[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Wed Jan 13 11:21:27 EST 2010
changeset 88420b95ebdc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=88420b95ebdc
summary: merge latest README
changeset 0e87c536350f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0e87c536350f
summary: fix #161 - guid temporaries in C API
diffstat:
README | 30 ++++++++++++++++++------------
src/las_c_api.cpp | 4 ++--
2 files changed, 20 insertions(+), 14 deletions(-)
diffs (98 lines):
diff -r 9213c9acea54 -r 0e87c536350f README
--- a/README Fri Oct 02 12:49:20 2009 -0500
+++ b/README Wed Jan 13 10:17:04 2010 -0600
@@ -70,6 +70,7 @@
* `LAS 1.2 Format Standard`_ (2008-09-02)
* `LAS 1.1 Format Standard`_ (2005-05-07)
* `LAS 1.0 Format Standard`_ (2003-05-09)
+* `LAS permutation matrix`_
License
@@ -103,7 +104,9 @@
Linked against a 1.2.5+ version of `libgeotiff`_, you can set and get the spatial reference
systems of LAS files using simple `proj.4`_ coordinate system definitions.
Alternatively, with libLAS 1.2, you can link against `GDAL`_ to be able to
-manipulate spatial references using WKT.
+manipulate spatial references using WKT. The current development version of
+libLAS can be used in combination with `GDAL`_ 1.7 to support `vertical coordinate systems`_
+as well.
Simple Variable Length Record Abstraction
@@ -144,14 +147,15 @@
`LAStools`_ pioneering implementation of the ASPRS LAS standard that made
development of the libLAS library possible.
-Subversion Tree
+Mercurial Repository Tree
-The SVN repository URL is available at http://liblas.org/svn
+The Mercurial repository for libLAS is located at http://hg.liblas.org/main
+You can obtain a copy of the active source code by issuing the following::
- svn checkout http://liblas.org/svn/trunk/
+ hg clone http://hg.liblas.org/main
Information about Trac
@@ -187,6 +191,7 @@
.. _`LAS 1.2 Format Standard`: http://liblas.org/raw-attachment/wiki/WikiStart/asprs_las_format_v12.pdf
.. _`LAS 1.1 Format Standard`: http://liblas.org/raw-attachment/wiki/WikiStart/asprs_las_format_v11.pdf
.. _`LAS 1.0 Format Standard`: http://liblas.org/raw-attachment/wiki/WikiStart/asprs_las_format_v10.pdf
+.. _`LAS permutation matrix`: http://liblas.org/raw-attachment/wiki/WikiStart/LAS-1.0-1.3-feature-matrix.pdf
.. _`ASPRS Standards Committee`: http://www.asprs.org/society/committees/standards/lidar_exchange_format.html
.. _`Howard Butler`: http://hobu.biz
.. _`Mateusz Loskot`: http://mateusz.loskot.net
@@ -198,12 +203,12 @@
.. _`Software`: http://liblas.org/wiki/Software
.. _`Resources`: http://liblas.org/wiki/Resources
.. _`License`: http://liblas.org/wiki/License
-.. _`las2las`: http://liblas.org/browser/trunk/doc/las2las.txt
-.. _`las2txt`: http://liblas.org/browser/trunk/doc/las2txt.txt
-.. _`lasinfo`: http://liblas.org/browser/trunk/doc/lasinfo.txt
-.. _`lasmerge`: http://liblas.org/browser/trunk/doc/lasmerge.txt
-.. _`txt2las`: http://liblas.org/browser/trunk/doc/txt2las.txt
-.. _`las2ogr`: http://liblas.org/browser/trunk/doc/las2ogr.txt
+.. _`las2las`: http://liblas.org/browser/doc/las2las.txt
+.. _`las2txt`: http://liblas.org/browser/doc/las2txt.txt
+.. _`lasinfo`: http://liblas.org/browser/doc/lasinfo.txt
+.. _`lasmerge`: http://liblas.org/browser/doc/lasmerge.txt
+.. _`txt2las`: http://liblas.org/browser/doc/txt2las.txt
+.. _`las2ogr`: http://liblas.org/browser/doc/las2ogr.txt
.. _`Freenode`: http://freenode.net
.. _`Library Design`: http://liblas.org/wiki/LibraryDesign
.. _`FOSS4G 2008`: http://liblas.org/raw-attachment/wiki/WikiStart/liblas_foss4g_2008.pdf
@@ -217,4 +222,5 @@
.. _`OSGeo4W`: http://wiki.osgeo.org/wiki/OSGeo_Win32_Installer
.. _`dotnetLibLAS API`: http://liblas.org/wiki/dotnetapi
-.. _`ASPRS Workshop Demo`: http://liblas.org/raw-attachment/wiki/WikiStart/ASPRS-Workshop-NOAA-Demo.pdf
\ No newline at end of file
+.. _`ASPRS Workshop Demo`: http://liblas.org/raw-attachment/wiki/WikiStart/ASPRS-Workshop-NOAA-Demo.pdf
+.. _`vertical coordinate systems`: http://liblas.org/wiki/VerticalCS
diff -r 9213c9acea54 -r 0e87c536350f src/las_c_api.cpp
--- a/src/las_c_api.cpp Fri Oct 02 12:49:20 2009 -0500
+++ b/src/las_c_api.cpp Wed Jan 13 10:17:04 2010 -0600
@@ -745,7 +745,7 @@
try {
liblas::guid id;
- id = liblas::guid::guid(value);
+ id = liblas::guid(value);
((LASHeader*) hHeader)->SetProjectId(id);
} catch (std::exception const& e)
@@ -1542,7 +1542,7 @@
VALIDATE_LAS_POINTER1(string, "LASGuid_CreateFromString", NULL);
liblas::guid id;
try {
- id = liblas::guid::guid(string);
+ id = liblas::guid(string);
return (LASGuidH) new liblas::guid(id);
catch (std::exception const& e) {
More information about the Liblas-commits
