[Liblas-commits] hg: switch filter logic to make easier to read
liblas-commits at liblas.org
Mon Jul 5 16:10:48 EDT 2010
changeset 6aeb8622dedd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6aeb8622dedd
summary: switch filter logic to make easier to read
diffstat:
doc/tutorial/cpp.txt | 6 +++---
1 files changed, 3 insertions(+), 3 deletions(-)
diffs (17 lines):
diff -r 7c319a70d798 -r 6aeb8622dedd doc/tutorial/cpp.txt
--- a/doc/tutorial/cpp.txt Fri Jul 02 11:54:13 2010 -0500
+++ b/doc/tutorial/cpp.txt Mon Jul 05 15:10:40 2010 -0500
@@ -263,10 +263,10 @@
// If the type is switched to eExclusion, we'll throw out all last returns.
- if (GetType() == eInclusion) {
+ if (GetType() == eExclusion && output == true) {
+ output = false;
+ } else {
output = true;
- } else {
- output = false;
return output;
More information about the Liblas-commits
