[Liblas-commits] hg: add support for ellipsoid height datums,
datum.csv, vd codes
liblas-commits at liblas.org
Mon Jan 18 23:27:12 EST 2010
changeset d4ebd0716d8a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d4ebd0716d8a
summary: add support for ellipsoid height datums, datum.csv, vd codes
diffstat:
src/gt_wkt_srs.cpp | 45 +++++++++++++++++++++++++++++++++++++--------
1 files changed, 37 insertions(+), 8 deletions(-)
diffs (103 lines):
diff -r c7e479dfdef7 -r d4ebd0716d8a src/gt_wkt_srs.cpp
--- a/src/gt_wkt_srs.cpp Mon Jan 18 14:17:20 2010 -0600
+++ b/src/gt_wkt_srs.cpp Mon Jan 18 23:27:11 2010 -0500
@@ -1,5 +1,5 @@
- * $Id: gt_wkt_srs.cpp 18490 2010-01-09 05:44:49Z warmerdam $
+ * $Id: gt_wkt_srs.cpp 18562 2010-01-16 04:56:05Z warmerdam $
* Project: GeoTIFF Driver
* Purpose: Implements translation between GeoTIFF normalized projection
@@ -42,6 +42,8 @@
#include "xtiffio.h"
#include "cpl_multiproc.h"
+CPL_CVSID("$Id: gt_wkt_srs.cpp 18562 2010-01-16 04:56:05Z warmerdam $")
CPL_C_START
void GTiffOneTimeInit();
int CPL_DLL VSIFCloseL( FILE * );
@@ -178,11 +180,11 @@
/* For example:
- GTCitationGeoKey (Ascii,215): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 18490 $ $Date: 2010-01-09 00:44:49 -0500 (Sat, 09 Jan 2010) $\nProjection Name = UTM\nUnits = meters\nGeoTIFF Units = meters"
+ GTCitationGeoKey (Ascii,215): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 18562 $ $Date: 2010-01-15 23:56:05 -0500 (Fri, 15 Jan 2010) $\nProjection Name = UTM\nUnits = meters\nGeoTIFF Units = meters"
- GeogCitationGeoKey (Ascii,267): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 18490 $ $Date: 2010-01-09 00:44:49 -0500 (Sat, 09 Jan 2010) $\nUnable to match Ellipsoid (Datum) to a GeographicTypeGeoKey value\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
+ GeogCitationGeoKey (Ascii,267): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 18562 $ $Date: 2010-01-15 23:56:05 -0500 (Fri, 15 Jan 2010) $\nUnable to match Ellipsoid (Datum) to a GeographicTypeGeoKey value\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
- PCSCitationGeoKey (Ascii,214): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 18490 $ $Date: 2010-01-09 00:44:49 -0500 (Sat, 09 Jan 2010) $\nUTM Zone 10N\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
+ PCSCitationGeoKey (Ascii,214): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 18562 $ $Date: 2010-01-15 23:56:05 -0500 (Fri, 15 Jan 2010) $\nUTM Zone 10N\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
@@ -681,6 +683,20 @@
+/* Somewhat similarly, codes 5001 to 5033 were treated as */
+/* vertical coordinate systems based on ellipsoidal heights. */
+/* We use the corresponding 2d geodetic datum as the vertical */
+/* datum and clear the vertical coordinate system code since */
+/* there isn't one in epsg. */
+ if( (verticalCSType >= 5001 && verticalCSType <= 5033)
+ && verticalDatum == -1 )
+ verticalDatum = verticalCSType+1000;
+ verticalCSType = -1;
/* Promote to being a compound coordinate system. */
OGR_SRSNode *poOldRoot = oSRS.GetRoot()->Clone();
@@ -714,7 +730,7 @@
"coord_ref_sys_code",
szSearchKey, CC_Integer,
"coord_ref_sys_name" );
- if( pszValue != NULL )
+ if( pszValue != NULL && *pszValue != '\0' )
strncpy( citation, pszValue, sizeof(citation) );
@@ -746,22 +762,35 @@
/* Setup the vertical datum. */
const char *pszVDatumName = "unknown";
+ const char *pszVDatumType = "2005"; // CS_VD_GeoidModelDerived
if( verticalDatum > 0 && verticalDatum != KvUserDefined )
- pszFilename = CSVFilename( "gdal_datum.csv" );
+ pszFilename = CSVFilename( "datum.csv" );
+ if( EQUAL(pszFilename,"datum.csv") )
+ pszFilename = CSVFilename( "gdal_datum.csv" );
sprintf( szSearchKey, "%d", verticalDatum );
pszValue = CSVGetField( pszFilename,
"DATUM_CODE", szSearchKey, CC_Integer,
"DATUM_NAME" );
pszVDatumName = pszValue;
+ pszValue = CSVGetField( pszFilename,
+ "DATUM_CODE", szSearchKey, CC_Integer,
+ "DATUM_TYPE" );
+ if( pszValue != NULL && EQUALN(pszValue,"geodetic",8) )
+ pszVDatumType = "2002"; // CS_VD_Ellipsoidal
+ // We unfortunately don't know how to identify other
+ // vertical datum types, particularly orthometric (2001).
oSRS.SetNode( "COMPD_CS|VERT_CS|VERT_DATUM", pszVDatumName );
oSRS.GetAttrNode( "COMPD_CS|VERT_CS|VERT_DATUM" )
- ->AddChild( new OGR_SRSNode( "2005" ) );
+ ->AddChild( new OGR_SRSNode( pszVDatumType ) );
oSRS.SetAuthority( "COMPD_CS|VERT_CS|VERT_DATUM", "EPSG",
verticalDatum );
More information about the Liblas-commits
