[Liblas-commits] hg: Removed use of std::copy_n which is available
in C++0x only.
liblas-commits at liblas.org
Thu Jul 29 12:28:25 EDT 2010
changeset fe4def923c79 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=fe4def923c79
summary: Removed use of std::copy_n which is available in C++0x only.
diffstat:
src/detail/writer/header.cpp | 2 +-
1 files changed, 1 insertions(+), 1 deletions(-)
diffs (12 lines):
diff -r 371f4d8914ee -r fe4def923c79 src/detail/writer/header.cpp
--- a/src/detail/writer/header.cpp Thu Jul 29 17:25:59 2010 +0100
+++ b/src/detail/writer/header.cpp Thu Jul 29 17:32:03 2010 +0100
@@ -218,7 +218,7 @@
// TODO: fix this for 1.3, which has srbyr = 7; See detail/reader/header.cpp for more details
// assert(vpbr.size() <= srbyr);
uint32_t pbr[srbyr] = { 0 };
- std::copy_n(vpbr.begin(), srbyr, pbr); // FIXME: currently, copies only 5 records, to be improved
+ std::copy(vpbr.begin(), vpbr.begin() + srbyr, pbr); // FIXME: currently, copies only 5 records, to be improved
detail::write_n(GetStream(), pbr, sizeof(pbr));
// 20-22. Scale factors
More information about the Liblas-commits
