not as pointers; return status code on open, not bool; declare items parameter as an array
changeset e651d0722c7e in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=e651d0722c7e
summary: pull-merge
changeset e8f5528c3d30 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=e8f5528c3d30
summary: sync w/ Martin's changes
diffstat:
include/laszip/lasunzipper.hpp | 89 ++++++++++----------
include/laszip/laszip.hpp | 164 +++++++++++++++++++++++++++----------
include/laszip/laszipper.hpp | 92 ++++++++++----------
src/bytestreamin_istream.hpp | 28 +++---
src/bytestreamout_ostream.hpp | 44 +++++-----
src/lasreaditem.hpp | 2 +-
src/lasreaditemcompressed_v1.cpp | 102 +++++++++++++++++++----
src/lasreaditemcompressed_v1.hpp | 43 +++++++--
src/lasreaditemraw.hpp | 25 ++++-
src/lasreadpoint.cpp | 30 +++---
src/lasreadpoint.hpp | 2 +-
src/lasunzipper.cpp | 28 +++---
src/laswriteitem.hpp | 4 +-
src/laswriteitemcompressed_v1.cpp | 109 ++++++++++++++++++++----
src/laswriteitemcompressed_v1.hpp | 51 ++++++++---
src/laswriteitemraw.hpp | 33 +++++-
src/laswritepoint.cpp | 35 +++++---
src/laswritepoint.hpp | 2 +-
src/laszipper.cpp | 33 ++++---
src/rangedecoder.cpp | 2 +-
src/rangeencoder.cpp | 2 +-
tools/laszippertest.cpp | 28 +++---
22 files changed, 626 insertions(+), 322 deletions(-)
diffs (truncated from 1888 to 300 lines):
diff -r b095ef93a1f2 -r e8f5528c3d30 include/laszip/lasunzipper.hpp
--- a/include/laszip/lasunzipper.hpp Sat Dec 18 12:29:58 2010 -0800
+++ b/include/laszip/lasunzipper.hpp Wed Dec 22 11:25:03 2010 -0800
@@ -16,36 +16,36 @@
- FILE: LASunzipper.hpp
- CONTENTS:
- Reads (optionally compressed) LIDAR points to LAS formats 1.0 - 1.3
- PROGRAMMERS:
- martin isenburg at cs.unc.edu
- COPYRIGHT:
- copyright (C) 2010 martin isenburg at cs.unc.edu
- This software is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
- CHANGE HISTORY:
+ FILE: LASunzipper.hpp
+ CONTENTS:
+ Reads (optionally compressed) LIDAR points to LAS formats 1.0 - 1.3
+ PROGRAMMERS:
+ martin isenburg at cs.unc.edu
+ COPYRIGHT:
+ copyright (C) 2010 martin isenburg at cs.unc.edu
+ This software is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+ CHANGE HISTORY:
12 December 2010 -- created from LASwriter/LASreader after Howard got pushy (-;
-#ifndef LAS_UNZIPPER_H
-#define LAS_UNZIPPER_H
+#ifndef LAS_UNZIPPER_H
+#define LAS_UNZIPPER_H
#include <stdio.h>
#include "laszip.hpp"
@@ -57,26 +57,25 @@
#include <fstream>
using namespace std;
#endif
class ByteStreamIn;
class LASreadPoint;
-class LASunzipper
-public:
- bool open(FILE* file, unsigned int num_items, const LASitem* items, unsigned int compression=0);
- bool open(istream* stream, unsigned int num_items, const LASitem* items, unsigned int compression=0);
- bool read(unsigned char** point);
+class LASunzipper
+public:
+ unsigned int open(FILE* file, unsigned int num_items, const LASitem items[], unsigned int compression=0);
+ unsigned int open(istream& stream, unsigned int num_items, const LASitem items[], unsigned int compression=0);
+ bool read(unsigned char * const * point);
unsigned int close();
- LASunzipper();
- ~LASunzipper();
+ LASunzipper();
+ ~LASunzipper();
private:
- int count;
+ int count;
ByteStreamIn* stream;
LASreadPoint* reader;
-#endif
+#endif
diff -r b095ef93a1f2 -r e8f5528c3d30 include/laszip/laszip.hpp
--- a/include/laszip/laszip.hpp Sat Dec 18 12:29:58 2010 -0800
+++ b/include/laszip/laszip.hpp Wed Dec 22 11:25:03 2010 -0800
@@ -49,54 +49,88 @@
#if defined(_MSC_VER) && (_MSC_VER < 1300)
#define LZ_WIN32_VC6
+typedef __int64 SIGNED_INT64;
+#else
+typedef long long SIGNED_INT64;
#endif
#define LASZIP_VERSION_MAJOR 1
#define LASZIP_VERSION_MINOR 0
#define LASZIP_VERSION_REVISION 0
-#define LASZIP_COMPRESSION_NONE 0
-#define LASZIP_COMPRESSION_RANGE 1
-#define LASZIP_COMPRESSION_ARITHMETIC 2
+#define LASZIP_COMPRESSION_NONE 0
+#define LASZIP_COMPRESSION_ARITHMETIC 1
+#define LASZIP_COMPRESSION_RANGE 2
+#define LASZIP_COMPRESSION_DEFAULT 1
class LASitem
public:
- enum Type { BYTE = 0, SHORT, INT, LONG, FLOAT, DOUBLE, POINT10, GPSTIME, RGB, WAVEPACKET } type;
+ enum Type { BYTE = 0, SHORT, INT, LONG, FLOAT, DOUBLE, POINT10, GPSTIME11, RGB12, WAVEPACKET13 } type;
unsigned short size;
unsigned short version;
- // convenience function (not done as a ctor, since these items are usually allocated as an array)
- void set(LASitem::Type type)
+ void set(LASitem::Type t, unsigned int number=1)
- LASitem& x = *this;
- switch (type)
- case LASitem::POINT10:
- x.type = LASitem::POINT10;
- x.size = 20;
- x.version = 0;
- break;
- case LASitem::GPSTIME:
- x.type = LASitem::GPSTIME;
- x.size = 8;
- x.version = 0;
- break;
- case LASitem::RGB:
- x.type = LASitem::RGB;
- x.size = 6;
- x.version = 0;
- break;
- case LASitem::WAVEPACKET:
- x.type = LASitem::WAVEPACKET;
- x.size = 29;
- x.version = 0;
- break;
- default:
- throw 0; // BUG
- return;
+ switch (t)
+ case LASitem::POINT10:
+ type = LASitem::POINT10;
+ size = 20;
+ version = 0;
+ break;
+ case LASitem::GPSTIME11:
+ type = LASitem::GPSTIME11;
+ size = 8;
+ version = 0;
+ break;
+ case LASitem::RGB12:
+ type = LASitem::RGB12;
+ size = 6;
+ version = 0;
+ break;
+ case LASitem::WAVEPACKET13:
+ type = LASitem::WAVEPACKET13;
+ size = 29;
+ version = 0;
+ break;
+ case LASitem::BYTE:
+ type = LASitem::BYTE;
+ size = number;
+ version = 0;
+ break;
+ default:
+ throw 0; // BUG
+ return;
+ bool is_type(LASitem::Type t) const
+ if (t != type) return false;
+ switch (t)
+ case POINT10:
+ if (size != 20) return false;
+ break;
+ case GPSTIME11:
+ if (size != 8) return false;
+ break;
+ case RGB12:
+ if (size != 6) return false;
+ break;
+ case WAVEPACKET13:
+ if (size != 29) return false;
+ break;
+ case BYTE:
+ if (size < 1) return false;
+ break;
+ default:
+ return false;
+ return true;
bool supported_type() const
@@ -104,12 +138,14 @@
switch (type)
case POINT10:
- case GPSTIME:
- case RGB:
- case WAVEPACKET:
+ case GPSTIME11:
+ case RGB12:
case BYTE:
return true;
break;
+ default:
+ return false;
return false;
@@ -121,13 +157,13 @@
case POINT10:
break;
- case GPSTIME:
+ case GPSTIME11:
break;
- case RGB:
+ case RGB12:
break;
- case WAVEPACKET:
break;
case BYTE:
@@ -146,13 +182,13 @@
case POINT10:
if (version > 1) return false;
break;
- case GPSTIME:
+ case GPSTIME11:
break;
- case RGB:
+ case RGB12:
break;
- case WAVEPACKET:
break;
case BYTE:
@@ -172,15 +208,15 @@
break;
- case GPSTIME:
+ case GPSTIME11:
break;
- case RGB:
+ case RGB12:
More information about the Liblas-commits
