[Liblas-commits] ann: add autoconf build
liblas-commits at liblas.org
Tue Jan 12 12:00:46 EST 2010
changeset a7ec72901785 in /Volumes/Data/www/liblas.org/ann
details: http://hg.liblas.organn?cmd=changeset;node=a7ec72901785
summary: add autoconf build
diffstat:
.hgignore | 3 +-
COPYING | 450 ++++++++++++++++++++++++
INSTALL | 234 ++++++++++++
License.txt | 448 ------------------------
Makefile | 783 +++++++++++++++++++++++++++++++++++-------
Makefile.am | 8 +
README | 68 +++
ReadMe.txt | 63 ---
ann-config.in | 53 ++
autogen.sh | 42 ++
configure.ac | 146 ++++++++
include/Makefile.am | 5 +
src/CMakeLists.txt | 16 -
src/Makefile | 942 +++++++++++++++++++++++----------------------------
src/Makefile.am | 27 +
15 files changed, 2114 insertions(+), 1174 deletions(-)
diffs (truncated from 3463 to 300 lines):
diff -r 3aa97457ee4e -r a7ec72901785 .hgignore
--- a/.hgignore Tue Jan 12 10:16:47 2010 -0600
+++ b/.hgignore Tue Jan 12 11:00:33 2010 -0600
@@ -45,4 +45,5 @@
cmake_install.cmake
.DS_Store
Debug
-Release
\ No newline at end of file
+Release
+ann-config
diff -r 3aa97457ee4e -r a7ec72901785 COPYING
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/COPYING Tue Jan 12 11:00:33 2010 -0600
@@ -0,0 +1,450 @@
+The ANN Library (all versions) is provided under the terms and
+conditions of the GNU Lesser General Public Library, which is stated
+below. It can also be found at:
+ http://www.gnu.org/copyleft/lesser.html
+GNU LESSER GENERAL PUBLIC LICENSE
+Version 2.1, February 1999
+Copyright (C) 1991, 1999 Free Software Foundation, Inc.
+59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
+Everyone is permitted to copy and distribute verbatim copies
+of this license document, but changing it is not allowed.
+[This is the first released version of the Lesser GPL. It also counts
+as the successor of the GNU Library Public License, version 2, hence the
+version number 2.1.]
+Preamble
+The licenses for most software are designed to take away your freedom to
+share and change it. By contrast, the GNU General Public Licenses are
+intended to guarantee your freedom to share and change free software--to
+make sure the software is free for all its users.
+This license, the Lesser General Public License, applies to some
+specially designated software packages--typically libraries--of the Free
+Software Foundation and other authors who decide to use it. You can use
+it too, but we suggest you first think carefully about whether this
+license or the ordinary General Public License is the better strategy to
+use in any particular case, based on the explanations below.
+When we speak of free software, we are referring to freedom of use, not
+price. Our General Public Licenses are designed to make sure that you
+have the freedom to distribute copies of free software (and charge for
+this service if you wish); that you receive source code or can get it if
+you want it; that you can change the software and use pieces of it in
+new free programs; and that you are informed that you can do these
+things.
+To protect your rights, we need to make restrictions that forbid
+distributors to deny you these rights or to ask you to surrender these
+rights. These restrictions translate to certain responsibilities for you
+if you distribute copies of the library or if you modify it.
+For example, if you distribute copies of the library, whether gratis or
+for a fee, you must give the recipients all the rights that we gave you.
+You must make sure that they, too, receive or can get the source code.
+If you link other code with the library, you must provide complete
+object files to the recipients, so that they can relink them with the
+library after making changes to the library and recompiling it. And you
+must show them these terms so they know their rights.
+We protect your rights with a two-step method: (1) we copyright the
+library, and (2) we offer you this license, which gives you legal
+permission to copy, distribute and/or modify the library.
+To protect each distributor, we want to make it very clear that there is
+no warranty for the free library. Also, if the library is modified by
+someone else and passed on, the recipients should know that what they
+have is not the original version, so that the original author's
+reputation will not be affected by problems that might be introduced by
+others.
+Finally, software patents pose a constant threat to the existence of any
+free program. We wish to make sure that a company cannot effectively
+restrict the users of a free program by obtaining a restrictive license
+from a patent holder. Therefore, we insist that any patent license
+obtained for a version of the library must be consistent with the full
+freedom of use specified in this license.
+Most GNU software, including some libraries, is covered by the ordinary
+GNU General Public License. This license, the GNU Lesser General Public
+License, applies to certain designated libraries, and is quite different
+from the ordinary General Public License. We use this license for
+certain libraries in order to permit linking those libraries into
+non-free programs.
+When a program is linked with a library, whether statically or using a
+shared library, the combination of the two is legally speaking a
+combined work, a derivative of the original library. The ordinary
+General Public License therefore permits such linking only if the entire
+combination fits its criteria of freedom. The Lesser General Public
+License permits more lax criteria for linking other code with the
+library.
+We call this license the "Lesser" General Public License because it does
+Less to protect the user's freedom than the ordinary General Public
+License. It also provides other free software developers Less of an
+advantage over competing non-free programs. These disadvantages are the
+reason we use the ordinary General Public License for many libraries.
+However, the Lesser license provides advantages in certain special
+circumstances.
+For example, on rare occasions, there may be a special need to encourage
+the widest possible use of a certain library, so that it becomes a
+de-facto standard. To achieve this, non-free programs must be allowed to
+use the library. A more frequent case is that a free library does the
+same job as widely used non-free libraries. In this case, there is
+little to gain by limiting the free library to free software only, so we
+use the Lesser General Public License.
+In other cases, permission to use a particular library in non-free
+programs enables a greater number of people to use a large body of free
+software. For example, permission to use the GNU C Library in non-free
+programs enables many more people to use the whole GNU operating system,
+as well as its variant, the GNU/Linux operating system.
+Although the Lesser General Public License is Less protective of the
+users' freedom, it does ensure that the user of a program that is linked
+with the Library has the freedom and the wherewithal to run that program
+using a modified version of the Library.
+The precise terms and conditions for copying, distribution and
+modification follow. Pay close attention to the difference between a
+"work based on the library" and a "work that uses the library". The
+former contains code derived from the library, whereas the latter must
+be combined with the library in order to run.
+TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
+0. This License Agreement applies to any software library or other
+program which contains a notice placed by the copyright holder or other
+authorized party saying it may be distributed under the terms of this
+Lesser General Public License (also called "this License"). Each
+licensee is addressed as "you".
+A "library" means a collection of software functions and/or data
+prepared so as to be conveniently linked with application programs
+(which use some of those functions and data) to form executables.
+The "Library", below, refers to any such software library or work which
+has been distributed under these terms. A "work based on the Library"
+means either the Library or any derivative work under copyright law:
+that is to say, a work containing the Library or a portion of it, either
+verbatim or with modifications and/or translated straightforwardly into
+another language. (Hereinafter, translation is included without
+limitation in the term "modification".)
+"Source code" for a work means the preferred form of the work for making
+modifications to it. For a library, complete source code means all the
+source code for all modules it contains, plus any associated interface
+definition files, plus the scripts used to control compilation and
+installation of the library.
+Activities other than copying, distribution and modification are not
+covered by this License; they are outside its scope. The act of running
+a program using the Library is not restricted, and output from such a
+program is covered only if its contents constitute a work based on the
+Library (independent of the use of the Library in a tool for writing
+it). Whether that is true depends on what the Library does and what the
+program that uses the Library does.
+1. You may copy and distribute verbatim copies of the Library's complete
+source code as you receive it, in any medium, provided that you
+conspicuously and appropriately publish on each copy an appropriate
+copyright notice and disclaimer of warranty; keep intact all the notices
+that refer to this License and to the absence of any warranty; and
+distribute a copy of this License along with the Library.
+You may charge a fee for the physical act of transferring a copy, and
+you may at your option offer warranty protection in exchange for a fee.
+2. You may modify your copy or copies of the Library or any portion of
+it, thus forming a work based on the Library, and copy and distribute
+such modifications or work under the terms of Section 1 above, provided
+that you also meet all of these conditions:
+ a) The modified work must itself be a software library.
+ b) You must cause the files modified to carry prominent notices
+ stating that you changed the files and the date of any change.
+ c) You must cause the whole of the work to be licensed at no
+ charge to all third parties under the terms of this License.
+ d) If a facility in the modified Library refers to a function or a
+ table of data to be supplied by an application program that uses
+ the facility, other than as an argument passed when the facility
+ is invoked, then you must make a good faith effort to ensure that,
+ in the event an application does not supply such function or
+ table, the facility still operates, and performs whatever part of
+ its purpose remains meaningful.
+ (For example, a function in a library to compute square roots has
+a purpose that is entirely well-defined independent of the application.
+Therefore, Subsection 2d requires that any application-supplied function
+or table used by this function must be optional: if the application does
+not supply it, the square root function must still compute square
+roots.)
+ These requirements apply to the modified work as a whole. If
+identifiable sections of that work are not derived from the Library, and
+can be reasonably considered independent and separate works in
+themselves, then this License, and its terms, do not apply to those
+sections when you distribute them as separate works. But when you
+distribute the same sections as part of a whole which is a work based on
+the Library, the distribution of the whole must be on the terms of this
+License, whose permissions for other licensees extend to the entire
+whole, and thus to each and every part regardless of who wrote it.
+ Thus, it is not the intent of this section to claim rights or
+contest your rights to work written entirely by you; rather, the intent
+is to exercise the right to control the distribution of derivative or
+collective works based on the Library.
+ In addition, mere aggregation of another work not based on the
+Library with the Library (or with a work based on the Library) on a
+volume of a storage or distribution medium does not bring the other work
+under the scope of this License.
+3. You may opt to apply the terms of the ordinary GNU General Public
+License instead of this License to a given copy of the Library. To do
+this, you must alter all the notices that refer to this License, so that
+they refer to the ordinary GNU General Public License, version 2,
+instead of to this License. (If a newer version than version 2 of the
+ordinary GNU General Public License has appeared, then you can specify
+that version instead if you wish.) Do not make any other change in these
+notices.
+Once this change is made in a given copy, it is irreversible for that
+copy, so the ordinary GNU General Public License applies to all
+subsequent copies and derivative works made from that copy.
+This option is useful when you wish to copy part of the code of the
+Library into a program that is not a library.
+4. You may copy and distribute the Library (or a portion or derivative
+of it, under Section 2) in object code or executable form under the
+terms of Sections 1 and 2 above provided that you accompany it with the
+complete corresponding machine-readable source code, which must be
+distributed under the terms of Sections 1 and 2 above on a medium
+customarily used for software interchange.
+If distribution of object code is made by offering access to copy from a
+designated place, then offering equivalent access to copy the source
+code from the same place satisfies the requirement to distribute the
+source code, even though third parties are not compelled to copy the
+source along with the object code.
+5. A program that contains no derivative of any portion of the Library,
+but is designed to work with the Library by being compiled or linked
+with it, is called a "work that uses the Library". Such a work, in
+isolation, is not a derivative work of the Library, and therefore falls
+outside the scope of this License.
+However, linking a "work that uses the Library" with the Library creates
+an executable that is a derivative of the Library (because it contains
+portions of the Library), rather than a "work that uses the library".
+The executable is therefore covered by this License. Section 6 states
+terms for distribution of such executables.
+When a "work that uses the Library" uses material from a header file
+that is part of the Library, the object code for the work may be a
+derivative work of the Library even though the source code is not.
+Whether this is true is especially significant if the work can be linked
+without the Library, or if the work is itself a library. The threshold
+for this to be true is not precisely defined by law.
+If such an object file uses only numerical parameters, data structure
+layouts and accessors, and small macros and small inline functions (ten
+lines or less in length), then the use of the object file is
+unrestricted, regardless of whether it is legally a derivative work.
+(Executables containing this object code plus portions of the Library
+will still fall under Section 6.)
+Otherwise, if the work is a derivative of the Library, you may
+distribute the object code for the work under the terms of Section 6.
+Any executables containing that work also fall under Section 6, whether
+or not they are linked directly with the Library itself.
+6. As an exception to the Sections above, you may also combine or link a
+"work that uses the Library" with the Library to produce a work
+containing portions of the Library, and distribute that work under terms
+of your choice, provided that the terms permit modification of the work
+for the customer's own use and reverse engineering for debugging such
+modifications.
+You must give prominent notice with each copy of the work that the
+Library is used in it and that the Library and its use are covered by
+this License. You must supply a copy of this License. If the work during
+execution displays copyright notices, you must include the copyright
+notice for the Library among them, as well as a reference directing the
More information about the Liblas-commits
