[Liblas-commits] hg: Fixed incorrect test case of reader_iterator.
liblas-commits at liblas.org
Thu Jul 29 11:47:18 EDT 2010
changeset a227d7b038ef in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a227d7b038ef
summary: Fixed incorrect test case of reader_iterator.
diffstat:
test/unit/common.hpp | 37 +++++++++++++++++-----------------
test/unit/lasreader_iterator_test.cpp | 25 ++--------------------
2 files changed, 21 insertions(+), 41 deletions(-)
diffs (104 lines):
diff -r 9dcdde9c7334 -r a227d7b038ef test/unit/common.hpp
--- a/test/unit/common.hpp Thu Jul 29 16:45:57 2010 +0100
+++ b/test/unit/common.hpp Thu Jul 29 16:50:55 2010 +0100
@@ -9,6 +9,7 @@
#include <liblas/laspoint.hpp>
#include <liblas/lasheader.hpp>
+#include <iostream>
namespace tut
@@ -37,38 +38,36 @@
// Functor to calculate bounding box of a set of points
struct bbox_calculator
- typedef liblas::Bounds result_type;
- bbox_calculator() : empty(true) {}
- result_type get_result() const { return bbox; }
+ bbox_calculator(liblas::Bounds& bbox) : bbox(&bbox), empty(true) {}
void operator()(liblas::Point const& p)
+ assert(0 != bbox);
// Box initialization during first iteration only
if (empty)
- bbox.min(0, p.GetX());
- bbox.max(0, p.GetX());
- bbox.min(1, p.GetY());
- bbox.max(1, p.GetY());
- bbox.min(2, p.GetZ());
- bbox.max(2, p.GetZ());
+ bbox->min(0, p.GetX());
+ bbox->max(0, p.GetX());
+ bbox->min(1, p.GetY());
+ bbox->max(1, p.GetY());
+ bbox->min(2, p.GetZ());
+ bbox->max(2, p.GetZ());
empty = false;
// Expand bounding box to include given point
- bbox.min(0, std::min(bbox.min(0), p.GetX()));
- bbox.min(1, std::min(bbox.min(1), p.GetY()));
- bbox.min(2, std::min(bbox.min(2), p.GetZ()));
- bbox.max(0, std::max(bbox.max(0), p.GetX()));
- bbox.max(1, std::max(bbox.max(1), p.GetY()));
- bbox.max(2, std::max(bbox.max(2), p.GetZ()));
+ bbox->min(0, std::min(bbox->min(0), p.GetX()));
+ bbox->min(1, std::min(bbox->min(1), p.GetY()));
+ bbox->min(2, std::min(bbox->min(2), p.GetZ()));
+ bbox->max(0, std::max(bbox->max(0), p.GetX()));
+ bbox->max(1, std::max(bbox->max(1), p.GetY()));
+ bbox->max(2, std::max(bbox->max(2), p.GetZ()));
+private:
+ liblas::Bounds* bbox;
bool empty;
- liblas::Bounds bbox;
// Common test procedure for default constructed point data.
diff -r 9dcdde9c7334 -r a227d7b038ef test/unit/lasreader_iterator_test.cpp
--- a/test/unit/lasreader_iterator_test.cpp Thu Jul 29 16:45:57 2010 +0100
+++ b/test/unit/lasreader_iterator_test.cpp Thu Jul 29 16:50:55 2010 +0100
@@ -383,30 +383,11 @@
Header const& h = reader_.GetHeader();
bbox_t lasbbox = h.GetExtent();
- // I don't know why this is failing -- hobu
- // std::cout << std::endl;
- // std::cout << "minx: " << h.GetMinX()
- // << " miny: " << h.GetMinY()
- // << " minz: " << h.GetMinZ()
- // << " maxx: " << h.GetMaxX()
- // << " maxy: " << h.GetMaxY()
- // << " maxz: " << h.GetMaxZ();
// Accumulate points extents to common bounding box
- bbox_calculator calculator;
- std::for_each(it, end, calculator);
+ bbox_t accumulated;
+ std::for_each(it, end, bbox_calculator(accumulated));
- // bbox_t b = calculator.get_result();
- // std::cout << "minx: " << b.min.x
- // << " miny: " << b.min.y
- // << " minz: " << b.min.z
- // << " maxx: " << b.max.x
- // << " maxy: " << b.max.y
- // << " maxz: " << b.max.z;
- ensure(lasbbox == calculator.get_result());
+ ensure(lasbbox == accumulated);
More information about the Liblas-commits
