[Liblas-commits] laszip: updated RGB encoding to be endian neutral
liblas-commits at liblas.org
Thu Dec 23 08:45:59 EST 2010
changeset 7770fdf9c7c2 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=7770fdf9c7c2
summary: updated RGB encoding to be endian neutral
diffstat:
src/arithmeticdecoder.cpp | 8 +-
src/arithmeticencoder.cpp | 8 +-
src/lasreaditemcompressed_v1.cpp | 66 +++++++++++++++++++-----
src/lasreaditemcompressed_v1.hpp | 2 +
src/laswriteitemcompressed_v1.cpp | 101 +++++++++++++++++++++++++------------
src/laswriteitemcompressed_v1.hpp | 2 +
src/laswritepoint.cpp | 4 +-
7 files changed, 133 insertions(+), 58 deletions(-)
diffs (truncated from 430 to 300 lines):
diff -r 4daf73355dc6 -r 7770fdf9c7c2 src/arithmeticdecoder.cpp
--- a/src/arithmeticdecoder.cpp Wed Dec 22 14:16:19 2010 -0800
+++ b/src/arithmeticdecoder.cpp Thu Dec 23 05:45:46 2010 -0800
@@ -235,28 +235,28 @@
return (U16)sym;
-U32 ArithmeticDecoder::readInt()
+inline U32 ArithmeticDecoder::readInt()
U32 lowerInt = readShort();
U32 upperInt = readShort();
return upperInt*U16_MAX_PLUS_ONE+lowerInt;
-F32 ArithmeticDecoder::readFloat()
+inline F32 ArithmeticDecoder::readFloat()
U32F32 u32f32;
u32f32.u32 = readInt();
return u32f32.f32;
-U64 ArithmeticDecoder::readInt64()
+inline U64 ArithmeticDecoder::readInt64()
U64 lowerInt = readInt();
U64 upperInt = readInt();
return upperInt*U32_MAX_PLUS_ONE+lowerInt;
-F64 ArithmeticDecoder::readDouble()
+inline F64 ArithmeticDecoder::readDouble()
U64F64 u64f64;
u64f64.u64 = readInt64();
diff -r 4daf73355dc6 -r 7770fdf9c7c2 src/arithmeticencoder.cpp
--- a/src/arithmeticencoder.cpp Wed Dec 22 14:16:19 2010 -0800
+++ b/src/arithmeticencoder.cpp Thu Dec 23 05:45:46 2010 -0800
@@ -236,26 +236,26 @@
if (length < AC__MinLength) renorm_enc_interval(); // renormalization
-void ArithmeticEncoder::writeInt(U32 sym)
+inline void ArithmeticEncoder::writeInt(U32 sym)
writeShort((U16)(sym % U16_MAX_PLUS_ONE)); // lower 16 bits
writeShort((U16)(sym / U16_MAX_PLUS_ONE)); // UPPER 16 bits
-void ArithmeticEncoder::writeFloat(F32 sym)
+inline void ArithmeticEncoder::writeFloat(F32 sym)
U32F32 u32f32;
u32f32.f32 = sym;
writeInt(u32f32.u32);
-void ArithmeticEncoder::writeInt64(U64 sym)
+inline void ArithmeticEncoder::writeInt64(U64 sym)
writeInt((U32)(sym % U32_MAX_PLUS_ONE)); // lower 32 bits
writeInt((U32)(sym / U32_MAX_PLUS_ONE)); // UPPER 32 bits
-void ArithmeticEncoder::writeDouble(F64 sym)
+inline void ArithmeticEncoder::writeDouble(F64 sym)
U64F64 u64f64;
u64f64.f64 = sym;
diff -r 4daf73355dc6 -r 7770fdf9c7c2 src/lasreaditemcompressed_v1.cpp
--- a/src/lasreaditemcompressed_v1.cpp Wed Dec 22 14:16:19 2010 -0800
+++ b/src/lasreaditemcompressed_v1.cpp Thu Dec 23 05:45:46 2010 -0800
@@ -305,7 +305,7 @@
else if (multi == 2) // the difference is huge
- last_gpstime.f64 = dec->readDouble();
+ last_gpstime.i64 = dec->readInt64();
else
@@ -356,7 +356,7 @@
else if (multi < LASZIP_GPSTIME_MULTIMAX-1)
*((F64*)item) = last_gpstime.f64;
@@ -405,15 +405,20 @@
inline BOOL LASreadItemCompressed_RGB12_v1::read(U8* item)
- U32 i, sym = dec->decodeSymbol(m_byte_used);
- for (i = 0; i < 6; i++)
- if (sym & (1 << i))
- item[i] = ic_rgb->decompress(last_item[i], i);
- last_item[i] = item[i];
+ U32 sym = dec->decodeSymbol(m_byte_used);
+ if (sym & (1 << 0)) ((U16*)item)[0] = ic_rgb->decompress(((U16*)last_item)[0]&255, 0);
+ else ((U16*)item)[0] = ((U16*)last_item)[0]&255;
+ if (sym & (1 << 1)) ((U16*)item)[0] |= (ic_rgb->decompress(((U16*)last_item)[0]>>8, 1) << 8);
+ else ((U16*)item)[0] |= (((U16*)last_item)[0]&65280);
+ if (sym & (1 << 2)) ((U16*)item)[1] = ic_rgb->decompress(((U16*)last_item)[1]&255, 2);
+ else ((U16*)item)[1] = ((U16*)last_item)[1]&255;
+ if (sym & (1 << 3)) ((U16*)item)[1] |= (ic_rgb->decompress(((U16*)last_item)[1]>>8, 3) << 8);
+ else ((U16*)item)[1] |= (((U16*)last_item)[1]&65280);
+ if (sym & (1 << 4)) ((U16*)item)[2] = ic_rgb->decompress(((U16*)last_item)[2]&255, 4);
+ else ((U16*)item)[2] = ((U16*)last_item)[2]&255;
+ if (sym & (1 << 5)) ((U16*)item)[2] |= (ic_rgb->decompress(((U16*)last_item)[2]>>8, 5) << 8);
+ else ((U16*)item)[2] |= (((U16*)last_item)[2]&65280);
+ memcpy(last_item, item, 6);
return TRUE;
@@ -423,6 +428,16 @@
+struct LASwavepacket13
+ U64 offset;
+ U32 packet_size;
+ I32F32 return_point;
+ I32F32 x;
+ I32F32 y;
+ I32F32 z;
LASreadItemCompressed_WAVEPACKET13_v1::LASreadItemCompressed_WAVEPACKET13_v1(EntropyDecoder* dec)
/* set decoder */
@@ -433,11 +448,12 @@
m_packet_index = dec->createSymbolModel(256);
m_small_offset_diff = dec->createBitModel();
ic_offset_diff = new IntegerCompressor(dec, 32);
+ ic_packet_size = new IntegerCompressor(dec, 32);
ic_return_point = new IntegerCompressor(dec, 32);
ic_xyz = new IntegerCompressor(dec, 32, 3);
/* create last item */
- last_item = new U8[29];
+ last_item = new U8[28];
LASreadItemCompressed_WAVEPACKET13_v1::~LASreadItemCompressed_WAVEPACKET13_v1()
@@ -445,6 +461,7 @@
dec->destroySymbolModel(m_packet_index);
dec->destroyBitModel(m_small_offset_diff);
delete ic_offset_diff;
+ delete ic_packet_size;
delete ic_return_point;
delete ic_xyz;
delete [] last_item;
@@ -453,23 +470,42 @@
BOOL LASreadItemCompressed_WAVEPACKET13_v1::init(const U8* item)
/* init state */
+ last_diff_32 = 0;
/* init models and integer compressors */
dec->initSymbolModel(m_packet_index);
dec->initBitModel(m_small_offset_diff);
ic_offset_diff->initDecompressor();
+ ic_packet_size->initDecompressor();
ic_return_point->initDecompressor();
ic_xyz->initDecompressor();
/* init last item */
- memcpy(last_item, item, 29);
+ item++;
+ memcpy(last_item, item, 28);
return TRUE;
inline BOOL LASreadItemCompressed_WAVEPACKET13_v1::read(U8* item)
-// dec->decodeSymbol(m_packet_index);
-// ic_xyz->decompress(last_item[i], i);
+ item[0] = (U8)(dec->decodeSymbol(m_packet_index));
+ item++;
+ if (dec->decodeBit(m_small_offset_diff))
+ last_diff_32 = ic_offset_diff->decompress(last_diff_32);
+ ((LASwavepacket13*)item)->offset = ((LASwavepacket13*)last_item)->offset + last_diff_32;
+ else
+ ((LASwavepacket13*)item)->offset = dec->readInt64();
+ ((LASwavepacket13*)item)->packet_size = ic_packet_size->decompress(((LASwavepacket13*)last_item)->packet_size);
+ ((LASwavepacket13*)item)->return_point.i32 = ic_return_point->decompress(((LASwavepacket13*)last_item)->return_point.i32);
+ ((LASwavepacket13*)item)->x.i32 = ic_xyz->decompress(((LASwavepacket13*)last_item)->x.i32, 0);
+ ((LASwavepacket13*)item)->y.i32 = ic_xyz->decompress(((LASwavepacket13*)last_item)->y.i32, 1);
+ ((LASwavepacket13*)item)->z.i32 = ic_xyz->decompress(((LASwavepacket13*)last_item)->z.i32, 2);
return TRUE;
diff -r 4daf73355dc6 -r 7770fdf9c7c2 src/lasreaditemcompressed_v1.hpp
--- a/src/lasreaditemcompressed_v1.hpp Wed Dec 22 14:16:19 2010 -0800
+++ b/src/lasreaditemcompressed_v1.hpp Thu Dec 23 05:45:46 2010 -0800
@@ -137,9 +137,11 @@
EntropyDecoder* dec;
U8* last_item;
+ I32 last_diff_32;
EntropyModel* m_packet_index;
EntropyModel* m_small_offset_diff;
IntegerCompressor* ic_offset_diff;
+ IntegerCompressor* ic_packet_size;
IntegerCompressor* ic_return_point;
IntegerCompressor* ic_xyz;
diff -r 4daf73355dc6 -r 7770fdf9c7c2 src/laswriteitemcompressed_v1.cpp
--- a/src/laswriteitemcompressed_v1.cpp Wed Dec 22 14:16:19 2010 -0800
+++ b/src/laswriteitemcompressed_v1.cpp Thu Dec 23 05:45:46 2010 -0800
@@ -57,18 +57,18 @@
struct LASpoint10
- int x;
- int y;
- int z;
- unsigned short intensity;
- unsigned char return_number : 3;
- unsigned char number_of_returns_of_given_pulse : 3;
- unsigned char scan_direction_flag : 1;
- unsigned char edge_of_flight_line : 1;
- unsigned char classification;
- char scan_angle_rank;
- unsigned char user_data;
- unsigned short point_source_ID;
+ I32 x;
+ I32 y;
+ I32 z;
+ U16 intensity;
+ U8 return_number : 3;
+ U8 number_of_returns_of_given_pulse : 3;
+ U8 scan_direction_flag : 1;
+ U8 edge_of_flight_line : 1;
+ U8 classification;
+ I8 scan_angle_rank;
+ U8 user_data;
+ U16 point_source_ID;
LASwriteItemCompressed_POINT10_v1::LASwriteItemCompressed_POINT10_v1(EntropyEncoder* enc)
@@ -318,7 +318,7 @@
else
enc->encodeSymbol(m_gpstime_0diff, 2); // the difference is huge
- enc->writeDouble(this_gpstime.f64);
+ enc->writeInt64(this_gpstime.i64);
last_gpstime.f64 = this_gpstime.f64;
@@ -396,9 +396,9 @@
else
- // if difference is so huge ... we simply write the double (for now)
+ // if difference is so huge ... we simply write the double
enc->encodeSymbol(m_gpstime_multi, LASZIP_GPSTIME_MULTIMAX-2);
@@ -448,20 +448,20 @@
inline BOOL LASwriteItemCompressed_RGB12_v1::write(const U8* item)
- U32 i, sym = 0;
- sym |= ((last_item[i] != item[i]) << i);
+ U32 sym = ((((U16*)last_item)[0]&0x00FF) != (((U16*)item)[0]&0x00FF)) << 0;
+ sym |= ((((U16*)last_item)[0]&0xFF00) != (((U16*)item)[0]&0xFF00)) << 1;
+ sym |= ((((U16*)last_item)[1]&0x00FF) != (((U16*)item)[1]&0x00FF)) << 2;
+ sym |= ((((U16*)last_item)[1]&0xFF00) != (((U16*)item)[1]&0xFF00)) << 3;
+ sym |= ((((U16*)last_item)[2]&0x00FF) != (((U16*)item)[2]&0x00FF)) << 4;
+ sym |= ((((U16*)last_item)[2]&0xFF00) != (((U16*)item)[2]&0xFF00)) << 5;
enc->encodeSymbol(m_byte_used, sym);
- if (last_item[i] != item[i])
- ic_rgb->compress(last_item[i], item[i], i);
More information about the Liblas-commits
