[Liblas-commits] laszip: remove extraneous ;
liblas-commits at liblas.org
Tue Jan 19 12:49:51 EST 2010
changeset ba3b839989fd in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=ba3b839989fd
summary: remove extraneous ;
diffstat:
src/arithmeticmodel.cpp | 100 ++++++++++++++++++++++++------------------------
1 files changed, 50 insertions(+), 50 deletions(-)
diffs (111 lines):
diff -r 64cb2e788e39 -r ba3b839989fd src/arithmeticmodel.cpp
--- a/src/arithmeticmodel.cpp Tue Jan 19 00:42:10 2010 -0500
+++ b/src/arithmeticmodel.cpp Tue Jan 19 11:45:27 2010 -0600
@@ -1,57 +1,57 @@
- * Project: laszip - http://liblas.org -
- * Purpose:
- * Author: Martin Isenburg
- * isenburg at cs.unc.edu
- * Copyright (c) 2009, Martin Isenburg
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- FILE: arithmeticmodel.cpp
- CONTENTS:
- see header file
- PROGRAMMERS:
- martin isenburg at cs.unc.edu
- COPYRIGHT:
+ * Project: laszip - http://liblas.org -
+ * Purpose:
+ * Author: Martin Isenburg
+ * isenburg at cs.unc.edu
+ * Copyright (c) 2009, Martin Isenburg
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ FILE: arithmeticmodel.cpp
+ CONTENTS:
+ see header file
+ PROGRAMMERS:
+ martin isenburg at cs.unc.edu
+ COPYRIGHT:
copyright (C) 2009 martin isenburg at cs.unc.edu
- This software is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
- CHANGE HISTORY:
- see header file
-#include "arithmeticmodel.h"
-#include <stdio.h>
-#include <stdlib.h>
+ This software is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+ CHANGE HISTORY:
+ see header file
+#include "arithmeticmodel.h"
+#include <stdio.h>
+#include <stdlib.h>
void AC_ERROR(const char* msg) {
fprintf(stderr, "Arithmetic coding ERROR: %s\n", msg); exit(1);
ArithmeticModel::ArithmeticModel(unsigned int n, unsigned int *init, int compress)
data_symbols = 0;
More information about the Liblas-commits
