[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Jul 14 11:50:52 EDT 2010
changeset 5046a89520c7 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=5046a89520c7
summary: don't copy transform points onto the heap. no reason for that
changeset 1c965145fba9 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1c965145fba9
summary: replace reprojection transform with boost::shared_ptr instead of naked pointer
diffstat:
 include/liblas/laswriter.hpp |   9 +++++++--
 src/laswriter.cpp            |  41 +++++++++++++++++++++++------------------
 2 files changed, 30 insertions(+), 20 deletions(-)
diffs (134 lines):
diff -r e07b656ef222 -r 1c965145fba9 include/liblas/laswriter.hpp
--- a/include/liblas/laswriter.hpp	Wed Jul 14 10:34:40 2010 -0500
+++ b/include/liblas/laswriter.hpp	Wed Jul 14 10:49:25 2010 -0500
@@ -56,10 +56,14 @@
 #include <memory>
 #include <cstdlib> // std::size_t
+#include <boost/shared_ptr.hpp>
 namespace liblas
+typedef boost::shared_ptr< liblas::TransformI > TransformPtr;
 /// Defines public interface to LAS writer implementation.
 /// This class
@@ -125,8 +129,9 @@
     std::vector<liblas::FilterI*>* m_filters;
     std::vector<liblas::TransformI*>* m_transforms;
-    liblas::TransformI* m_reprojection_transform;
+    TransformPtr m_reprojection_transform;
+    // liblas::TransformI* m_reprojection_transform;
     SpatialReference m_out_srs;
     SpatialReference m_in_srs;
diff -r e07b656ef222 -r 1c965145fba9 src/laswriter.cpp
--- a/src/laswriter.cpp	Wed Jul 14 10:34:40 2010 -0500
+++ b/src/laswriter.cpp	Wed Jul 14 10:49:25 2010 -0500
@@ -57,7 +57,7 @@
     m_pimpl(detail::WriterFactory::Create(ofs)), m_header(header),
     m_filters(0),
     m_transforms(0),
-    m_reprojection_transform(0)
+    m_reprojection_transform(TransformPtr())
     m_pimpl->WriteHeader(m_header);
@@ -123,23 +123,22 @@
     if (bHaveTransforms) {
     if (m_transforms->size() != 0) {
         // Apply the transforms to each point
-        Point* pt = new Point(point);
+        Point p(point);
         for (ti = m_transforms->begin(); ti != m_transforms->end(); ++ti) {
             liblas::TransformI* transform = *ti;
-            transform->transform(*pt);
+            transform->transform(p);
         // We have to write a copy of our point, because we're applying
         // transformations that change the point.
-        m_pimpl->WritePoint(*pt, m_header);
-        delete pt;
+        m_pimpl->WritePoint(p, m_header);
         return true;
     // if we haven't returned because of the filter and we don't have any
     // transforms, just write the point
@@ -150,7 +149,6 @@
 std::ostream& Writer::GetStream() const
     return m_pimpl->GetStream();
-    // return m_ofs;
 void Writer::WriteHeader(Header& header)
@@ -176,7 +174,13 @@
     m_out_srs = srs;
+    // Check the very first transform and see if it is
+    // the reprojection transform.  If it is, we're going to
+    // nuke it and replace it with a new one
+    // If there was nothing there, we're going to make a new reprojection
+    // transform and put in on the transforms list (or make a new transforms
+    // list if *that* isn't there).
     TransformI* possible_reprojection_transform = 0;
     if (m_transforms != 0) {
@@ -185,29 +189,30 @@
-    if (m_reprojection_transform == possible_reprojection_transform && m_reprojection_transform != 0) {
+    if (m_reprojection_transform.get() == possible_reprojection_transform && m_reprojection_transform.get() != 0) {
         // remove it from the transforms list
         std::vector<TransformI*>::iterator i = m_transforms->begin();
         m_transforms->erase(i);
-    if (m_reprojection_transform != 0)
-        delete m_reprojection_transform;
-    m_reprojection_transform = new ReprojectionTransform(m_in_srs, m_out_srs);
+    // overwrite our reprojection transform
+    m_reprojection_transform = TransformPtr(new ReprojectionTransform(m_in_srs, m_out_srs));
         if (m_transforms->size() > 0) {
-            m_transforms->insert(m_transforms->begin(), m_reprojection_transform);
+            // Insert the new reprojection transform to the beginning of the
+            // vector there are already transforms there.
+            m_transforms->insert(m_transforms->begin(), m_reprojection_transform.get());
         } else {
-            m_transforms->push_back(m_reprojection_transform);
+            // List exists, but its size is 0
+            m_transforms->push_back(m_reprojection_transform.get());
     } else {
+        // transforms don't exist yet, make a new one and put our
+        // reprojection transform on it.
         m_transforms = new std::vector<liblas::TransformI*>;
More information about the Liblas-commits mailing list
