[Liblas-commits] hg: Removed WITH_BOOST option and made Boost a
required dependen...
liblas-commits at liblas.org
Mon Jul 26 12:14:47 EDT 2010
changeset 0528a32de5bc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0528a32de5bc
summary: Removed WITH_BOOST option and made Boost a required dependency. In order to build libLAS, it is enough to set BOOST_INCLUDEDIR value.
diffstat:
CMakeLists.txt | 31 +++++++++++--------------------
1 files changed, 11 insertions(+), 20 deletions(-)
diffs (53 lines):
diff -r 6f123366fe23 -r 0528a32de5bc CMakeLists.txt
--- a/CMakeLists.txt Mon Jul 26 10:14:37 2010 -0500
+++ b/CMakeLists.txt Mon Jul 26 17:18:23 2010 +0100
@@ -134,7 +134,15 @@
# Search for dependencies
-# libxml2 support - required, default=ON
+# Boost C++ Libraries support - required
+message(STATUS "Searching for Boost 1.38+ - done")
+find_package(Boost 1.38 REQUIRED)
+if(Boost_FOUND)
+ include_directories(${Boost_INCLUDE_DIRS})
+endif()
+# libxml2 support - optional, default=ON
set(WITH_LIBXML2 FALSE CACHE BOOL "Choose if libxml2 support should be built ")
if(WITH_LIBXML2)
@@ -147,24 +155,6 @@
endif()
endif()
-# Boost C++ Libraries support - optional, default=ON
-set(WITH_BOOST TRUE CACHE BOOL "Choose if Boost C++ Libraries support should be built (required)")
-# TODO: Decide minimum required version of Boost. Is 1.38 OK? --mloskot
-if(WITH_BOOST)
- message(STATUS "Searching for Boost 1.38+ - done")
- find_package(Boost 1.38 REQUIRED)
- if(Boost_FOUND)
- include_directories(${Boost_INCLUDE_DIRS})
- endif()
-endif()
# GeoTIFF support - optional, default=OFF
set(WITH_GEOTIFF FALSE CACHE BOOL "Choose if GeoTIFF support should be built")
@@ -333,4 +323,5 @@
if (WIN32)
include(BuildOSGeo4W)
-endif(WIN32)
\ No newline at end of file
+endif(WIN32)
More information about the Liblas-commits
