[Liblas-commits] hg: add colorize.py to grab colors from GDAL images and assign t...
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Jul 23 23:14:20 EDT 2010
changeset 59b1f93a276e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=59b1f93a276e
summary: add colorize.py to grab colors from GDAL images and assign them to points in LAS files
diffstat:
 python/scripts/colorize.py |  323 +++++++++++++++++++++++++++++++++++++++++++++
 1 files changed, 323 insertions(+), 0 deletions(-)
diffs (truncated from 328 to 300 lines):
diff -r e8d76b9f0a55 -r 59b1f93a276e python/scripts/colorize.py
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/python/scripts/colorize.py	Fri Jul 23 22:14:13 2010 -0500
@@ -0,0 +1,323 @@
+#!/usr/bin/env python
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  Pull color from a GDAL raster into an LAS file
+ * Author:   Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler
+ * Copyright (c) 2010, Aaron Reyna
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+import optparse
+import os
+import sys
+from liblas import header
+from liblas import color
+from liblas import file as lasfile
+from liblas import schema
+from liblas import srs
+from osgeo import gdal
+gdal.UseExceptions()
+class Colorizer(object):
+    def construct_parser(self):
+        from optparse import OptionParser, OptionGroup
+        usage = "usage: %prog [options] arg"
+        parser = OptionParser(usage)
+        g = OptionGroup(parser, "Base options", "Basic Translation Options")
+        g.add_option("-c", "--connection", dest="connection",
+                          help="OCI connection string", metavar="CONNECTION")
+        g.add_option("-o", "--output", dest='output',
+                          help="LAS file to write", metavar="OUTPUT")
+        g.add_option("-i", "--input", dest='input',
+                          help="LAS file to read", metavar="INPUT")
+        g.add_option("-r", "--image", dest='image',
+                          help="GDAL raster image to use for color ", metavar="IMAGE")
+        g.add_option("-b", "--bands", dest='bands',
+                          help="Comma-separated list of bands numbers to use for R,G,B ", metavar="BANDS")
+        g.add_option("-s", "--scale", dest='scale',
+                          help="Scale the color values to 16 bit by multiplying by 256 ", metavar="SCALE")
+        g.add_option("-t", "--target-srs", dest='target_srs',
+                          help="Output SRS for LAS file", metavar="TARGET_SRS")
+        g.add_option("-a", "--assign-srs", dest='assign_srs',
+                          help="Assign specified SRS for input LAS file", metavar="ASSIGN_SRS")
+        g.add_option("-w", "--overwrite",
+                          action="store_true", dest="overwrite",
+                          help="overwrite the existing LAS output file")
+        g.add_option("-q", "--quiet",
+                          action="store_false", dest="verbose", default=False,
+                          help="Don't say what we're doing on stdout")
+        parser.add_option_group(g)
+        if self.opts:
+            g = OptionGroup(parser, "Special Options", "Special options")
+            for o in self.opts:
+                g.add_option(o)
+        parser.set_defaults(verbose=True, precision = 6)
+        self.parser = parser
+    def __init__(self, arguments, options=None):
+        self.las = None
+        self.image = None
+        self.output = None
+        self.sql = None
+        self.opts = options
+        self.construct_parser()
+        self.options, self.args = self.parser.parse_args(args=arguments)
+        if not self.options.image:
+            try:
+                self.options.image = self.args[1]
+                self.options.image = gdal.Open(self.options.image)
+            except IndexError:
+                raise self.parser.error("No input image was selected to use for color values!")
+            except Exception as inst:
+                raise self.parser.error("Unable to open GDAL image: %s" % inst.args[0])
+        if not self.options.bands:
+            self.options.bands = (1,2,3)
+        else:
+            self.options.bands = [int(i) for i in self.options.bands.split(',')]
+        if not self.options.output:
+            try:
+                self.options.output = self.args[2]
+                self.options.output = 'output.las'
+        if self.options.output:
+            self.options.output = os.path.abspath(self.options.output)
+            if os.path.isdir(self.options.output):
+                raise self.parser.error("Output '%s' is a directory, not a file " % self.options.output)
+            if os.path.exists(self.options.output):
+                if not self.options.overwrite:
+                    raise self.parser.error("Output file '%s' exists, but you have not selected the --overwrite option" % self.options.output)
+        else:
+            raise self.parser.error("No output was specified")
+        if self.options.target_srs:
+            s = srs.SRS()
+            s.set_userinput(self.options.target_srs)
+            self.options.target_srs = s
+        if self.options.assign_srs:
+            s = srs.SRS()
+            s.set_userinput(self.options.assign_srs)
+            self.options.assign_srs = s
+        if self.args:
+            self.options.las = self.args[0]
+            try:
+                f = self.options.las
+                self.options.las = lasfile.File(f, mode='r')
+                    # if we're assigning an SRS, take the header from the
+                    # file, grab it, and then stick our SRS on it and use it
+                    # to read the file
+                    h = self.options.las.header
+                    h.srs = self.options.assign_srs
+                    self.options.las = lasfile.File(f, header=h)
+                raise self.parser.error("Unable to open input LAS file: %s" % inst.args[0])
+    def create_output(self):
+        # Use the same header as before, but just add support for color
+        # and adjust our version to 1.2
+        s = h.schema
+        s.color = True
+        h.schema = s
+        h.version = '1.2'
+            h.srs = self.options.target_srs
+        self.options.output = lasfile.File(self.options.output, header=h, mode='w')
+            self.options.output.set_srs(self.options.target_srs)
+    def process(self):
+        rows = self.options.image.RasterYSize
+        cols = self.options.image.RasterXSize
+        bands = self.options.image.RasterCount
+        # get georeference info
+        transform = self.options.image.GetGeoTransform()
+        xOrigin = transform[0]
+        yOrigin = transform[3]
+        pixelWidth = transform[1]
+        pixelHeight = transform[5]
+        red_band = self.options.image.GetRasterBand(self.options.bands[0]) # 1-based index
+        green_band = self.options.image.GetRasterBand(self.options.bands[1])
+        blue_band = self.options.image.GetRasterBand(self.options.bands[1])
+        for p in self.options.las[0:400]:
+            # compute pixel offset
+            xOffset = int((p.x - xOrigin) / pixelWidth)
+            yOffset = int((p.y - yOrigin) / pixelHeight)
+            red = red_band.ReadAsArray(xOffset, yOffset, 1, 1)
+            green = green_band.ReadAsArray(xOffset, yOffset, 1, 1)
+            blue = blue_band.ReadAsArray(xOffset, yOffset, 1, 1)
+            red, green, blue = int(red), int(green), int(blue)
+            if self.options.scale:
+                red =  red * 256
+                green = green * 256
+                blue = blue * 256
+            c = color.Color(red, blue, green)
+            p.color = c
+            self.options.output.write(p)
+def main():
+    d = Colorizer(sys.argv[1:])
+    d.create_output()
+    d.process()
+if __name__=='__main__':
+    main()
+# import os, sys
+# from liblas import file
+# from liblas import header
+# from liblas import color
+# from liblas import *
+# try:
+#   from osgeo import ogr, gdal
+#   from osgeo.gdalconst import *
+#   os.chdir('C:\\crap\\county\\Crook')
+# except ImportError:
+#   import ogr, gdal
+#   from gdalconst import *
+#   os.chdir(r'C:\\crap\\county\\Crook')
+# print "loaded"
+# lassy = 'D:\\aaron_working\\DESCHUTTES\\Decluttered_no_birds\\DES_04593.las'
+# gdal.UseExceptions()
+# # open the image
+# img = gdal.Open('naip_1_1_1n_s_or013_2005_1_C4593.img', GA_ReadOnly)
+# if img is None:
+#   print 'Could not open aster.img'
+#   sys.exit(1)
+# print "loaded img"
+# # get image size
+# rows = img.RasterYSize
+# cols = img.RasterXSize
+# bands = img.RasterCount
+# # get georeference info
+# transform = img.GetGeoTransform()
+# xOrigin = transform[0]
+# yOrigin = transform[3]
+# pixelWidth = transform[1]
+# pixelHeight = transform[5]
+# data=file.File(lassy, mode='r')
+# print "creating .LAS file"
+# h = header.Header()
+# h.dataformat_id = 1
+# h.minor_version = 2
+# newdata=file.File('D:\\aaron_working\\DESCHUTTES\\Decluttered_no_birds\\DES_04593aaaab.las', mode='w', header=h)
+# for p in data:
+#     pt = point.Point()
+#     xL = p.x
+#     yL = p.y
+#     pt.x = p.x
+#     pt.y = p.y
+#     pt.z = p.z
+#     pt.intensity = p.intensity
+#     pt.flightline_edge = p.flightline_edge
+#     pt.scan_flags = p.scan_flags
+#     pt.number_of_returns = p.number_of_returns
+#     pt.classification = p.classification
+#     pt.scan_angle = p.scan_angle
More information about the Liblas-commits mailing list
