[Liblas-commits] hg: clean up tests due to LASFile removal
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Jan 29 12:23:47 EST 2010
changeset f8f3667abef4 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=f8f3667abef4
summary: clean up tests due to LASFile removal
diffstat:
 test/unit/CMakeLists.txt   |    1 -
 test/unit/Makefile.am      |    1 -
 test/unit/common.cpp       |    8 +-
 test/unit/lasfile_test.cpp |  271 ---------------------------------------------
 4 files changed, 4 insertions(+), 277 deletions(-)
diffs (truncated from 323 to 300 lines):
diff -r ebe8c63c1dec -r f8f3667abef4 test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt	Fri Jan 29 10:24:21 2010 -0600
+++ b/test/unit/CMakeLists.txt	Fri Jan 29 11:19:09 2010 -0600
@@ -11,7 +11,6 @@
     common.cpp
     guid_test.cpp
     laserror_test.cpp
-    lasfile_test.cpp
     lasheader_test.cpp
     laspoint_test.cpp
     lasreader_iterator_test.cpp
diff -r ebe8c63c1dec -r f8f3667abef4 test/unit/Makefile.am
--- a/test/unit/Makefile.am	Fri Jan 29 10:24:21 2010 -0600
+++ b/test/unit/Makefile.am	Fri Jan 29 11:19:09 2010 -0600
@@ -24,7 +24,6 @@
     guid_test.cpp \
     lasclassification_test.cpp \
     laserror_test.cpp \
-    lasfile_test.cpp \
     lasheader_test.cpp \
     lasspatialreference_test.cpp \
     laspoint_test.cpp \
diff -r ebe8c63c1dec -r f8f3667abef4 test/unit/common.cpp
--- a/test/unit/common.cpp	Fri Jan 29 10:24:21 2010 -0600
+++ b/test/unit/common.cpp	Fri Jan 29 11:19:09 2010 -0600
@@ -59,9 +59,9 @@
     ensure_equals("wrong default records count",
         h.GetRecordsCount(), liblas::uint32_t(0));
     ensure_equals("wrong default data format id",
-        h.GetDataFormatId(), LASHeader::ePointFormat0);
+        h.GetDataFormatId(), liblas::ePointFormat0);
     ensure_equals("wrong default data record length",
-        h.GetDataRecordLength(), LASHeader::ePointSize0);
+        h.GetDataRecordLength(), liblas::ePointSize0);
     ensure_equals("wrong default point records count",
         h.GetPointRecordsCount(), liblas::uint32_t(0));
@@ -139,8 +139,8 @@
     ensure_equals(h.GetHeaderSize(), liblas::uint16_t(227));
     ensure_equals(h.GetDataOffset(), liblas::uint32_t(229));
     ensure_equals(h.GetRecordsCount(), liblas::uint32_t(0));
-    ensure_equals(h.GetDataFormatId(), liblas::LASHeader::ePointFormat1);
-    ensure_equals(h.GetDataRecordLength(), liblas::LASHeader::ePointSize1);
+    ensure_equals(h.GetDataFormatId(), liblas::ePointFormat1);
+    ensure_equals(h.GetDataRecordLength(), liblas::ePointSize1);
     ensure_equals(h.GetPointRecordsCount(), liblas::uint32_t(8));
     ensure_equals(h.GetScaleX(), double(0.01));
     ensure_equals(h.GetScaleY(), double(0.01));
diff -r ebe8c63c1dec -r f8f3667abef4 test/unit/lasfile_test.cpp
--- a/test/unit/lasfile_test.cpp	Fri Jan 29 10:24:21 2010 -0600
+++ /dev/null	Thu Jan 01 00:00:00 1970 +0000
@@ -1,271 +0,0 @@
-// $Id$
-// (C) Copyright Mateusz Loskot 2008, mateusz at loskot.net
-// Distributed under the BSD License
-// (See accompanying file LICENSE.txt or copy at
-// http://www.opensource.org/licenses/bsd-license.php)
-#include <liblas/lasfile.hpp>
-#include <liblas/lasheader.hpp>
-#include <liblas/lasreader.hpp>
-#include <liblas/laswriter.hpp>
-#include <tut/tut.hpp>
-#include <iostream>
-#include <stdexcept>
-#include <string>
-#include "liblas_test.hpp"
-#include "common.hpp"
-namespace tut
-    struct lasfile_data
-        std::string tmpfile_;
-        std::string file10_;
-        lasfile_data()
-            : tmpfile_(g_test_data_path + "/lasfile_tmp.las"),
-                file10_(g_test_data_path + "/TO_core_last_clip.las")
-        ~lasfile_data()
-            // remove temporary file after each test case
-            int const ret = std::remove(tmpfile_.c_str());
-            if (0 != ret)
-                ; // ignore, file may not exist
-    typedef test_group<lasfile_data> tg;
-    typedef tg::object to;
-    tg test_group_lasfile("liblas::LASFile");
-    // Test default constructor
-    template<>
-    template<>
-    void to::test<1>()
-        liblas::LASFile file;
-        ensure(file.IsNull());
-    // Test custom constructor
-    template<>
-    template<>
-    void to::test<2>()
-        liblas::LASFile file(file10_);
-        ensure_not(file.IsNull());
-        ensure_equals(file.GetName(), file10_);
-        ensure_equals(file.GetMode(), liblas::LASFile::eRead);
-        liblas::LASHeader const& header1 = file.GetHeader();
-        test_file10_header(header1);
-        liblas::LASReader& reader = file.GetReader();
-        liblas::LASHeader const& header2 = reader.GetHeader();
-        test_file10_header(header2);
-        try
-            liblas::LASWriter& writer = file.GetWriter();
-            ensure_equals(writer.GetVersion(), liblas::eLASVersion10);
-            ensure("std::runtime_error not thrown", false);
-        catch (std::runtime_error const& e)
-            ensure_equals(std::string(e.what()).substr(0, 6), std::string("Writer"));
-    template<>
-    template<>
-    void to::test<3>()
-        liblas::LASHeader header;
-        try
-            liblas::LASFile file(tmpfile_, header, liblas::LASFile::eRead);
-            ensure_equals(file.GetName(), tmpfile_);
-            ensure_equals(std::string(e.what()),
-                std::string("File mode must be eWrite or eAppend"));
-    template<>
-    template<>
-    void to::test<4>()
-        liblas::LASFile file(tmpfile_, header, liblas::LASFile::eWrite);
-        ensure_equals(file.GetMode(), liblas::LASFile::eWrite);
-        test_default_header(header1);
-        liblas::LASHeader const& header2 = writer.GetHeader();
-        test_default_header(header2);
-        try
-            ensure_equals(reader.GetVersion(), liblas::eLASVersion10);
-            ensure_equals(std::string(e.what()).substr(0, 6), std::string("Reader"));
-    // Test copy constructor on default initialized object
-    template<>
-    template<>
-    void to::test<5>()
-        liblas::LASFile file2(file);
-        ensure(file2.IsNull());
-    // Test assignment operator
-    template<>
-    template<>
-    void to::test<6>()
-        liblas::LASFile file2;
-        file2 = file;
-    // Test copy constructor on read-only file
-    template<>
-    template<>
-    void to::test<7>()
-        ensure_not(file2.IsNull());
-        ensure_equals(file2.GetName(), file10_);
-        ensure_equals(file2.GetMode(), liblas::LASFile::eRead);
-        liblas::LASHeader const& header2 = file2.GetHeader();
-    // Test assignment operator on read-only file
-    template<>
-    template<>
-    void to::test<8>()
-            file2 = file;
-            // file object is deallocated here
-        liblas::LASHeader const& header1 = file2.GetHeader();
-    // Test assignment operator on write-only file
-    template<>
-    template<>
-    void to::test<9>()
-        ensure_equals(file2.GetName(), tmpfile_);
-        ensure_equals(file2.GetMode(), liblas::LASFile::eWrite);
-    template<>
-    template<>
-    void to::test<10>()
More information about the Liblas-commits mailing list
