[Liblas-commits] laszip: remove calls to fprintf, exit
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Dec 27 14:44:51 EST 2010
details:   http://hg.liblas.orglaszip/rev/7af78ceb3bfa
changeset: 90:7af78ceb3bfa
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Mon Dec 27 12:14:06 2010 -0700
description:
Subject: laszip: remove fprintf calls
details:   http://hg.liblas.orglaszip/rev/ba16595e644c
changeset: 91:ba16595e644c
date:      Mon Dec 27 12:15:58 2010 -0700
description:
Subject: laszip: fix err checks on open()
details:   http://hg.liblas.orglaszip/rev/ce1bdb2a9e26
changeset: 92:ce1bdb2a9e26
date:      Mon Dec 27 12:17:59 2010 -0700
description:
Subject: laszip: use an enum for the compression type, for type safety
details:   http://hg.liblas.orglaszip/rev/276b21e82629
changeset: 93:276b21e82629
date:      Mon Dec 27 12:35:32 2010 -0700
description:
Subject: laszip: explicit default param no longer needed
details:   http://hg.liblas.orglaszip/rev/16cbedc7335f
changeset: 94:16cbedc7335f
date:      Mon Dec 27 12:44:10 2010 -0700
description:
diffstat:
 include/laszip/lasunzipper.hpp |   4 ++--
 include/laszip/laszip.hpp      |  13 +++++++++----
 include/laszip/laszipper.hpp   |   4 ++--
 src/bytestreamin_file.hpp      |   2 +-
 src/bytestreamin_istream.hpp   |   2 +-
 src/lasreadpoint.cpp           |  10 +++++-----
 src/lasreadpoint.hpp           |   2 +-
 src/lasunzipper.cpp            |   8 ++++----
 src/laswritepoint.cpp          |  10 +++++-----
 src/laswritepoint.hpp          |   2 +-
 src/laszipper.cpp              |   8 ++++----
 src/rangemodel.cpp             |   7 +++++--
 tools/laszippertest.cpp        |  24 ++++++++++++------------
 13 files changed, 52 insertions(+), 44 deletions(-)
diffs (truncated from 368 to 300 lines):
diff -r e815143ce051 -r 16cbedc7335f include/laszip/lasunzipper.hpp
--- a/include/laszip/lasunzipper.hpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/include/laszip/lasunzipper.hpp	Mon Dec 27 12:44:10 2010 -0700
@@ -64,8 +64,8 @@
 class LASunzipper
 public:
-  unsigned int open(FILE* file, unsigned int num_items, const LASitem items[], unsigned int compression=0);
-  unsigned int open(istream& stream, unsigned int num_items, const LASitem items[], unsigned int compression=0);
+  unsigned int open(FILE* file, unsigned int num_items, const LASitem items[], LASzip::CompressionType compression_type);
+  unsigned int open(istream& stream, unsigned int num_items, const LASitem items[], LASzip::CompressionType compression_type);
   bool read(unsigned char * const * point);
   unsigned int close();
diff -r e815143ce051 -r 16cbedc7335f include/laszip/laszip.hpp
--- a/include/laszip/laszip.hpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/include/laszip/laszip.hpp	Mon Dec 27 12:44:10 2010 -0700
@@ -58,11 +58,7 @@
 #define LASZIP_VERSION_MINOR    0
 #define LASZIP_VERSION_REVISION 0
-#define LASZIP_COMPRESSION_NONE       0
-#define LASZIP_COMPRESSION_ARITHMETIC 1
-#define LASZIP_COMPRESSION_RANGE      2
-#define LASZIP_COMPRESSION_DEFAULT    1
 class LASitem
@@ -86,6 +82,15 @@
 class LASzip
 public:
+    enum CompressionType
+        COMPRESSION_NONE       = 0,
+        COMPRESSION_ARITHMETIC = 1,
+        COMPRESSION_RANGE      = 2,
+        COMPRESSION_DEFAULT    = COMPRESSION_ARITHMETIC
+public:
     LASzip();
     ~LASzip();
diff -r e815143ce051 -r 16cbedc7335f include/laszip/laszipper.hpp
--- a/include/laszip/laszipper.hpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/include/laszip/laszipper.hpp	Mon Dec 27 12:44:10 2010 -0700
@@ -64,8 +64,8 @@
 class LASzipper
 public:
-  unsigned int open(FILE* outfile, unsigned int num_items, LASitem items[], unsigned int compression=0);
-  unsigned int open(ostream& outstream, unsigned int num_items, LASitem items[], unsigned int compression=0);
+  unsigned int open(FILE* outfile, unsigned int num_items, LASitem items[], LASzip::CompressionType compression_type);
+  unsigned int open(ostream& outstream, unsigned int num_items, LASitem items[], LASzip::CompressionType compression_type);
   bool write(const unsigned char* const * point);
diff -r e815143ce051 -r 16cbedc7335f src/bytestreamin_file.hpp
--- a/src/bytestreamin_file.hpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/src/bytestreamin_file.hpp	Mon Dec 27 12:44:10 2010 -0700
@@ -109,7 +109,7 @@
   int byte = getc(file);
   if (byte == EOF)
-    fprintf(stderr, "reading EOF\n");
+    //fprintf(stderr, "reading EOF\n");
     byte = 0;
   return (unsigned int)byte;
diff -r e815143ce051 -r 16cbedc7335f src/bytestreamin_istream.hpp
--- a/src/bytestreamin_istream.hpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/src/bytestreamin_istream.hpp	Mon Dec 27 12:44:10 2010 -0700
@@ -111,7 +111,7 @@
   int byte = stream.get();
   if (stream.eof())
     byte = 0;
diff -r e815143ce051 -r 16cbedc7335f src/lasreadpoint.cpp
--- a/src/lasreadpoint.cpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/src/lasreadpoint.cpp	Mon Dec 27 12:44:10 2010 -0700
@@ -63,7 +63,7 @@
   dec = 0;
-BOOL LASreadPoint::setup(U32 num_items, const LASitem* items, U32 compression)
+BOOL LASreadPoint::setup(U32 num_items, const LASitem* items, LASzip::CompressionType compression_type)
   U32 i;
@@ -74,15 +74,15 @@
   // create entropy decoder (if requested)
-  switch (compression)
+  switch (compression_type)
-  case LASZIP_COMPRESSION_NONE:
+  case LASzip::COMPRESSION_NONE:
     dec = 0;
     break;
-  case LASZIP_COMPRESSION_RANGE:
+  case LASzip::COMPRESSION_RANGE:
     dec = new RangeDecoder();
     break;
-  case LASZIP_COMPRESSION_ARITHMETIC:
+  case LASzip::COMPRESSION_ARITHMETIC:
     dec = new ArithmeticDecoder();
     break;
   default:
diff -r e815143ce051 -r 16cbedc7335f src/lasreadpoint.hpp
--- a/src/lasreadpoint.hpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/src/lasreadpoint.hpp	Mon Dec 27 12:44:10 2010 -0700
@@ -63,7 +63,7 @@
   ~LASreadPoint();
   // should only be called *once*
-  BOOL setup(U32 num_items, const LASitem* items, U32 compression=0);
+  BOOL setup(U32 num_items, const LASitem* items, LASzip::CompressionType compression_type);
   BOOL init(ByteStreamIn* instream);
   BOOL read(U8* const * point);
diff -r e815143ce051 -r 16cbedc7335f src/lasunzipper.cpp
--- a/src/lasunzipper.cpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/src/lasunzipper.cpp	Mon Dec 27 12:44:10 2010 -0700
@@ -49,26 +49,26 @@
 #include "bytestreamin_istream.hpp"
 #include "lasreadpoint.hpp"
-unsigned int LASunzipper::open(FILE* infile, unsigned int num_items, const LASitem items[], unsigned int compression)
+unsigned int LASunzipper::open(FILE* infile, unsigned int num_items, const LASitem items[], LASzip::CompressionType compression_type)
   count = 0;
   stream = new ByteStreamInFile(infile);
   if (!stream) return 1;
   reader = new LASreadPoint();
   if (!reader) return 1;
-  if (!reader->setup(num_items, items, compression)) return 1;
+  if (!reader->setup(num_items, items, compression_type)) return 1;
   if (!reader->init(stream)) return 1;
   return 0;
-unsigned int LASunzipper::open(istream& instream, unsigned int num_items, const LASitem items[], unsigned int compression)
+unsigned int LASunzipper::open(istream& instream, unsigned int num_items, const LASitem items[], LASzip::CompressionType compression_type)
   count = 0;
   stream = new ByteStreamInIstream(instream);
   return 0;
diff -r e815143ce051 -r 16cbedc7335f src/laswritepoint.cpp
--- a/src/laswritepoint.cpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/src/laswritepoint.cpp	Mon Dec 27 12:44:10 2010 -0700
@@ -63,7 +63,7 @@
   enc = 0;
-BOOL LASwritePoint::setup(U32 num_items, LASitem* items, U32 compression)
+BOOL LASwritePoint::setup(U32 num_items, LASitem* items, LASzip::CompressionType compression_type)
   U32 i;
@@ -74,15 +74,15 @@
   // create entropy encoder (if requested)
     enc = 0;
     break;
     enc = new RangeEncoder();
     break;
     enc = new ArithmeticEncoder();
     break;
   default:
diff -r e815143ce051 -r 16cbedc7335f src/laswritepoint.hpp
--- a/src/laswritepoint.hpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/src/laswritepoint.hpp	Mon Dec 27 12:44:10 2010 -0700
@@ -63,7 +63,7 @@
   ~LASwritePoint();
-  BOOL setup(U32 num_items, LASitem* items, U32 compression=0);
+  BOOL setup(U32 num_items, LASitem* items, LASzip::CompressionType compression_type);
   BOOL init(ByteStreamOut* outstream);
   BOOL write(const U8 * const * point);
diff -r e815143ce051 -r 16cbedc7335f src/laszipper.cpp
--- a/src/laszipper.cpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/src/laszipper.cpp	Mon Dec 27 12:44:10 2010 -0700
@@ -49,26 +49,26 @@
 #include "bytestreamout_ostream.hpp"
 #include "laswritepoint.hpp"
-unsigned int LASzipper::open(FILE* outfile, unsigned int num_items, LASitem items[], unsigned int compression)
+unsigned int LASzipper::open(FILE* outfile, unsigned int num_items, LASitem items[], LASzip::CompressionType compression_type)
   count = 0;
   stream = new ByteStreamOutFile(outfile);
   writer = new LASwritePoint();
   if (!writer) return 1;
-  if (!writer->setup(num_items, items, compression)) return 1;
+  if (!writer->setup(num_items, items, compression_type)) return 1;
   if (!writer->init(stream)) return 1;
   return 0;
-unsigned int LASzipper::open(ostream& outstream, unsigned int num_items, LASitem items[], unsigned int compression)
+unsigned int LASzipper::open(ostream& outstream, unsigned int num_items, LASitem items[], LASzip::CompressionType compression_type)
   count = 0;
   stream = new ByteStreamOutOstream(outstream);
   return 0;
diff -r e815143ce051 -r 16cbedc7335f src/rangemodel.cpp
--- a/src/rangemodel.cpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/src/rangemodel.cpp	Mon Dec 27 12:44:10 2010 -0700
@@ -48,6 +48,8 @@
 #include <stdio.h>
 #include <stdlib.h>
+#include <stdexcept>
 /* initialisation of model                             */
 /* n   number of symbols in that model                 */
 /* compress  set to 1 on compression, 0 on decompression */
@@ -120,8 +122,9 @@
   if (c!=newf[0])
-    fprintf(stderr,"BUG: rescaling left %d total frequency\n",c);
-    exit(1);
+    //fprintf(stderr,"BUG: rescaling left %d total frequency\n",c);
+    //exit(1);
+    throw std::runtime_error("laszip internal error: RangeModel::dorescale()");
   newf[0] = newf[0]>>1 | 1;
   missing -= newf[0];
diff -r e815143ce051 -r 16cbedc7335f tools/laszippertest.cpp
--- a/tools/laszippertest.cpp	Thu Dec 23 17:24:25 2010 -0800
+++ b/tools/laszippertest.cpp	Mon Dec 27 12:44:10 2010 -0700
@@ -154,7 +154,7 @@
     ostream1 = new ofstream();
     ostream1->open("test1.lax", std::ios::out | std::ios::binary );
 #endif
-    if (laszipper1->open(*ostream1, num_items, items, LASZIP_COMPRESSION_NONE) != 0)
+    if (laszipper1->open(*ostream1, num_items, items, LASzip::COMPRESSION_NONE) != 0)
       fprintf(stderr, "ERROR: could not open laszipper1\n");
       return 0;
@@ -168,7 +168,7 @@
     ostream2 = new ofstream();
     ostream2->open("test2.lax", std::ios::out | std::ios::binary );
 #endif
-    if (laszipper2->open(*ostream2, num_items, items, LASZIP_COMPRESSION_ARITHMETIC) != 0)
+    if (laszipper2->open(*ostream2, num_items, items, LASzip::COMPRESSION_ARITHMETIC) != 0)
       fprintf(stderr, "ERROR: could not open laszipper2\n");
       return 0;
@@ -182,7 +182,7 @@
     ostream3 = new ofstream();
     ostream3->open("test3.lax", std::ios::out | std::ios::binary );
 #endif
-    if (laszipper3->open(*ostream3, num_items, items, LASZIP_COMPRESSION_RANGE) != 0)
+    if (laszipper3->open(*ostream3, num_items, items, LASzip::COMPRESSION_RANGE) != 0)
       fprintf(stderr, "ERROR: could not open laszipper3\n");
       return 0;
@@ -191,21 +191,21 @@
   else
     ofile1 = fopen("test1.lax", "wb");
-    if (!laszipper1->open(ofile1, num_items, items, LASZIP_COMPRESSION_NONE))
+    if (laszipper1->open(ofile1, num_items, items, LASzip::COMPRESSION_NONE) != 0)
More information about the Liblas-commits mailing list
