[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Thu Jul 1 11:42:53 EDT 2010
changeset d57d6830721f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d57d6830721f
summary: make boost required
changeset 9d4d836ad06d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9d4d836ad06d
summary: rename liblas::PointFormat to liblas::Schema
diffstat:
CMakeLists.txt | 8 +-
include/liblas/capi/liblas.h | 38 ++--
include/liblas/detail/reader/point.hpp | 2 +-
include/liblas/detail/writer/point.hpp | 2 +-
include/liblas/lasformat.hpp | 114 -----------------
include/liblas/lasheader.hpp | 10 +-
include/liblas/lasschema.hpp | 114 +++++++++++++++++
python/examples/add_vlr.py | 25 +++
python/liblas/core.py | 90 ++++++------
python/liblas/format.py | 150 ----------------------
python/liblas/header.py | 62 ++++----
python/liblas/schema.py | 150 ++++++++++++++++++++++
python/tests/File.txt | 4 +-
python/tests/Format.txt | 68 ----------
python/tests/Schema.txt | 68 ++++++++++
src/CMakeLists.txt | 6 +-
src/detail/reader/point.cpp | 3 +-
src/detail/writer/point.cpp | 4 +-
src/las_c_api.cpp | 110 ++++++++--------
src/lasformat.cpp | 220 ---------------------------------
src/lasheader.cpp | 10 +-
src/lasschema.cpp | 220 +++++++++++++++++++++++++++++++++
22 files changed, 753 insertions(+), 725 deletions(-)
diffs (truncated from 1971 to 300 lines):
diff -r 714a12f210b1 -r 9d4d836ad06d CMakeLists.txt
--- a/CMakeLists.txt Thu Jul 01 09:24:46 2010 -0500
+++ b/CMakeLists.txt Thu Jul 01 10:42:44 2010 -0500
@@ -149,12 +149,14 @@
-# Boost C++ Libraries support - optional, default=OFF
-set(WITH_BOOST FALSE CACHE BOOL "Choose if Boost C++ Libraries support should be built")
+# Boost C++ Libraries support - optional, default=ON
+set(WITH_BOOST TRUE CACHE BOOL "Choose if Boost C++ Libraries support should be built (required)")
# TODO: Decide minimum required version of Boost. Is 1.38 OK? --mloskot
if(WITH_BOOST)
- find_package(Boost 1.35 REQUIRED iostreams)
+ message(STATUS "Searching for Boost 1.38+ - done")
+ find_package(Boost 1.38 REQUIRED iostreams)
if(Boost_FOUND AND Boost_iostreams_FOUND)
include_directories(${Boost_INCLUDE_DIRS})
diff -r 714a12f210b1 -r 9d4d836ad06d include/liblas/capi/liblas.h
--- a/include/liblas/capi/liblas.h Thu Jul 01 09:24:46 2010 -0500
+++ b/include/liblas/capi/liblas.h Thu Jul 01 10:42:44 2010 -0500
@@ -61,7 +61,7 @@
typedef struct LASVLRHS *LASVLRH;
typedef struct LASColorHS *LASColorH;
typedef struct LASSRSHS *LASSRSH;
-typedef struct LASPointFormatHS *LASPointFormatH;
+typedef struct LASSchemaHS *LASSchemaH;
/* Fake out the compiler if we don't have libgeotiff */
@@ -1128,7 +1128,7 @@
LAS_DLL LASError LASPoint_SetColor(LASPointH hPoint, const LASColorH hColor);
/** Gets the extra data stream for the LASPointH as an array of bytes. The length of this
- * array should be the difference between the LASPointFormat_GetByteSize() and the
+ * array should be the difference between the LASSchema_GetByteSize() and the
* a LASHeader_GetDataRecordLength(). Points with data larger than this (fixed) size
* will be clipped upong being written into the file. You must allocate it on
* the heap and you are responsible for its destruction.
@@ -1139,7 +1139,7 @@
LAS_DLL LASError LASPoint_GetExtraData(const LASPointH hPoint, uint8_t** data, uint16_t* length);
/** Sets the extra data stream for the LASPointH as an array of bytes. The length of this
* the VLR structure.
@@ -1183,30 +1183,30 @@
LAS_DLL void LASString_Free(char* string);
-LAS_DLL LASPointFormatH LASPointFormat_Create( uint8_t version_major,
+LAS_DLL LASSchemaH LASSchema_Create( uint8_t version_major,
uint8_t version_minor,
uint32_t size,
uint8_t bHasColor,
uint8_t bHasTime);
-LAS_DLL uint8_t LASPointFormat_GetVersionMinor( LASPointFormatH hFormat);
-LAS_DLL LASError LASPointFormat_SetVersionMinor( LASPointFormatH hFormat, uint8_t nMinor);
-LAS_DLL uint8_t LASPointFormat_GetMajorVersion( LASPointFormatH hFormat);
-LAS_DLL LASError LASPointFormat_SetVersionMinor( LASPointFormatH hFormat, uint8_t nMajor);
-LAS_DLL uint8_t LASPointFormat_HasColor( LASPointFormatH hFormat);
-LAS_DLL LASError LASPointFormat_SetColor( LASPointFormatH hFormat, uint8_t bColor);
-LAS_DLL uint8_t LASPointFormat_HasTime( LASPointFormatH hFormat);
-LAS_DLL LASError LASPointFormat_SetTime( LASPointFormatH hFormat, uint8_t bTime);
-LAS_DLL uint16_t LASPointFormat_GetByteSize( LASPointFormatH hFormat);
-LAS_DLL LASError LASPointFormat_SetByteSize( LASPointFormatH hFormat, uint16_t size);
-LAS_DLL uint16_t LASPointFormat_GetBaseByteSize( LASPointFormatH hFormat);
-LAS_DLL LASError LASPointFormat_SetBaseByteSize( LASPointFormatH hFormat, uint16_t size);
+LAS_DLL uint8_t LASSchema_GetVersionMinor( LASSchemaH hFormat);
+LAS_DLL LASError LASSchema_SetVersionMinor( LASSchemaH hFormat, uint8_t nMinor);
+LAS_DLL uint8_t LASSchema_GetMajorVersion( LASSchemaH hFormat);
+LAS_DLL LASError LASSchema_SetVersionMinor( LASSchemaH hFormat, uint8_t nMajor);
+LAS_DLL uint8_t LASSchema_HasColor( LASSchemaH hFormat);
+LAS_DLL LASError LASSchema_SetColor( LASSchemaH hFormat, uint8_t bColor);
+LAS_DLL uint8_t LASSchema_HasTime( LASSchemaH hFormat);
+LAS_DLL LASError LASSchema_SetTime( LASSchemaH hFormat, uint8_t bTime);
+LAS_DLL uint16_t LASSchema_GetByteSize( LASSchemaH hFormat);
+LAS_DLL LASError LASSchema_SetByteSize( LASSchemaH hFormat, uint16_t size);
+LAS_DLL uint16_t LASSchema_GetBaseByteSize( LASSchemaH hFormat);
+LAS_DLL LASError LASSchema_SetBaseByteSize( LASSchemaH hFormat, uint16_t size);
-LAS_DLL LASPointFormatH LASHeader_GetPointFormat( LASHeaderH hHeader );
-LAS_DLL LASError LASHeader_SetPointFormat( LASHeaderH hHeader, LASPointFormatH hFormat);
+LAS_DLL LASSchemaH LASHeader_GetSchema( LASHeaderH hHeader );
+LAS_DLL LASError LASHeader_SetSchema( LASHeaderH hHeader, LASSchemaH hFormat);
-LAS_DLL void LASPointFormat_Destroy(LASPointFormatH hFormat);
+LAS_DLL void LASSchema_Destroy(LASSchemaH hFormat);
LAS_C_END
diff -r 714a12f210b1 -r 9d4d836ad06d include/liblas/detail/reader/point.hpp
--- a/include/liblas/detail/reader/point.hpp Thu Jul 01 09:24:46 2010 -0500
+++ b/include/liblas/detail/reader/point.hpp Thu Jul 01 10:42:44 2010 -0500
@@ -83,7 +83,7 @@
const liblas::Header& m_header;
liblas::Point m_point;
- PointFormat m_format;
+ Schema m_format;
void setup();
void fill(PointRecord& record);
diff -r 714a12f210b1 -r 9d4d836ad06d include/liblas/detail/writer/point.hpp
--- a/include/liblas/detail/writer/point.hpp Thu Jul 01 09:24:46 2010 -0500
+++ b/include/liblas/detail/writer/point.hpp Thu Jul 01 10:42:44 2010 -0500
@@ -85,7 +85,7 @@
PointRecord m_record;
+ Schema m_format;
liblas::uint8_t* m_blanks;
diff -r 714a12f210b1 -r 9d4d836ad06d include/liblas/lasformat.hpp
--- a/include/liblas/lasformat.hpp Thu Jul 01 09:24:46 2010 -0500
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,114 +0,0 @@
- * $Id$
- * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
- * Purpose: LAS PointFormat implementation for C++ libLAS
- * Author: Howard Butler, hobu.inc at gmail.com
- * Copyright (c) 2010, Howard Butler
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following
- * conditions are met:
- * * Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided
- * with the distribution.
- * * Neither the name of the Martin Isenburg or Iowa Department
- * of Natural Resources nor the names of its contributors may be
- * used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
- * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
- * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
- * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
- * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
- * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
- * OF SUCH DAMAGE.
-#ifndef LIBLAS_FORMAT_HPP_INCLUDED
-#define LIBLAS_FORMAT_HPP_INCLUDED
-#include <liblas/detail/fwd.hpp>
-#include <liblas/cstdint.hpp>
-// std
-#include <iosfwd>
-namespace liblas {
-class PointFormat
-public:
- PointFormat( liblas::uint8_t major,
- liblas::uint8_t minor,
- liblas::uint16_t size);
- liblas::uint16_t size,
- bool bColor,
- bool bTime);
- PointFormat& operator=(PointFormat const& rhs);
- PointFormat(PointFormat const& other);
- ~PointFormat() {};
- /// Fetch byte size
- uint16_t GetByteSize() const;
- /// Set value of the red image channel
- void SetByteSize(uint16_t const& value);
- /// Get the base size (only accounting for Time, Color, etc )
- uint16_t GetBaseByteSize() const;
- uint8_t GetVersionMajor() const;
- void SetVersionMajor(uint8_t const& value);
- uint8_t GetVersionMinor() const;
- void SetVersionMinor(uint8_t const& value);
- bool HasColor() const;
- void Color(bool const& bColor); // updatesize(); }
- bool HasTime() const;
- void Time(bool const& bTime); // {m_hasTime = bTime; updatesize(); }
-protected:
- liblas::uint16_t m_size;
- liblas::uint8_t m_versionminor;
- liblas::uint8_t m_versionmajor;
- bool m_hasColor;
- bool m_hasTime;
- liblas::uint16_t m_base_size;
-private:
- void updatesize();
- void updatesize(liblas::uint16_t new_size);
- liblas::uint16_t calculate_base_size();
-} // namespace liblas
-#endif // LIBLAS_FORMAT_HPP_INCLUDED
diff -r 714a12f210b1 -r 9d4d836ad06d include/liblas/lasheader.hpp
--- a/include/liblas/lasheader.hpp Thu Jul 01 09:24:46 2010 -0500
+++ b/include/liblas/lasheader.hpp Thu Jul 01 10:42:44 2010 -0500
@@ -50,7 +50,7 @@
#include <liblas/liblas.hpp>
#include <liblas/lasvariablerecord.hpp>
#include <liblas/lasspatialreference.hpp>
-#include <liblas/lasformat.hpp>
+#include <liblas/lasschema.hpp>
#include <liblas/guid.hpp>
//std
@@ -323,8 +323,8 @@
/// Set the georeference
void SetSRS(SpatialReference& srs);
- PointFormat GetPointFormat() const;
- void SetPointFormat(const PointFormat& format);
+ Schema GetSchema() const;
+ void SetSchema(const Schema& format);
private:
@@ -352,7 +352,7 @@
void Init();
void ClearGeoKeyVLRs();
- void UpdatePointFormat();
+ void UpdateSchema();
// Private data members
@@ -382,7 +382,7 @@
PointExtents m_extents;
std::vector<VariableRecord> m_vlrs;
SpatialReference m_srs;
+ Schema m_format;
diff -r 714a12f210b1 -r 9d4d836ad06d include/liblas/lasschema.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/liblas/lasschema.hpp Thu Jul 01 10:42:44 2010 -0500
@@ -0,0 +1,114 @@
+ * $Id$
+ * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose: LAS Schema implementation for C++ libLAS
+ * Author: Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
More information about the Liblas-commits
