[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org
Wed Jan 13 19:26:35 EST 2010
changeset 1a9a7ae688c0 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1a9a7ae688c0
summary: Updated documentation in Doxygen comments for LASReader and LASWriter.
changeset a59a55c07cd8 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a59a55c07cd8
summary: It is supposed to be update only in LASReader and LASWriter documentation but looks like big merge.
changeset a87ed509c137 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a87ed509c137
summary: Merged two dummy commits testing server connection
diffstat:
.hgignore | 1 +
CMakeLists.txt | 17 +-
README | 7 +-
apps/CMakeLists.txt | 23 +-
apps/las2las.c | 86 +++++++++++-
apps/lascommon.c | 2 +-
autogen.sh | 3 +-
build/cmake/FindGeoTIFF.cmake | 78 +++++++---
build/cmake/FindOracle.cmake | 77 ++++++++++
build/cmake/FindSpatialIndex.cmake | 96 ++++++------
include/liblas/capi/liblas.h | 6 +-
include/liblas/lasreader.hpp | 5 +-
include/liblas/lasspatialreference.hpp | 31 ++++-
include/liblas/laswriter.hpp | 25 ++-
python/liblas/core.py | 9 +
python/liblas/srs.py | 11 +-
python/tests/File.txt | 36 ++--
python/tests/SRS-GDAL.txt | 12 +-
src/CMakeLists.txt | 26 +-
src/gt_wkt_srs.cpp | 234 +++++++++++++++++++++++++++++++-
src/las_c_api.cpp | 36 ++++-
src/lasheader.cpp | 2 +-
src/lasspatialreference.cpp | 77 ++++++++++-
test/data/srs_vertcs.las | 0
test/unit/laspoint_test.cpp | 10 +-
test/unit/lasreader_test.cpp | 2 +-
test/unit/laswriter_test.cpp | 4 +-
27 files changed, 751 insertions(+), 165 deletions(-)
diffs (truncated from 1598 to 300 lines):
diff -r 008dd83b4d5d -r a87ed509c137 .hgignore
--- a/.hgignore Thu Dec 31 03:03:19 2009 +0000
+++ b/.hgignore Thu Jan 14 00:26:14 2010 +0000
@@ -62,3 +62,4 @@
src/liblas.a
Debug
Release
+.DS_Store
diff -r 008dd83b4d5d -r a87ed509c137 CMakeLists.txt
--- a/CMakeLists.txt Thu Dec 31 03:03:19 2009 +0000
+++ b/CMakeLists.txt Thu Jan 14 00:26:14 2010 +0000
@@ -149,8 +149,8 @@
INCLUDE_DIRECTORIES(${GEOTIFF_INCLUDE_DIR})
ADD_DEFINITIONS(-DHAVE_LIBGEOTIFF=1)
ENDIF()
- ENDIF(GEOTIFF_FOUND)
-ENDIF(WITH_GEOTIFF)
+ ENDIF()
+ENDIF()
# GDAL/OGR support - optional, default=OFF
SET(WITH_GDAL FALSE CACHE BOOL "Choose if GDAL support should be built")
@@ -169,7 +169,7 @@
CHECK_FUNCTION_EXISTS(OSRSetEquirectangular2 HAVE_OSRSETEQUIRECTANGULAR2)
IF(NOT HAVE_OSRSETEQUIRECTANGULAR2)
- # Reset to NOT found for GDAL/OGR
+ # Reset to NOT found for GDAL/OGR
SET(GDAL_FOUND)
MESSAGE(FATAL_ERROR "GDAL support requires GDAL 1.6.0 or newer")
ELSE()
@@ -195,7 +195,16 @@
ENDIF()
# Oracle support - optional, default=OFF
-# TODO
+SET(WITH_ORACLE FALSE CACHE BOOL "Choose if Oracle support should be built")
+IF(WITH_ORACLE)
+ FIND_PACKAGE(Oracle)
+ IF(ORACLE_FOUND)
+ INCLUDE_DIRECTORIES(${ORACLE_INCLUDE_DIR})
+ ADD_DEFINITIONS(-DHAVE_ORACLE=1)
+ ENDIF()
+ENDIF()
# Installation settings
diff -r 008dd83b4d5d -r a87ed509c137 README
--- a/README Thu Dec 31 03:03:19 2009 +0000
+++ b/README Thu Jan 14 00:26:14 2010 +0000
@@ -1,4 +1,4 @@
libLAS - LAS 1.0/1.1/1.2 ASPRS LiDAR data translation toolset
@@ -104,7 +104,9 @@
Linked against a 1.2.5+ version of `libgeotiff`_, you can set and get the spatial reference
systems of LAS files using simple `proj.4`_ coordinate system definitions.
Alternatively, with libLAS 1.2, you can link against `GDAL`_ to be able to
-manipulate spatial references using WKT.
+manipulate spatial references using WKT. The current development version of
+libLAS can be used in combination with `GDAL`_ 1.7 to support `vertical coordinate systems`_
+as well.
Simple Variable Length Record Abstraction
@@ -221,3 +223,4 @@
.. _`dotnetLibLAS API`: http://liblas.org/wiki/dotnetapi
.. _`FOSS4G 2008`: http://liblas.org/raw-attachment/wiki/WikiStart/liblas_foss4g_2008.pdf
.. _`ASPRS Workshop Demo`: http://liblas.org/raw-attachment/wiki/WikiStart/ASPRS-Workshop-NOAA-Demo.pdf
+.. _`vertical coordinate systems`: http://liblas.org/wiki/VerticalCS
diff -r 008dd83b4d5d -r a87ed509c137 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Thu Dec 31 03:03:19 2009 +0000
+++ b/apps/CMakeLists.txt Thu Jan 14 00:26:14 2010 +0000
@@ -29,7 +29,7 @@
SET(LASINDEX lasindex)
ENDIF()
-IF(OCI_FOUND)
+IF(ORACLE_FOUND AND GDAL_FOUND)
SET(LAS2OCI las2oci)
ENDIF()
@@ -56,63 +56,64 @@
SET(APPS_CPP_DEPENDENCIES
${LIBLAS_LIB_NAME}
+ ${ZLIB_LIBRARY}
${GEOTIFF_LIBRARY}
${GDAL_LIBRARY}
${SPATIALINDEX_LIBRARY}
- ${ZLIB_LIBRARY})
+ ${ORACLE_LIBRARY})
# Build lasinfo
IF(LASINFO)
SET(LASINFO_SRC lascommon.c ${LASINFO}.c)
ADD_EXECUTABLE(${LASINFO} ${LASINFO_SRC})
TARGET_LINK_LIBRARIES(${LASINFO} ${LIBLAS_C_LIB_NAME})
-ENDIF(LASINFO)
+ENDIF()
# Build las2las
IF(LAS2LAS)
SET(LAS2LAS_SRC lascommon.c ${LAS2LAS}.c)
ADD_EXECUTABLE(${LAS2LAS} ${LAS2LAS_SRC})
TARGET_LINK_LIBRARIES(${LAS2LAS} ${LIBLAS_C_LIB_NAME})
-ENDIF(LAS2LAS)
+ENDIF()
# Build las2txt
IF(LAS2TXT)
SET(LAS2TXT_SRC lascommon.c ${LAS2TXT}.c)
ADD_EXECUTABLE(${LAS2TXT} ${LAS2TXT_SRC})
TARGET_LINK_LIBRARIES(${LAS2TXT} ${LIBLAS_C_LIB_NAME})
-ENDIF(LAS2TXT)
+ENDIF()
# Build txt2las
IF(TXT2LAS)
SET(TXT2LAS_SRC lascommon.c ${TXT2LAS}.c)
ADD_EXECUTABLE(${TXT2LAS} ${TXT2LAS_SRC})
TARGET_LINK_LIBRARIES(${TXT2LAS} ${LIBLAS_C_LIB_NAME})
-ENDIF(TXT2LAS)
+ENDIF()
# Build lasmerge
IF(LASMERGE)
SET(LASMERGE_SRC lascommon.c ${LASMERGE}.c)
ADD_EXECUTABLE(${LASMERGE} ${LASMERGE_SRC})
TARGET_LINK_LIBRARIES(${LASMERGE} ${LIBLAS_C_LIB_NAME})
-ENDIF(LASMERGE)
+ENDIF()
# Build lasindex
IF(LASINDEX)
ADD_EXECUTABLE(${LASINDEX} lasindex.cpp)
TARGET_LINK_LIBRARIES(${LASINDEX} ${APPS_CPP_DEPENDENCIES})
-ENDIF(LASINDEX)
+ENDIF()
# Build las2ogr
IF(LAS2OGR)
ADD_EXECUTABLE(${LAS2OGR} las2ogr.cpp)
TARGET_LINK_LIBRARIES(${LAS2OGR} ${APPS_CPP_DEPENDENCIES})
-ENDIF(LAS2OGR)
+ENDIF()
# Build las2oci
IF(LAS2OCI)
ADD_EXECUTABLE(${LAS2OCI} las2oci.cpp)
- TARGET_LINK_LIBRARIES(${LAS2CI} ${APPS_CPP_DEPENDENCIES})
-ENDIF(LAS2OCI)
+ TARGET_LINK_LIBRARIES(${LAS2OCI} ${APPS_CPP_DEPENDENCIES})
+ENDIF()
# Targets installation
diff -r 008dd83b4d5d -r a87ed509c137 apps/las2las.c
--- a/apps/las2las.c Thu Dec 31 03:03:19 2009 +0000
+++ b/apps/las2las.c Thu Jan 14 00:26:14 2010 +0000
@@ -140,6 +140,8 @@
LASPointH surviving_point_max = NULL;
double surviving_gps_time_min;
double surviving_gps_time_max;
+ int verticalCSType = -1, verticalDatum = -1, verticalUnits = 9001;
+ const char *verticalCitation = "";
int clipped = 0;
int eliminated_return = 0;
@@ -336,6 +338,44 @@
do_reprojection = TRUE;
+ else if ( strcmp(argv[i],"--a_srs") == 0 ||
+ strcmp(argv[i],"-a_srs") == 0
+ ++i;
+ if (LAS_IsGDALEnabled()) {
+ out_srs = LASSRS_Create();
+ ret = LASSRS_SetFromUserInput(out_srs, argv[i]);
+ if (ret) {
+ LASError_Print("Unable to import output SRS");
+ exit(1);
+ else if ( strcmp(argv[i],"--a_vertcs") == 0 ||
+ strcmp(argv[i],"-a_vertcs") == 0
+ ++i;
+ verticalCSType = atoi(argv[i]);
+ ++i;
+ if( i < argc && argv[i][0] != '-' )
+ verticalCitation = argv[i];
+ ++i;
+ verticalDatum = atoi(argv[i]);
+ ++i;
+ verticalUnits = atoi(argv[i]);
+ ++i;
else if ( strcmp(argv[i],"--scale") == 0 ||
strcmp(argv[i],"-scale") == 0
@@ -627,7 +667,12 @@
fprintf(stderr,
"thinned: %d\n",
thinned);
+ if (surviving_number_of_point_records == 0) {
+ fprintf(stderr, "All points were eliminated!\n");
+ exit(0);
LASReader_Destroy(reader);
LASHeader_Destroy(header);
@@ -811,6 +856,22 @@
LASHeader_SetDataOffset(surviving_header, LASHeader_GetDataOffset(surviving_header)+abs(header_pad));
+ /* Do we have vertical cs info to set? */
+ if( verticalCSType > 0 )
+ if( out_srs == NULL )
+ out_srs = LASHeader_GetSRS(surviving_header);
+ LASSRS_SetVerticalCS( out_srs,
+ verticalCSType,
+ verticalCitation,
+ verticalDatum,
+ verticalUnits );
if (do_reprojection) {
if (verbose) {
proj4_text = LASSRS_GetProj4(out_srs);
@@ -819,14 +880,20 @@
free(proj4_text);
- /* keep around the header's SRS if we don't have on set by the user */
+ /* keep around the header's SRS if we don't have one set by the user */
if (in_srs == NULL) {
in_srs = LASHeader_GetSRS(surviving_header);
LASHeader_SetSRS(surviving_header, out_srs);
+ /* Are we just assigning an override SRS? (-a_srs) */
+ else if( out_srs != NULL )
+ LASHeader_SetSRS(surviving_header, out_srs);
if (verbose) {
fprintf(stderr,
"second pass reading %d and writing %d points ...\n",
@@ -974,8 +1041,11 @@
LASHeader_Destroy(surviving_header);
- LASPoint_Destroy(surviving_point_max);
- LASPoint_Destroy(surviving_point_min);
+ if (surviving_point_max != NULL)
+ LASPoint_Destroy(surviving_point_max);
+ if (surviving_point_min != NULL)
+ LASPoint_Destroy(surviving_point_min);
reader = LASReader_Create(file_name_out);
if (!reader) {
@@ -997,8 +1067,10 @@
repair_header(stderr, header, summary) ;
if (summary != NULL) {
- LASPoint_Destroy(summary->pmin);
- LASPoint_Destroy(summary->pmax);
+ if (summary->pmin != NULL)
+ LASPoint_Destroy(summary->pmin);
More information about the Liblas-commits
