[Liblas-commits] laszip: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jan 12 11:06:01 EST 2010
changeset ac088d1ea74b in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=ac088d1ea74b
summary: add missing stuff so things can build
changeset f77c6eb550d7 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=f77c6eb550d7
summary: fix up compilation issues
diffstat:
 .hgignore       |   66 +++++++++++++++
 INSTALL         |  234 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++
 Makefile.am     |    2 +-
 src/Makefile.am |    2 +-
 4 files changed, 302 insertions(+), 2 deletions(-)
diffs (truncated from 329 to 300 lines):
diff -r e9412e0397c7 -r f77c6eb550d7 .hgignore
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/.hgignore	Tue Jan 12 10:05:53 2010 -0600
@@ -0,0 +1,66 @@
+syntax: glob
+.deps
+.libs
+*.dll
+*.embed.manifest
+*.exe
+*.exp
+*.idb
+*.ilk
+*.intermediate.manifest
+*.la
+*.lib
+*.lo
+*.ncb
+*.o
+*.obj
+*.pdb
+*.pyc
+*.res
+*.suo
+*.swp
+*.bz2
+*.gz
+*.orig
+*.user
+aclocal.m4
+apps/las2las
+apps/las2txt
+apps/lasinfo
+apps/lasmerge
+apps/liblas-config
+apps/ts2las
+apps/txt2las
+apps/las2oci
+apps/las2ogr
+apps/lasindex
+autom4te.cache
+config.guess
+config.log
+config.status
+config.sub
+configure
+depcomp
+install-sh
+libtool
+liblas_test
+ltmain.sh
+missing
+Makefile
+Makefile.in
+build.hobu
+test/data/*.dat
+test/data/*.idx
+python/build/*
+python/dist/*
+python/libLAS.egg-info/*
+src/CMakeFiles
+CMakeFiles
+CMakeCache.txt
+cmake_install.cmake
+src/liblas.a
+Debug
+Release
+.DS_Store
+laszip-config
diff -r e9412e0397c7 -r f77c6eb550d7 INSTALL
+++ b/INSTALL	Tue Jan 12 10:05:53 2010 -0600
@@ -0,0 +1,234 @@
+Installation Instructions
+Copyright (C) 1994, 1995, 1996, 1999, 2000, 2001, 2002, 2004, 2005,
+2006 Free Software Foundation, Inc.
+This file is free documentation; the Free Software Foundation gives
+unlimited permission to copy, distribute and modify it.
+Basic Installation
+Briefly, the shell commands `./configure; make; make install' should
+configure, build, and install this package.  The following
+more-detailed instructions are generic; see the `README' file for
+instructions specific to this package.
+   The `configure' shell script attempts to guess correct values for
+various system-dependent variables used during compilation.  It uses
+those values to create a `Makefile' in each directory of the package.
+It may also create one or more `.h' files containing system-dependent
+definitions.  Finally, it creates a shell script `config.status' that
+you can run in the future to recreate the current configuration, and a
+file `config.log' containing compiler output (useful mainly for
+debugging `configure').
+   It can also use an optional file (typically called `config.cache'
+and enabled with `--cache-file=config.cache' or simply `-C') that saves
+the results of its tests to speed up reconfiguring.  Caching is
+disabled by default to prevent problems with accidental use of stale
+cache files.
+   If you need to do unusual things to compile the package, please try
+to figure out how `configure' could check whether to do them, and mail
+diffs or instructions to the address given in the `README' so they can
+be considered for the next release.  If you are using the cache, and at
+some point `config.cache' contains results you don't want to keep, you
+may remove or edit it.
+   The file `configure.ac' (or `configure.in') is used to create
+`configure' by a program called `autoconf'.  You need `configure.ac' if
+you want to change it or regenerate `configure' using a newer version
+of `autoconf'.
+The simplest way to compile this package is:
+  1. `cd' to the directory containing the package's source code and type
+     `./configure' to configure the package for your system.
+     Running `configure' might take a while.  While running, it prints
+     some messages telling which features it is checking for.
+  2. Type `make' to compile the package.
+  3. Optionally, type `make check' to run any self-tests that come with
+     the package.
+  4. Type `make install' to install the programs and any data files and
+     documentation.
+  5. You can remove the program binaries and object files from the
+     source code directory by typing `make clean'.  To also remove the
+     files that `configure' created (so you can compile the package for
+     a different kind of computer), type `make distclean'.  There is
+     also a `make maintainer-clean' target, but that is intended mainly
+     for the package's developers.  If you use it, you may have to get
+     all sorts of other programs in order to regenerate files that came
+     with the distribution.
+Compilers and Options
+Some systems require unusual options for compilation or linking that the
+`configure' script does not know about.  Run `./configure --help' for
+details on some of the pertinent environment variables.
+   You can give `configure' initial values for configuration parameters
+by setting variables in the command line or in the environment.  Here
+is an example:
+     ./configure CC=c99 CFLAGS=-g LIBS=-lposix
+   *Note Defining Variables::, for more details.
+Compiling For Multiple Architectures
+You can compile the package for more than one kind of computer at the
+same time, by placing the object files for each architecture in their
+own directory.  To do this, you can use GNU `make'.  `cd' to the
+directory where you want the object files and executables to go and run
+the `configure' script.  `configure' automatically checks for the
+source code in the directory that `configure' is in and in `..'.
+   With a non-GNU `make', it is safer to compile the package for one
+architecture at a time in the source code directory.  After you have
+installed the package for one architecture, use `make distclean' before
+reconfiguring for another architecture.
+Installation Names
+By default, `make install' installs the package's commands under
+`/usr/local/bin', include files under `/usr/local/include', etc.  You
+can specify an installation prefix other than `/usr/local' by giving
+`configure' the option `--prefix=PREFIX'.
+   You can specify separate installation prefixes for
+architecture-specific files and architecture-independent files.  If you
+pass the option `--exec-prefix=PREFIX' to `configure', the package uses
+PREFIX as the prefix for installing programs and libraries.
+Documentation and other data files still use the regular prefix.
+   In addition, if you use an unusual directory layout you can give
+options like `--bindir=DIR' to specify different values for particular
+kinds of files.  Run `configure --help' for a list of the directories
+you can set and what kinds of files go in them.
+   If the package supports it, you can cause programs to be installed
+with an extra prefix or suffix on their names by giving `configure' the
+option `--program-prefix=PREFIX' or `--program-suffix=SUFFIX'.
+Optional Features
+Some packages pay attention to `--enable-FEATURE' options to
+`configure', where FEATURE indicates an optional part of the package.
+They may also pay attention to `--with-PACKAGE' options, where PACKAGE
+is something like `gnu-as' or `x' (for the X Window System).  The
+`README' should mention any `--enable-' and `--with-' options that the
+package recognizes.
+   For packages that use the X Window System, `configure' can usually
+find the X include and library files automatically, but if it doesn't,
+you can use the `configure' options `--x-includes=DIR' and
+`--x-libraries=DIR' to specify their locations.
+Specifying the System Type
+There may be some features `configure' cannot figure out automatically,
+but needs to determine by the type of machine the package will run on.
+Usually, assuming the package is built to be run on the _same_
+architectures, `configure' can figure that out, but if it prints a
+message saying it cannot guess the machine type, give it the
+`--build=TYPE' option.  TYPE can either be a short name for the system
+type, such as `sun4', or a canonical name which has the form:
+     CPU-COMPANY-SYSTEM
+where SYSTEM can have one of these forms:
+     OS KERNEL-OS
+   See the file `config.sub' for the possible values of each field.  If
+`config.sub' isn't included in this package, then this package doesn't
+need to know the machine type.
+   If you are _building_ compiler tools for cross-compiling, you should
+use the option `--target=TYPE' to select the type of system they will
+produce code for.
+   If you want to _use_ a cross compiler, that generates code for a
+platform different from the build platform, you should specify the
+"host" platform (i.e., that on which the generated programs will
+eventually be run) with `--host=TYPE'.
+Sharing Defaults
+If you want to set default values for `configure' scripts to share, you
+can create a site shell script called `config.site' that gives default
+values for variables like `CC', `cache_file', and `prefix'.
+`configure' looks for `PREFIX/share/config.site' if it exists, then
+`PREFIX/etc/config.site' if it exists.  Or, you can set the
+`CONFIG_SITE' environment variable to the location of the site script.
+A warning: not all `configure' scripts look for a site script.
+Defining Variables
+Variables not defined in a site shell script can be set in the
+environment passed to `configure'.  However, some packages may run
+configure again during the build, and the customized values of these
+variables may be lost.  In order to avoid this problem, you should set
+them in the `configure' command line, using `VAR=value'.  For example:
+     ./configure CC=/usr/local2/bin/gcc
+causes the specified `gcc' to be used as the C compiler (unless it is
+overridden in the site shell script).
+Unfortunately, this technique does not work for `CONFIG_SHELL' due to
+an Autoconf bug.  Until the bug is fixed you can use this workaround:
+     CONFIG_SHELL=/bin/bash /bin/bash ./configure CONFIG_SHELL=/bin/bash
+`configure' Invocation
+`configure' recognizes the following options to control how it operates.
+`--help'
+`-h'
+     Print a summary of the options to `configure', and exit.
+`--version'
+`-V'
+     Print the version of Autoconf used to generate the `configure'
+     script, and exit.
+`--cache-file=FILE'
+     Enable the cache: use and save the results of the tests in FILE,
+     traditionally `config.cache'.  FILE defaults to `/dev/null' to
+     disable caching.
+`--config-cache'
+`-C'
+     Alias for `--cache-file=config.cache'.
+`--quiet'
+`--silent'
+`-q'
+     Do not print messages saying which checks are being made.  To
+     suppress all normal output, redirect it to `/dev/null' (any error
+     messages will still be shown).
More information about the Liblas-commits mailing list
