[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Jul 29 12:48:46 EDT 2010
changeset 23bc1a506f0a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=23bc1a506f0a
summary: Removed sharedptr.hpp - replaced by boost::shared_ptr
changeset 52f24e850b32 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=52f24e850b32
summary: merged
diffstat:
 include/liblas/detail/sharedptr.hpp |  132 ------------------------------------
 python/tests/File.txt               |   11 ++-
 src/detail/reader/header.cpp        |    2 +-
 3 files changed, 11 insertions(+), 134 deletions(-)
diffs (181 lines):
diff -r fe4def923c79 -r 52f24e850b32 include/liblas/detail/sharedptr.hpp
--- a/include/liblas/detail/sharedptr.hpp	Thu Jul 29 17:32:03 2010 +0100
+++ /dev/null	Thu Jan 01 00:00:00 1970 +0000
@@ -1,132 +0,0 @@
- * $Id$
- * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
- * Purpose:  Shared pointer implementation for C++ libLAS
- * Author:   Mateusz Loskot, mateusz at loskot.net
- * The SharedPtr class is based on implementation of CountedPtr
- * from the book "The C++ Standard Library - A Tutorial and Reference"
- * (C) Copyright Nicolai M. Josuttis 1999
- * (C) Copyright Mateusz Loskot 2008, mateusz at loskot.net (modifications)
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following
- * conditions are met:
- *     * Redistributions of source code must retain the above copyright
- *       notice, this list of conditions and the following disclaimer.
- *     * Redistributions in binary form must reproduce the above copyright
- *       notice, this list of conditions and the following disclaimer in
- *       the documentation and/or other materials provided
- *       with the distribution.
- *     * Neither the name of the Martin Isenburg or Iowa Department
- *       of Natural Resources nor the names of its contributors may be
- *       used to endorse or promote products derived from this software
- *       without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
- * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
- * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
- * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
- * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
- * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
- * OF SUCH DAMAGE.
-#ifndef LIBLAS_DETAIL_SHAREDPTR_HPP_INCLUDED
-#define LIBLAS_DETAIL_SHAREDPTR_HPP_INCLUDED
-#include <cassert>
-namespace liblas { namespace detail {
-template <class T>
-class SharedPtr
-public:
-    // Initialize pointer with existing pointer, where pointer p
-    // is required to be a return value of new operator
-    // TODO: Relax the "0 != p requirement"
-    //  m_count(new long(p ? 1 : 0))
-    explicit SharedPtr(T* p = 0)
-        : m_ptr(p), m_count(new long(1))
-    // Copy pointer (one more owner)
-    SharedPtr(SharedPtr<T> const& other) throw()
-        : m_ptr(other.m_ptr), m_count(other.m_count)
-            ++*m_count;
-    // Destructor (delete value if this was the last owner)
-    ~SharedPtr() throw()
-        dispose();
-    // Assignment operator (unshare old and share new value)
-    SharedPtr<T>& operator=(SharedPtr<T> const& rhs) throw()
-        if (&rhs != this)
-            dispose();
-            m_ptr = rhs.m_ptr;
-            m_count = rhs.m_count;
-            ++*m_count;
-        return *this;
-    T& operator*() const throw()
-        assert(0 != m_ptr);
-        return *m_ptr;
-    T* operator->() const throw()
-        return m_ptr;
-    T* get() const
-        return m_ptr;
-    long use_count() const
-        return (*m_count);
-private:
-    T* m_ptr;
-    long* m_count; // shared number of owners
-    void dispose()
-        if (--*m_count == 0)
-            delete m_count;
-            delete m_ptr;
-}} // namespace liblas::detail
-#endif // LIBLAS_DETAIL_SHAREDPTR_HPP_INCLUDED
diff -r fe4def923c79 -r 52f24e850b32 python/tests/File.txt
--- a/python/tests/File.txt	Thu Jul 29 17:32:03 2010 +0100
+++ b/python/tests/File.txt	Thu Jul 29 17:52:24 2010 +0100
@@ -49,11 +49,20 @@
   >>> f.close()
   >>> f.open()
+Test Reading different locations and proper internal overwriting of the file
   >>> f2 = file.File('../test/data/TO_core_last_clip.las')
   >>> p2 = f2.read(6)
   >>> p2.x, p2.y, p2.z
   (630320.95999999996, 4834500.0, 55.009999999999998)
+  >>> p2 == f2.read(3)
+  False
+  >>> p2.x == f2.read(6).x
+  True
   >>> f2.close()
   >>> del f2
@@ -305,7 +314,7 @@
   >>> h6.data_record_length
   52
 f.size - f.base_size will be 16 bytes of space (h6.data_record_length - 34 bytes for point format 3)
 >>> import ctypes
diff -r fe4def923c79 -r 52f24e850b32 src/detail/reader/header.cpp
--- a/src/detail/reader/header.cpp	Thu Jul 29 17:32:03 2010 +0100
+++ b/src/detail/reader/header.cpp	Thu Jul 29 17:52:24 2010 +0100
@@ -210,7 +210,7 @@
         m_header->SetPointRecordsByReturnCount(i, point_counts[i]);
-    delete point_counts;
+    delete[] point_counts;
     // 21-23. Scale factors
     read_n(x1, m_ifs, sizeof(x1));
More information about the Liblas-commits mailing list
