[Liblas-commits] hg: add lasblock utility for generating OPC blocks as .kdx files
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jul 19 22:58:18 EDT 2010
changeset 2d95cf229452 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2d95cf229452
summary: add lasblock utility for generating OPC blocks as .kdx files
diffstat:
 apps/CMakeLists.txt |   10 +-
 apps/chipper.cpp    |  309 ++++++++++++++++++++++++++++++++++++++++++++++++++++
 apps/chipper.hpp    |  129 +++++++++++++++++++++
 apps/lasblock.cpp   |  143 ++++++++++++++++++++++++
 4 files changed, 589 insertions(+), 2 deletions(-)
diffs (truncated from 627 to 300 lines):
diff -r c3cc6f66f1ed -r 2d95cf229452 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Mon Jul 19 21:08:39 2010 -0500
+++ b/apps/CMakeLists.txt	Mon Jul 19 21:58:10 2010 -0500
@@ -20,7 +20,7 @@
 set(LAS2TXT las2txt)
 set(TXT2LAS txt2las)
 set(LAS2LAS2 las2las2 )
+set(LASBLOCK lasblock )
 # Set the build type to release if it is not explicitly set by the user and
 # isn't in the cache yet
@@ -45,7 +45,7 @@
 set(LIBLAS_UTILITIES
     ${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT} ${TXT2LAS}
-    ${LAS2OGR}  ${LAS2OCI} ${LAS2LAS2} ${BIGFILE_TEST})
+    ${LAS2OGR}  ${LAS2OCI} ${LAS2LAS2} ${LASBLOCK} ${BIGFILE_TEST})
 # TODO: Experimental and requires testing --mloskot
 # Generate user-specific settings for Visual Studio project
@@ -113,6 +113,12 @@
     target_link_libraries(${LASMERGE} ${LIBLAS_C_LIB_NAME})
 endif()
+# Build lasblock
+if(LASBLOCK)
+    set(LASBLOCK_SRC lasblock.cpp chipper.cpp chipper.hpp)
+    add_executable(${LASBLOCK} ${LASBLOCK_SRC})
+    target_link_libraries(${LASBLOCK} ${APPS_CPP_DEPENDENCIES})
+endif()
 # Build las2ogr
 if(LAS2OGR)
diff -r c3cc6f66f1ed -r 2d95cf229452 apps/chipper.cpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/apps/chipper.cpp	Mon Jul 19 21:58:10 2010 -0500
@@ -0,0 +1,309 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  Point Partitioning/blocking for OPC
+ * Author:   Andrew Bell andrew.bell.ia at gmail.com
+ * Copyright (c) 2010, Andrew Bell
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Andrew Bell or libLAS nor the names of
+ *       its contributors may be used to endorse or promote products derived
+ *       from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#include "chipper.hpp"
+#include <math.h>
+using namespace std;
+The objective is to split the region into non-overlapping blocks, each
+containing approximately the same number of points, as specified by the
+user.
+First, the points are read into arrays - one for the x direction, and one for
+the y direction.  The arrays are sorted and are initialized with indices into
+the other array of the location of the other coordinate of the same point.
+Partitions are created that place the maximum number of points in a
+block, subject to the user-defined threshold, using a cumulate and round
+procedure.
+The distance of the point-space is checked in each direction and the
+wider dimension is chosen for splitting at an appropriate partition point.
+The points in the narrower direction are copied to locations in the spare
+array at one side or the other of the chosen partition, and that portion
+of the spare array then becomes the active array for the narrow direction.
+This avoids resorting of the arrays, which are already sorted.
+This procedure is then recursively applied to the created blocks until
+they contains only one or two partitions.  In the case of one partition,
+we are done, and we simply store away the contents of the block.  If there are
+two partitions in a block, we avoid the recopying the narrow array to the
+spare since the wide array already contains the desired points partitioned
+into two blocks.  We simply need to locate the maximum and minimum values
+from the narrow array so that the approriate extrema of the block can
+be stored.
+namespace liblas
+namespace chipper
+vector<uint32_t> Block::GetIDs() const
+    vector<uint32_t> ids;
+    for (uint32_t i = m_left; i <= m_right; ++i)
+        ids.push_back((*m_list_p)[i].m_ptindex);
+    return ids;
+void Chipper::Chip()
+    Load(m_xvec, m_yvec, m_spare);
+    Partition(m_xvec.size());
+    DecideSplit(m_xvec, m_yvec, m_spare, 0, m_partitions.size() - 1);
+void Chipper::Load(RefList& xvec, RefList& yvec, RefList& spare )
+    PtRef ref;
+    uint32_t idx;
+    uint32_t count;
+    vector<PtRef>::iterator it;
+    count = m_reader->GetHeader().GetPointRecordsCount();
+    xvec.reserve(count);
+    yvec.reserve(count);
+    spare.reserve(count);
+    count = 0;
+    while (m_reader->ReadNextPoint()) {
+        const liblas::Point& pt = m_reader->GetPoint();
+        ref.m_pos = pt.GetX();
+        ref.m_ptindex = count;
+        xvec.push_back(ref);
+        ref.m_pos = pt.GetY();
+        yvec.push_back(ref);
+        count++;
+    // Sort xvec and assign other index in yvec to sorted indices in xvec.
+    sort(xvec.begin(), xvec.end());
+    for (uint32_t i = 0; i < xvec.size(); ++i) {
+        idx = xvec[i].m_ptindex;
+        yvec[idx].m_oindex = i;
+    // Sort yvec.
+    sort(yvec.begin(), yvec.end());
+    //Iterate through the yvector, setting the xvector appropriately.
+    for (uint32_t i = 0; i < yvec.size(); ++i)
+        xvec[yvec[i].m_oindex].m_oindex = i;
+void Chipper::Partition(uint32_t size)
+    uint32_t num_partitions;
+    num_partitions = size / m_threshold;
+    if ( size % m_threshold )
+        num_partitions++;
+    double total = 0;
+    double partition_size = (double)size / num_partitions;
+    m_partitions.push_back(0);
+    for (uint32_t i = 0; i < num_partitions; ++i) {
+        total += partition_size;
+        m_partitions.push_back((uint32_t)round(total));
+void Chipper::DecideSplit(RefList& v1, RefList& v2, RefList& spare,
+    uint32_t pleft, uint32_t pright)
+    double v1range;
+    double v2range;
+    uint32_t left = m_partitions[pleft];
+    uint32_t right = m_partitions[pright] - 1;
+    // Decide the wider direction of the block, and split in that direction
+    // to maintain squareness.
+    v1range = v1[right].m_pos - v1[left].m_pos;
+    v2range = v2[right].m_pos - v2[left].m_pos;
+    if (v1range > v2range)
+        Split(v1, v2, spare, pleft, pright);
+    else
+        Split(v2, v1, spare, pleft, pright);
+void Chipper::Split(RefList& wide, RefList& narrow, RefList& spare,
+    uint32_t lstart;
+    uint32_t rstart;
+    uint32_t pcenter;
+    uint32_t left;
+    uint32_t right;
+    uint32_t center;
+    left = m_partitions[pleft];
+    right = m_partitions[pright] - 1;
+    // There are two cases in which we are done.
+    // 1) We have a distance of two between left and right.
+    // 2) We have a distance of three between left and right.
+    if (pright - pleft == 1)
+        Emit(wide, left, right, narrow, left, right);
+    else if (pright - pleft == 2)
+        FinalSplit(wide, narrow, pleft, pright);
+    else
+        pcenter = (pleft + pright) / 2;
+        center = m_partitions[pcenter];
+        // We are splitting in the wide direction - split elements in the
+        // narrow array by copying them to the spare array in the correct
+        // partition.  The spare array then becomes the active narrow array
+        // for the [left,right] partition.
+        lstart = left;
+        rstart = center;
+        for (int64_t i = left; i <= right; ++i)
+            if (narrow[i].m_oindex < center)
+                spare[lstart] = narrow[i];
+                wide[narrow[i].m_oindex].m_oindex = lstart;
+                lstart++;
+            else
+                spare[rstart] = narrow[i];
+                wide[narrow[i].m_oindex].m_oindex = rstart;
+                rstart++;
+        // Save away the direction so we know which array is X and which is Y
+        // so that when we emit, we can properly label the max/min points.
+        Direction dir = narrow.m_dir;
+        spare.m_dir = dir;
+        DecideSplit(wide, spare, narrow, pleft, pcenter);
+        DecideSplit(wide, spare, narrow, pcenter, pright);
+        narrow.m_dir = dir;
+// In this case the wide array is like we want it.  The narrow array is
+// ordered, but not for our split, so we have to find the max/min entries
+// for each partition in the final split.
+void Chipper::FinalSplit(RefList& wide, RefList& narrow,
+    long left1 = -1;
+    long left2 = -1;
+    long right1 = -1;
+    long right2 = -1;
+    uint32_t center = m_partitions[pright - 1];
+    // Find left values for the partitions.
+        if (left1 < 0 && (narrow[i].m_oindex < center))
+            left1 = i;
+            if (left2 >= 0)
+                break;
+        else if (left2 < 0 && (narrow[i].m_oindex >= center))
+            left2 = i;
+            if (left1 >= 0)
+                break;
+    // Find right values for the partitions.
More information about the Liblas-commits mailing list
