[Liblas-commits] hg: Fixed indentation of FindSpatialIndex.cmake
macro
liblas-commits at liblas.org
Thu Jan 7 17:35:38 EST 2010
changeset 5928c7842ce3 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=5928c7842ce3
summary: Fixed indentation of FindSpatialIndex.cmake macro
diffstat:
build/cmake/FindSpatialIndex.cmake | 96 +++++++++++++++++++-------------------
1 files changed, 48 insertions(+), 48 deletions(-)
diffs (129 lines):
diff -r b68046c37a6b -r 5928c7842ce3 build/cmake/FindSpatialIndex.cmake
--- a/build/cmake/FindSpatialIndex.cmake Thu Dec 31 13:08:43 2009 -0600
+++ b/build/cmake/FindSpatialIndex.cmake Thu Jan 07 22:35:24 2010 +0000
@@ -5,7 +5,7 @@
# SPATIALINDEX_FOUND = if the library found
# SPATIALINDEX_LIBRARY = full path to the library
# SPATIALINDEX_INCLUDE_DIR = where to find the library headers
-# SPATIALINDEX_VERSION = version of library which was found, e.g. "1.4.0"
+# SPATIALINDEX_VERSION = version of library which was found, e.g. "1.4.0"
# Copyright (c) 2009 Mateusz Loskot <mateusz at loskot.net>
@@ -16,69 +16,69 @@
MESSAGE(STATUS "Searching for SpatialIndex ${SpatialIndex_FIND_VERSION}+ library")
IF(SPATIALINDEX_INCLUDE_DIR)
- # Already in cache, be silent
- SET(SPATIALINDEX_FIND_QUIETLY TRUE)
+ # Already in cache, be silent
+ SET(SPATIALINDEX_FIND_QUIETLY TRUE)
ENDIF()
IF(WIN32)
- SET(OSGEO4W_IMPORT_LIBRARY spatialindex_i)
- IF(DEFINED ENV{OSGEO4W_ROOT})
- SET(OSGEO4W_ROOT_DIR $ENV{OSGEO4W_ROOT})
- MESSAGE(STATUS "Trying OSGeo4W using environment variable OSGEO4W_ROOT=$ENV{OSGEO4W_ROOT}")
- ELSE()
- SET(OSGEO4W_ROOT_DIR c:/OSGeo4W)
- MESSAGE(STATUS "Trying OSGeo4W using default location OSGEO4W_ROOT=${OSGEO4W_ROOT_DIR}")
- ENDIF()
+ SET(OSGEO4W_IMPORT_LIBRARY spatialindex_i)
+ IF(DEFINED ENV{OSGEO4W_ROOT})
+ SET(OSGEO4W_ROOT_DIR $ENV{OSGEO4W_ROOT})
+ MESSAGE(STATUS "Trying OSGeo4W using environment variable OSGEO4W_ROOT=$ENV{OSGEO4W_ROOT}")
+ ELSE()
+ SET(OSGEO4W_ROOT_DIR c:/OSGeo4W)
+ MESSAGE(STATUS "Trying OSGeo4W using default location OSGEO4W_ROOT=${OSGEO4W_ROOT_DIR}")
+ ENDIF()
ENDIF()
FIND_PATH(SPATIALINDEX_INCLUDE_DIR
- NAMES SpatialIndex.h RTree.h
- HINTS
- ${OSGEO4W_ROOT_DIR}/include
- PATHS
- PATH_SUFFIXES spatialindex
- DOC "Path to include directory of SpatialIndex library")
+ NAMES SpatialIndex.h RTree.h
+ HINTS
+ ${OSGEO4W_ROOT_DIR}/include
+ PATHS
+ PATH_SUFFIXES spatialindex
+ DOC "Path to include directory of SpatialIndex library")
SET(SPATIALINDEX_NAMES ${OSGEO4W_IMPORT_LIBRARY} spatialindex)
FIND_LIBRARY(SPATIALINDEX_LIBRARY
- NAMES ${SPATIALINDEX_NAMES}
- PATHS
- ${OSGEO4W_ROOT_DIR}/lib)
+ NAMES ${SPATIALINDEX_NAMES}
+ PATHS ${OSGEO4W_ROOT_DIR}/lib)
IF (SPATIALINDEX_INCLUDE_DIR)
- SET(SPATIALINDEX_VERSION 0)
+ SET(SPATIALINDEX_VERSION 0)
- SET(SPATIALINDEX_VERSION_H "${SPATIALINDEX_INCLUDE_DIR}/Version.h")
- FILE(READ ${SPATIALINDEX_VERSION_H} SPATIALINDEX_VERSION_H_CONTENTS)
+ SET(SPATIALINDEX_VERSION_H "${SPATIALINDEX_INCLUDE_DIR}/Version.h")
+ FILE(READ ${SPATIALINDEX_VERSION_H} SPATIALINDEX_VERSION_H_CONTENTS)
- IF (DEFINED SPATIALINDEX_VERSION_H_CONTENTS)
- STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_MAJOR[ \t]+([0-9]+).*" "\\1" SIDX_VERSION_MAJOR "${SPATIALINDEX_VERSION_H_CONTENTS}")
- STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_MINOR[ \t]+([0-9]+).*" "\\1" SIDX_VERSION_MINOR "${SPATIALINDEX_VERSION_H_CONTENTS}")
- STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_REV[ \t]+([0-9]+).*" "\\1" SIDX_VERSION_REV "${SPATIALINDEX_VERSION_H_CONTENTS}")
+ IF (DEFINED SPATIALINDEX_VERSION_H_CONTENTS)
+ STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_MAJOR[ \t]+([0-9]+).*" "\\1" SIDX_VERSION_MAJOR "${SPATIALINDEX_VERSION_H_CONTENTS}")
+ STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_MINOR[ \t]+([0-9]+).*" "\\1" SIDX_VERSION_MINOR "${SPATIALINDEX_VERSION_H_CONTENTS}")
+ STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_REV[ \t]+([0-9]+).*" "\\1" SIDX_VERSION_REV "${SPATIALINDEX_VERSION_H_CONTENTS}")
- IF(NOT ${SIDX_VERSION_MAJOR} MATCHES "[0-9]+")
- MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_MAJOR!")
- ENDIF()
- IF(NOT ${SIDX_VERSION_MINOR} MATCHES "[0-9]+")
- MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_MINOR!")
- ENDIF()
- IF(NOT ${SIDX_VERSION_REV} MATCHES "[0-9]+")
- MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_REV!")
- ENDIF()
+ IF(NOT ${SIDX_VERSION_MAJOR} MATCHES "[0-9]+")
+ MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_MAJOR!")
+ ENDIF()
+ IF(NOT ${SIDX_VERSION_MINOR} MATCHES "[0-9]+")
+ MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_MINOR!")
+ ENDIF()
+ IF(NOT ${SIDX_VERSION_REV} MATCHES "[0-9]+")
+ MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_REV!")
+ ENDIF()
- SET(SPATIALINDEX_VERSION "${SIDX_VERSION_MAJOR}.${SIDX_VERSION_MINOR}.${SIDX_VERSION_REV}"
- CACHE INTERNAL "The version string for SpatialIndex library")
+ SET(SPATIALINDEX_VERSION "${SIDX_VERSION_MAJOR}.${SIDX_VERSION_MINOR}.${SIDX_VERSION_REV}"
+ CACHE INTERNAL "The version string for SpatialIndex library")
- IF (SPATIALINDEX_VERSION VERSION_EQUAL SpatialIndex_FIND_VERSION OR
- SPATIALINDEX_VERSION VERSION_GREATER SpatialIndex_FIND_VERSION)
- MESSAGE(STATUS "Found SpatialIndex version: ${SPATIALINDEX_VERSION}")
- ELSE()
- MESSAGE(FATAL_ERROR "SpatialIndex version check failed. Version ${SPATIALINDEX_VERSION} was found, at least version ${SpatialIndex_FIND_VERSION} is required")
- ENDIF()
- ELSE()
- MESSAGE(FATAL_ERROR "Failed to open ${SPATIALINDEX_VERSION_H} file")
- ENDIF()
+ IF (SPATIALINDEX_VERSION VERSION_EQUAL SpatialIndex_FIND_VERSION OR
+ SPATIALINDEX_VERSION VERSION_GREATER SpatialIndex_FIND_VERSION)
+ MESSAGE(STATUS "Found SpatialIndex version: ${SPATIALINDEX_VERSION}")
+ ELSE()
+ MESSAGE(FATAL_ERROR "SpatialIndex version check failed. Version ${SPATIALINDEX_VERSION} was found, at least version ${SpatialIndex_FIND_VERSION} is required")
+ ENDIF()
+ ELSE()
+ MESSAGE(FATAL_ERROR "Failed to open ${SPATIALINDEX_VERSION_H} file")
+ ENDIF()
ENDIF()
# Handle the QUIETLY and REQUIRED arguments and set SPATIALINDEX_FOUND to TRUE
More information about the Liblas-commits
