[Liblas-commits] hg: add curvature examples
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Jul 30 15:44:10 EDT 2010
changeset d6d11239f7a7 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d6d11239f7a7
summary: add curvature examples
diffstat:
 schemas/las.xml |  27 +++++++++++++++++++++++++++
 1 files changed, 27 insertions(+), 0 deletions(-)
diffs (35 lines):
diff -r 806bf114f336 -r d6d11239f7a7 schemas/las.xml
--- a/schemas/las.xml	Fri Jul 30 18:54:46 2010 +0100
+++ b/schemas/las.xml	Fri Jul 30 14:44:02 2010 -0500
@@ -200,4 +200,31 @@
         <minimum/>
         <maximum/>
     </ns1:dimension>
+    <ns1:dimension>
+        <name>Tangential curvature</name>
+        <description>
+            Second-order derivative of an interpolated DEM (elevation) surface
+            at this point.
+        </description>
+        <position>12</position>
+        <active>1</active>
+        <size>8</size>
+        <units>byte</units>
+        <interpretation>double</interpretation>
+        <minimum/>
+        <maximum/>
+    </ns1:dimension>
+    <ns1:dimension>
+        <name>Profile curvature</name>
+        <description>
+            at this point.
+        </description>
+        <size>8</size>
+        <minimum/>
+        <maximum/>
 </ns1:LASSchema>
More information about the Liblas-commits mailing list
