[Liblas-commits] hg: add classification filter example
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Jul 1 09:37:38 EDT 2010
changeset d3c9a68dad27 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d3c9a68dad27
summary: add classification filter example
diffstat:
 doc/tutorial/cpp.txt |  64 +++++++++++++++++++++++++++++++++++++++++++++++++++-
 1 files changed, 63 insertions(+), 1 deletions(-)
diffs (72 lines):
diff -r 550e985548eb -r d3c9a68dad27 doc/tutorial/cpp.txt
--- a/doc/tutorial/cpp.txt	Wed Jun 30 15:03:24 2010 -0500
+++ b/doc/tutorial/cpp.txt	Thu Jul 01 08:37:32 2010 -0500
@@ -203,4 +203,66 @@
-.. _`unit tests package`: http://liblas.org/browser/trunk/test/unit
\ No newline at end of file
+Applying filters to a reader to extract specified classes
+The following example demonstrates how to use the built-in ClassificationFilter
+to filter for classes that match the specified values.  You can also provide
+your own filters by subclassing liblas::FilterI and providing a filter()
+function.
+.. note::
+    Filters are applied in the order they are read from the vector that is
+    given to the Reader/Writer in the SetFilters call.
+.. code-block:: cpp
+    #include <liblas/liblas.hpp>
+    #include <liblas/laspoint.hpp>
+    #include <liblas/lasreader.hpp>
+    #include <liblas/laswriter.hpp>
+    #include <liblas/lasfilter.hpp>
+    #include <vector>
+    int main(int argc, char* argv[])
+        std::ifstream ifs;
+        std::string in_file("input.las");
+        std::string out_file("output.las");
+        if (!liblas::Open(ifs, in_file.c_str()))
+            throw std::runtime_error(std::string("Can not open \'") + in_file + "\'");
+        std::vector<liblas::uint8_t> classes;
+        classes.push_back(2); // ground
+        classes.push_back(9); // water
+        classes.push_back(6); // building
+        std::vector<liblas::FilterI*> filters;
+        liblas::ClassificationFilter* class_filter = new liblas::ClassificationFilter(classes);
+        // eInclusion means to keep the classes that match.  eExclusion would
+        // throw out those that matched
+        class_filter->SetType(liblas::FilterI::eInclusion);
+        filters.push_back(class_filter);
+        liblas::Reader reader(ifs);
+        reader.SetFilters(&filters);
+        std::ofstream ofs;
+        if (!liblas::Create(ofs, out_file.c_str()))
+            throw std::runtime_error(std::string("Can not create \'") + in_file + "\'");
+        liblas::Writer writer(ofs, reader.GetHeader());
+        while (reader.ReadNextPoint())
+            liblas::Point const& p = reader.GetPoint();
+            writer.WritePoint(p);
+.. _`unit tests package`: http://liblas.org/browser/trunk/test/unit
More information about the Liblas-commits mailing list
