[Liblas-commits] hg: Define type of colour component as
Color::value_type. Use <b...
liblas-commits at liblas.org
Fri Jul 30 19:10:36 EDT 2010
changeset c92131892c45 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=c92131892c45
summary: Define type of colour component as Color::value_type. Use <boost/cstdint.hpp> as definition of portable integral types used by Color class.
diffstat:
include/liblas/lascolor.hpp | 47 ++++++++++++++++++++++----------------------
src/lascolor.cpp | 1 -
2 files changed, 24 insertions(+), 24 deletions(-)
diffs (149 lines):
diff -r dbc959d9ca2f -r c92131892c45 include/liblas/lascolor.hpp
--- a/include/liblas/lascolor.hpp Sat Jul 31 00:02:19 2010 +0100
+++ b/include/liblas/lascolor.hpp Sat Jul 31 00:10:25 2010 +0100
@@ -42,10 +42,10 @@
#ifndef LIBLAS_LASCOLOR_HPP_INCLUDED
#define LIBLAS_LASCOLOR_HPP_INCLUDED
-#include <liblas/cstdint.hpp>
#include <liblas/detail/fwd.hpp>
#include <liblas/detail/utility.hpp>
+// boost
+#include <boost/cstdint.hpp>
// std
#include <stdexcept> // std::out_of_range
#include <cstdlib> // std::size_t
@@ -57,13 +57,15 @@
public:
+ typedef boost::uint16_t value_type;
/// Default constructor.
/// Initializes with black color using RGB {0, 0, 0}.
Color();
// User-defined constructor.
// Initializes object with given RGB values.
- Color(uint16_t red, uint16_t green, uint16_t blue)
+ Color(value_type red, value_type green, value_type blue)
: m_red(red), m_green(green), m_blue(blue)
@@ -77,39 +79,38 @@
bool operator==(const Color& other) const;
/// Fetch value of the red image channel
- uint16_t GetRed() const;
+ value_type GetRed() const;
/// Set value of the red image channel
- void SetRed(uint16_t const& value);
+ void SetRed(value_type const& value);
/// Fetch value of the blue image channel
- uint16_t GetBlue() const;
+ value_type GetBlue() const;
/// Set value of the blue image channel
- void SetBlue(uint16_t const& value);
+ void SetBlue(value_type const& value);
/// Fetch value of the green image channel
- uint16_t GetGreen() const;
+ value_type GetGreen() const;
- void SetGreen(uint16_t const& value);
+ void SetGreen(value_type const& value);
/// Index operator providing access to RGB values.
/// Valid index values are 0, 1 or 2.
/// \exception std::out_of_range if requested index is out of range (> 2).
- uint16_t& operator[](std::size_t const& n);
+ value_type& operator[](std::size_t const& n);
/// Const version of index operator providing access to RGB values.
- uint16_t const& operator[](std::size_t const& n) const;
+ value_type const& operator[](std::size_t const& n) const;
private:
- uint16_t m_red;
- uint16_t m_green;
- uint16_t m_blue;
+ value_type m_red;
+ value_type m_green;
+ value_type m_blue;
void throw_out_of_range() const
@@ -118,37 +119,37 @@
-inline uint16_t Color::GetRed() const
+inline Color::value_type Color::GetRed() const
return m_red;
-inline void Color::SetRed(uint16_t const& value)
+inline void Color::SetRed(Color::value_type const& value)
m_red = value;
-inline uint16_t Color::GetBlue() const
+inline Color::value_type Color::GetBlue() const
return m_blue;
-inline void Color::SetBlue(uint16_t const& value)
+inline void Color::SetBlue(Color::value_type const& value)
m_blue = value;
-inline uint16_t Color::GetGreen() const
+inline Color::value_type Color::GetGreen() const
return m_green;
-inline void Color::SetGreen(uint16_t const& value)
+inline void Color::SetGreen(Color::value_type const& value)
m_green = value;
-inline uint16_t& Color::operator[](std::size_t const& n)
+inline Color::value_type& Color::operator[](std::size_t const& n)
if (n == 0) { return m_red; }
if (n == 1) { return m_green; }
@@ -157,7 +158,7 @@
throw_out_of_range();
-inline uint16_t const& Color::operator[](std::size_t const& n) const
+inline Color::value_type const& Color::operator[](std::size_t const& n) const
diff -r dbc959d9ca2f -r c92131892c45 src/lascolor.cpp
--- a/src/lascolor.cpp Sat Jul 31 00:02:19 2010 +0100
+++ b/src/lascolor.cpp Sat Jul 31 00:10:25 2010 +0100
@@ -40,7 +40,6 @@
#include <liblas/lascolor.hpp>
namespace liblas {
More information about the Liblas-commits
