[Liblas-commits] hg: remove LASFile, it was useless and not being used
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Jan 29 10:05:04 EST 2010
changeset 38451089c06a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=38451089c06a
summary: remove LASFile, it was useless and not being used
diffstat:
 include/Makefile.am            |    2 -
 include/liblas/detail/file.hpp |   90 ------------------
 include/liblas/lasfile.hpp     |   85 -----------------
 src/Makefile.am                |    4 +-
 src/detail/file.cpp            |  195 -----------------------------------------
 src/las_c_api.cpp              |    1 -
 src/lasfile.cpp                |  116 ------------------------
 7 files changed, 1 insertions(+), 492 deletions(-)
diffs (truncated from 553 to 300 lines):
diff -r addf137144ca -r 38451089c06a include/Makefile.am
--- a/include/Makefile.am	Fri Jan 29 08:49:06 2010 -0600
+++ b/include/Makefile.am	Fri Jan 29 09:00:25 2010 -0600
@@ -8,7 +8,6 @@
     liblas/lasclassification.hpp \
     liblas/lascolor.hpp \
     liblas/laserror.hpp \
-    liblas/lasfile.hpp \
     liblas/lasheader.hpp \
     liblas/laspoint.hpp \
     liblas/lasreader.hpp \
@@ -21,7 +20,6 @@
     liblas/capi/las_version.h \
     liblas/capi/las_config.h \
     liblas/detail/endian.hpp \
-    liblas/detail/file.hpp \
     liblas/detail/fwd.hpp \
     liblas/detail/reader.hpp \
     liblas/detail/reader10.hpp \
diff -r addf137144ca -r 38451089c06a include/liblas/detail/file.hpp
--- a/include/liblas/detail/file.hpp	Fri Jan 29 08:49:06 2010 -0600
+++ /dev/null	Thu Jan 01 00:00:00 1970 +0000
@@ -1,90 +0,0 @@
- * $Id$
- * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
- * Purpose:  A composite class to handle read/write operations
- * Author:   Mateusz Loskot, mateusz at loskot.net
- * Copyright (c) 2008, Mateusz Loskot
- * Copyright (c) 2008, Howard Butler
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following
- * conditions are met:
- *     * Redistributions of source code must retain the above copyright
- *       notice, this list of conditions and the following disclaimer.
- *     * Redistributions in binary form must reproduce the above copyright
- *       notice, this list of conditions and the following disclaimer in
- *       the documentation and/or other materials provided
- *       with the distribution.
- *     * Neither the name of the Martin Isenburg or Iowa Department
- *       of Natural Resources nor the names of its contributors may be
- *       used to endorse or promote products derived from this software
- *       without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
- * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
- * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
- * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
- * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
- * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
- * OF SUCH DAMAGE.
-#ifndef LIBLAS_DETAIL_FILE_HPP_INCLUDED
-#define LIBLAS_DETAIL_FILE_HPP_INCLUDED
-#include <liblas/lasreader.hpp>
-#include <liblas/laswriter.hpp>
-#include <memory>
-#include <string>
-#include <fstream>
-#include <iostream>
-#include <stdexcept>
-#include <cassert>
-namespace liblas { namespace detail {
-class FileImpl
-public:
-    FileImpl(std::string const& filename);
-    FileImpl(std::string const& filename, LASHeader const& header, int mode);
-    ~FileImpl();
-    std::string GetName() const;
-    int GetMode() const;
-    LASHeader const& GetHeader() const;
-    LASReader& GetReader();
-    LASWriter& GetWriter();
-private:
-    // Blocked copying operations, declared but not defined.
-    FileImpl(FileImpl const& other);
-    FileImpl& operator=(FileImpl const& rhs);
-    int m_mode;
-    std::string m_filename;
-    std::istream* m_istrm;
-    std::ostream* m_ostrm;
-    LASReader* m_reader;
-    LASWriter* m_writer;
-    LASHeader m_header;
-    void throw_no_file_error() const;
-}} // namespace liblas::detail
-#endif // LIBLAS_DETAIL_FILE_HPP_INCLUDED
diff -r addf137144ca -r 38451089c06a include/liblas/lasfile.hpp
--- a/include/liblas/lasfile.hpp	Fri Jan 29 08:49:06 2010 -0600
@@ -1,85 +0,0 @@
- * $Id$
- * OF SUCH DAMAGE.
-#ifndef LIBLAS_LASFILE_HPP_INCLUDED
-#define LIBLAS_LASFILE_HPP_INCLUDED
-#include <liblas/detail/file.hpp> // complete type required
-#include <liblas/detail/sharedptr.hpp>
-#include <string>
-#include <cassert>
-namespace liblas {
-/// \todo to be documented
-class LASFile
-public:
-    enum Mode
-        eRead = 0,
-        eWrite = 1,
-        eAppend = 2
-    LASFile();
-    LASFile(std::string const& filename);
-    LASFile(std::string const& filename, LASHeader const& header, Mode mode);
-    LASFile(LASFile const& other);
-    LASFile& operator=(LASFile const& rhs);
-    bool IsNull() const;
-    Mode GetMode() const;
-private:
-    detail::SharedPtr<detail::FileImpl> m_pimpl;
-} // namespace liblas
-#endif // LIBLAS_LASFILE_HPP_INCLUDED
diff -r addf137144ca -r 38451089c06a src/Makefile.am
--- a/src/Makefile.am	Fri Jan 29 08:49:06 2010 -0600
+++ b/src/Makefile.am	Fri Jan 29 09:00:25 2010 -0600
@@ -34,7 +34,6 @@
 	lasvariablerecord.cpp \
 	lasreader.cpp \
 	laswriter.cpp \
-	lasfile.cpp \
 	las_c_api.cpp \
 	lasspatialreference.cpp \
 	lasformat.cpp \
@@ -45,8 +44,7 @@
 	detail/writer.cpp \
 	detail/writer10.cpp \
 	detail/writer11.cpp \
-	detail/writer12.cpp \
-	detail/file.cpp
+	detail/writer12.cpp
 if GDAL_IS_CONFIG
 liblas_la_SOURCES += gt_wkt_srs.cpp gt_citation.cpp tifvsi.cpp
diff -r addf137144ca -r 38451089c06a src/detail/file.cpp
--- a/src/detail/file.cpp	Fri Jan 29 08:49:06 2010 -0600
@@ -1,195 +0,0 @@
- * $Id$
- * OF SUCH DAMAGE.
-#include <string>
-#include <fstream>
-#include <cassert>
-FileImpl::FileImpl(std::string const& filename)
-    : m_mode(0), m_filename(filename),
-        m_istrm(0), m_ostrm(0), m_reader(0), m_writer(0)
-    if (filename == "stdin")
-        m_istrm = &std::cin;
-    else
-        std::ios::openmode const mode = std::ios::in | std::ios::binary;
-        m_istrm = new std::ifstream(m_filename.c_str(), mode);
-        if (!m_istrm->good())
-            delete m_istrm;
-            throw_no_file_error();
More information about the Liblas-commits mailing list
