[Liblas-commits] hg: Added FIXME comment to make use of shared_ptr
for robust lib...
liblas-commits at liblas.org
Sat Jul 31 21:11:45 EDT 2010
changeset 75fd8e2efbe1 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=75fd8e2efbe1
summary: Added FIXME comment to make use of shared_ptr for robust libtif resources management. Tidy up.
diffstat:
include/liblas/lasspatialreference.hpp | 13 ++++---
src/lasspatialreference.cpp | 57 ++++++++++++++++-----------------
2 files changed, 34 insertions(+), 36 deletions(-)
diffs (158 lines):
diff -r c0853bafd094 -r 75fd8e2efbe1 include/liblas/lasspatialreference.hpp
--- a/include/liblas/lasspatialreference.hpp Sun Aug 01 02:02:25 2010 +0100
+++ b/include/liblas/lasspatialreference.hpp Sun Aug 01 02:10:36 2010 +0100
@@ -105,7 +105,7 @@
~SpatialReference();
/// Constructor creating SpatialReference instance from given Variable-Length Record.
- SpatialReference(const std::vector<VariableRecord>& vlrs);
+ SpatialReference(std::vector<VariableRecord> const& vlrs);
/// Copy constryctor.
SpatialReference(SpatialReference const& other);
@@ -147,9 +147,9 @@
/// -1 if no value is available.
/// \param verticalUnits - the EPSG vertical units code, often 9001 for Metre.
void SetVerticalCS(int verticalCSType,
- std::string const& citation = "",
+ std::string const& citation = std::string(0),
int verticalDatum = -1,
- int verticalUnits = 9001 );
+ int verticalUnits = 9001);
/// Sets the SRS using GDAL's SetFromUserInput function. If GDAL is not linked, this
/// operation has no effect.
@@ -175,21 +175,22 @@
/// VLR records that pertain to the GeoTIFF keys, and extraneous
/// VLR records will not be copied.
/// \param vlrs - A list of VLRs that contains VLRs describing GeoTIFF keys
- void SetVLRs(const std::vector<VariableRecord>& vlrs);
+ void SetVLRs(std::vector<VariableRecord> const& vlrs);
/// Add a VLR representing GeoTIFF keys to the SRS
- void AddVLR(const VariableRecord& vlr);
+ void AddVLR(VariableRecord const& vlr);
/// Return a copy of the LASVLRs that SpatialReference maintains
std::vector<VariableRecord> GetVLRs() const;
private:
+ // FIXME: Define as shared_ptr<GTIF> with custom deleter to get rid of bloated mem management, unsafe anyway --mloskot
GTIF* m_gtiff;
ST_TIFF* m_tiff;
std::vector<VariableRecord> m_vlrs;
- bool IsGeoVLR(const VariableRecord& vlr) const;
+ bool IsGeoVLR(VariableRecord const& vlr) const;
/// Reset the VLRs of the SpatialReference using the existing GTIF* and ST_TIF*
/// Until this method is called,
diff -r c0853bafd094 -r 75fd8e2efbe1 src/lasspatialreference.cpp
--- a/src/lasspatialreference.cpp Sun Aug 01 02:02:25 2010 +0100
+++ b/src/lasspatialreference.cpp Sun Aug 01 02:10:36 2010 +0100
@@ -49,17 +49,32 @@
#include <string>
#include <vector>
-namespace liblas
+namespace liblas {
-SpatialReference::SpatialReference() :
- m_gtiff(0),
- m_tiff(0)
+SpatialReference::SpatialReference()
+ : m_gtiff(0)
+ , m_tiff(0)
assert(0 == m_gtiff);
assert(0 == m_tiff);
+SpatialReference::SpatialReference(std::vector<VariableRecord> const& vlrs)
+ : m_gtiff(0)
+ , m_tiff(0)
+ SetVLRs(vlrs);
+ GetGTIF();
+SpatialReference::SpatialReference(SpatialReference const& other)
+ : m_gtiff(0)
+ , m_tiff(0)
+ SetVLRs(other.GetVLRs());
+ GetGTIF();
SpatialReference& SpatialReference::operator=(SpatialReference const& rhs)
if (&rhs != this)
@@ -86,22 +101,6 @@
#endif
-SpatialReference::SpatialReference(SpatialReference const& other)
- m_tiff = 0;
- m_gtiff = 0;
- SetVLRs(other.GetVLRs());
- GetGTIF();
-SpatialReference::SpatialReference(std::vector<VariableRecord> const& vlrs)
- m_tiff = 0;
- m_gtiff = 0;
- SetVLRs(vlrs);
- GetGTIF();
/// Keep a copy of the VLRs that are related to GeoTIFF SRS information.
void SpatialReference::SetVLRs(std::vector<VariableRecord> const& vlrs)
@@ -295,8 +294,8 @@
m_gtiff = (GTIF*)pgtiff;
m_tiff = (ST_TIFF*)ptiff;
ResetVLRs();
- m_gtiff = NULL;
- m_tiff = NULL;
+ m_gtiff = 0;
+ m_tiff = 0;
const GTIF* SpatialReference::GetGTIF()
@@ -421,7 +420,7 @@
#endif
-void SpatialReference::SetFromUserInput( std::string const& v)
+void SpatialReference::SetFromUserInput(std::string const& v)
#ifdef HAVE_GDAL
@@ -476,11 +475,10 @@
#endif
-void SpatialReference::SetVerticalCS( int verticalCSType,
- std::string const& citation,
- int verticalDatum,
- int verticalUnits )
+void SpatialReference::SetVerticalCS(int verticalCSType,
+ std::string const& citation,
+ int verticalDatum,
+ int verticalUnits)
if (!m_gtiff)
@@ -519,7 +517,6 @@
#endif /* def HAVE_LIBGEOTIFF */
std::string SpatialReference::GetProj4() const
#ifdef HAVE_GDAL
More information about the Liblas-commits
