[Liblas-commits] hg: delete dead code
liblas-commits at liblas.org
Thu Dec 23 14:23:13 EST 2010
details: http://hg.liblas.orghg/rev/1e4fe91df19d
changeset: 2635:1e4fe91df19d
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Dec 23 13:23:08 2010 -0600
description:
delete dead code
diffstat:
src/header.cpp | 28 ----------------------------
1 files changed, 0 insertions(+), 28 deletions(-)
diffs (38 lines):
diff -r 7c81fc8db21c -r 1e4fe91df19d src/header.cpp
--- a/src/header.cpp Thu Dec 23 13:16:41 2010 -0600
+++ b/src/header.cpp Thu Dec 23 13:23:08 2010 -0600
@@ -662,34 +662,6 @@
void Header::SetSchema(const Schema& format)
- // // A user can use the set the header's version information and
- // // format information and sizes by using a PointFormat instance
- // // in addition to setting all the settings individually by hand
- // // The DataRecordLength will be set to the max of either the format's
- // // byte size or the pointformat's specified size according to whether
- // // or not it has color or time (FIXME: or waveform packets once we get to 1.3 )
- // // The extra space that is available can be used to store LASPoint::GetExtraData.
- // // We trim the format size to uint16_t because that's what the header stores
- // if (format.HasColor() && format.HasTime()) {
- // SetDataFormatId(liblas::ePointFormat3);
- // SetDataRecordLength(std::max( static_cast<uint16_t>(ePointSize3),
- // static_cast<uint16_t>(format.GetByteSize())));
- // } else if (format.HasColor() && !format.HasTime()) {
- // SetDataFormatId(liblas::ePointFormat2);
- // SetDataRecordLength(std::max( static_cast<uint16_t>(ePointSize2),
- // } else if (!format.HasColor() && format.HasTime()) {
- // SetDataFormatId(liblas::ePointFormat1);
- // SetDataRecordLength(std::max( static_cast<uint16_t>(ePointSize1),
- // } else {
- // SetDataFormatId(liblas::ePointFormat0);
- // SetDataRecordLength(std::max( static_cast<uint16_t>(ePointSize0),
m_schema = format;
// Reset the X, Y, Z dimensions with offset and scale values
More information about the Liblas-commits
