[Liblas-commits] hg: notes about libPC, Boost requirement
liblas-commits at liblas.org
Tue Jul 27 11:25:37 EDT 2010
changeset f98607cfae91 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=f98607cfae91
summary: notes about libPC, Boost requirement
diffstat:
doc/compilation.txt | 8 +++++++
doc/development/release_plan.txt | 42 +++++++++++++++++++++++++++++++++++++--
doc/utilities/index.txt | 3 +-
doc/utilities/ts2las.txt | 25 +++++++++++++++++++++++
4 files changed, 74 insertions(+), 4 deletions(-)
diffs (137 lines):
diff -r c7c784b915ca -r f98607cfae91 doc/compilation.txt
--- a/doc/compilation.txt Tue Jul 27 16:03:29 2010 +0100
+++ b/doc/compilation.txt Tue Jul 27 10:25:30 2010 -0500
@@ -56,6 +56,13 @@
* GCC 4.2
* LLVM 4.2
+`Boost`_
+`Boost`_ is required to build libLAS 1.6. Set ``BOOST_INCLUDEDIR`` if
+cmake cannot find it in a default location.
.. _optional_libraries:
Optional libraries
@@ -582,3 +589,4 @@
.. _`Autoconf`: http://www.gnu.org/software/autoconf/
.. _`LLVM`: http://llvm.org/
.. _`OSGeo4W`: http://trac.osgeo.org/osgeo4w/
+.. _`Boost`: http://www.boost.org/
\ No newline at end of file
diff -r c7c784b915ca -r f98607cfae91 doc/development/release_plan.txt
--- a/doc/development/release_plan.txt Tue Jul 27 16:03:29 2010 +0100
+++ b/doc/development/release_plan.txt Tue Jul 27 10:25:30 2010 -0500
@@ -7,7 +7,7 @@
:Author: Howard Butler
:Contact: hobu.inc at gmail dot com
-:Date: 7/19/2010
+:Date: 7/27/2010
.. contents::
:depth: 3
@@ -38,6 +38,13 @@
flexibility to add new features and extensibility to allow the reader and
writers to be overridden by user code.
+Rudimentary LAS 1.3 support
+Support for reading and writing LAS 1.3 *point* data is not provided in
+libLAS 1.6. Support for reading point formats 4 or 5 is not yet complete,
+however.
Generic interfaces
@@ -79,8 +86,8 @@
-libLAS has migrated to CMake to manage compilation. See
-`libLAS Compilation <http://liblas.org/compilation.html>`__ for specific details how to use CMake
+libLAS has migrated to CMake to manage compilation. See `libLAS Compilation
+<http://liblas.org/compilation.html>`__ for specific details how to use CMake
to build libLAS from source.
Minor features
@@ -133,6 +140,35 @@
* Beta 2: 9/10/2010
* 1.6.0: 9/30/2010
+libPC
+There exists a need in the LiDAR and laser scanning fields for a library much
+like `GDAL`_ to provide translation to and from various formats. Further
+development with libLAS has caused it to currently accrete support for reading
+TerraSolid .bin files (:ref:`ts2las`) and write the `Oracle Point Cloud`_
+(:ref:`las2oci`) format into Oracle databases. Additionally, there are a
+multitude of other formats with similar characteristics that would be
+excellent candidates for participating in a GDAL-like library for point cloud
+data. These include:
+* LAS
+* `QFIT`_
+* `Oracle Point Cloud`_
+* `BAG`_
+* Fixed schema CSV/text
+* Variable schema CSV/text
+To that end, I will be embarking on developing a new library in the style of
+GDAL to provide support for reading and writing (to varying levels of
+capability) these formats. The plan is for it to be bootstrapped after the
+1.6 release of libLAS.
+.. _`GDAL`: http://www.gdal.org
+.. _`QFIT`: http://nsidc.org/data/ilatm1b.html
+.. _`Oracle Point Cloud`: http://download.oracle.com/docs/cd/B28359_01/appdev.111/b28400/sdo_pc_pkg_ref.htm
+.. _`BAG`: http://www.opennavsurf.org/papers/ons_fsd.pdf
diff -r c7c784b915ca -r f98607cfae91 doc/utilities/index.txt
--- a/doc/utilities/index.txt Tue Jul 27 16:03:29 2010 +0100
+++ b/doc/utilities/index.txt Tue Jul 27 10:25:30 2010 -0500
@@ -15,4 +15,5 @@
las2ogr
txt2las
las2oci
- lasblock
+ lasblock
+ ts2las
diff -r c7c784b915ca -r f98607cfae91 doc/utilities/ts2las.txt
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/doc/utilities/ts2las.txt Tue Jul 27 10:25:30 2010 -0500
@@ -0,0 +1,25 @@
+.. raw:: pdf
+ PageBreak
+.. _ts2las:
+ ts2las
+:Author: Howard Butler
+:Contact: hobu at hobu.net
+ts2las converts TerraSolid .bin files into LAS files.
+Usage
+ $ ts2las -i input.bin -o lidar.las
More information about the Liblas-commits
