[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Thu Jul 29 12:05:14 EDT 2010
changeset 4f88a603d17c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=4f88a603d17c
summary: Upgraded TUT framework to most recent SVN r190 version
changeset 6e5d65bfde5e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6e5d65bfde5e
summary: Fixed compilation warnings in laspoint_test.cpp
diffstat:
test/unit/laspoint_test.cpp | 7 +-
test/unit/tut/README | 2 +-
test/unit/tut/tut.hpp | 132 +++++++----
test/unit/tut/tut_assert.hpp | 163 ++++++++++++--
test/unit/tut/tut_config.hpp | 6 +
test/unit/tut/tut_console_reporter.hpp | 95 +++++--
test/unit/tut/tut_cppunit_reporter.hpp | 201 ------------------
test/unit/tut/tut_exception.hpp | 92 +++++++-
test/unit/tut/tut_posix.hpp | 37 ++-
test/unit/tut/tut_restartable.hpp | 9 +-
test/unit/tut/tut_result.hpp | 79 +++++-
test/unit/tut/tut_runner.hpp | 55 +++-
test/unit/tut/tut_xml_reporter.hpp | 361 ---------------------------------
13 files changed, 512 insertions(+), 727 deletions(-)
diffs (truncated from 2028 to 300 lines):
diff -r 783324a4e8f5 -r 6e5d65bfde5e test/unit/laspoint_test.cpp
--- a/test/unit/laspoint_test.cpp Thu Jul 29 17:01:38 2010 +0100
+++ b/test/unit/laspoint_test.cpp Thu Jul 29 17:08:48 2010 +0100
@@ -424,20 +424,21 @@
template<>
void to::test<17>()
- std::vector<liblas::uint8_t> data;
+ typedef std::vector<liblas::uint8_t> data_t;
+ data_t data;
data.push_back(254);
data.push_back(1);
ensure_equals("invalid default extra data",
- m_default.GetExtraData().size(), 0);
+ m_default.GetExtraData().size(), 0u);
m_default.SetExtraData(data);
ensure_equals("invalid set red color",
- m_default.GetExtraData().size(), 3);
+ m_default.GetExtraData().size(), 3u);
ensure_equals("invalid set green color",
m_default.GetExtraData()[1], 254);
diff -r 783324a4e8f5 -r 6e5d65bfde5e test/unit/tut/README
--- a/test/unit/tut/README Thu Jul 29 17:01:38 2010 +0100
+++ b/test/unit/tut/README Thu Jul 29 17:08:48 2010 +0100
@@ -1,7 +1,7 @@
TUT: C++ Template Unit Test Framework
-Version: TUT-2008-11-30
+Version: TUT (SVN Revision 190)
Homepage: http://tut-framework.sourceforge.net/
diff -r 783324a4e8f5 -r 6e5d65bfde5e test/unit/tut/tut.hpp
--- a/test/unit/tut/tut.hpp Thu Jul 29 17:01:38 2010 +0100
+++ b/test/unit/tut/tut.hpp Thu Jul 29 17:08:48 2010 +0100
@@ -1,5 +1,6 @@
#ifndef TUT_H_GUARD
#define TUT_H_GUARD
+#include <tut/tut_config.hpp>
#include <iostream>
#include <map>
@@ -9,11 +10,6 @@
#include <sstream>
#include <iterator>
#include <algorithm>
-#include <typeinfo>
-#if defined(linux)
-#define TUT_USE_POSIX
-#endif
#include "tut_exception.hpp"
#include "tut_result.hpp"
@@ -35,6 +31,9 @@
namespace tut
+template <class, int>
+class test_group;
* Test object. Contains data test run upon and default test method
* implementation. Inherited from Data to allow tests to
@@ -43,12 +42,29 @@
template <class Data>
class test_object : public Data, public test_object_posix
+ template<class D, int M>
+ friend class test_group;
+ void set_test_group(const char *group)
+ current_test_group_ = group;
+ void set_test_id(int current_test_id)
+ current_test_id_ = current_test_id;
public:
* Default constructor
test_object()
+ : called_method_was_a_dummy_test_(false),
+ current_test_id_(0),
+ current_test_name_(),
+ current_test_group_()
@@ -62,9 +78,9 @@
return current_test_name_;
- void set_test_id(int current_test_id)
+ const std::string& get_test_group() const
- current_test_id_ = current_test_id;
+ return current_test_group_;
int get_test_id() const
@@ -86,13 +102,17 @@
* Used to detect usused test numbers and avoid unnecessary
* test object creation which may be time-consuming depending
* on operations described in Data::Data() and Data::~Data().
- * TODO: replace with throwing special exception from default test.
bool called_method_was_a_dummy_test_;
+ virtual ~test_object()
private:
int current_test_id_;
std::string current_test_name_;
+ std::string current_test_group_;
@@ -126,6 +146,9 @@
template <class Data, int MaxTestsInGroup = 50>
class test_group : public group_base, public test_group_posix
+ test_group(const test_group&);
+ void operator=(const test_group&);
const char* name_;
typedef void (test_object<Data>::*testmethod)();
@@ -139,13 +162,15 @@
tests tests_;
tests_iterator current_test_;
- enum seh_result
- SEH_OK,
- SEH_CTOR,
- SEH_TEST,
- SEH_DUMMY
+ enum seh_result
+ SEH_OK,
+#if defined(TUT_USE_SEH)
+ SEH_CTOR,
+ SEH_TEST,
+#endif
+ SEH_DUMMY
* Exception-in-destructor-safe smart-pointer class.
@@ -201,11 +226,16 @@
try
if (delete_obj() == false)
throw warning("destructor of test object raised"
" an SEH exception");
+#else
+ bool d = delete_obj();
+ assert(d && "delete failed with SEH disabled: runtime bug?");
+#endif
catch (const std::exception& ex)
@@ -268,7 +298,9 @@
* Creates and registers test group with specified name.
test_group(const char* name)
- : name_(name)
+ : name_(name),
+ tests_(),
+ current_test_()
// register itself
runner.get().register_group(name_,this);
@@ -281,7 +313,9 @@
* This constructor is used in self-test run only.
test_group(const char* name, test_runner& another_runner)
- : name_(name)
+ : name_(name),
+ tests_(),
+ current_test_()
// register itself
another_runner.register_group(name_, this);
@@ -367,22 +401,23 @@
try
switch (run_test_seh_(ti->second, obj, current_test_name, ti->first))
- case SEH_CTOR:
- throw bad_ctor("seh");
- break;
+ case SEH_CTOR:
+ throw bad_ctor("seh");
+ break;
- case SEH_TEST:
- throw seh("seh");
- break;
+ case SEH_TEST:
+ throw seh("seh");
+ break;
+#endif
+ case SEH_DUMMY:
+ tr.result = test_result::dummy;
+ break;
- case SEH_DUMMY:
- tr.result = test_result::dummy;
- break;
- case SEH_OK:
- // ok
- break;
+ case SEH_OK:
+ // ok
+ break;
catch (const rethrown& ex)
@@ -393,13 +428,13 @@
catch (const tut_error& ex)
tr.result = ex.result();
- tr.exception_typeid = typeid(ex).name();
+ tr.exception_typeid = ex.type();
tr.message = ex.what();
tr.result = test_result::ex;
+ tr.exception_typeid = type_name(ex);
catch (...)
@@ -433,12 +468,12 @@
__try
#endif
- if (obj.get() == 0)
- reset_holder_(obj);
+ if (obj.get() == 0)
+ reset_holder_(obj);
- obj->called_method_was_a_dummy_test_ = false;
+ obj->called_method_was_a_dummy_test_ = false;
@@ -446,6 +481,7 @@
#endif
obj.get()->set_test_id(current_test_id);
+ obj.get()->set_test_group(name_);
(obj.get()->*tm)();
@@ -456,20 +492,20 @@
#endif
- if (obj->called_method_was_a_dummy_test_)
- // do not call obj.release(); reuse object
- return SEH_DUMMY;
+ if (obj->called_method_was_a_dummy_test_)
+ // do not call obj.release(); reuse object
+ return SEH_DUMMY;
More information about the Liblas-commits
