[Liblas-commits] hg: 4 new changesets
liblas-commits at liblas.org
Tue Jun 8 13:57:51 EDT 2010
changeset 252b784f5492 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=252b784f5492
summary: use std::vector<uint8_t> instead of std::vector<bool> and use std::vector<uint8_t>::size_type for our cache size operations to preserve precision
changeset 89ca04840d24 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=89ca04840d24
summary: ignore unused variable
changeset 5940536de7e4 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=5940536de7e4
summary: suppress warning about EQUAL and EQUALN from GDAL for all but /W4. We have redefined those.
changeset fbb7f83ddd6e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=fbb7f83ddd6e
summary: Default to release mode building
diffstat:
CMakeLists.txt | 9 ++++-----
include/liblas/detail/reader/reader.hpp | 11 ++++++-----
include/liblas/lasfilter.hpp | 2 +-
src/detail/reader/reader.cpp | 33 +++++++++++++++++----------------
src/gt_citation.cpp | 8 ++++++--
5 files changed, 34 insertions(+), 29 deletions(-)
diffs (190 lines):
diff -r 1111988c675c -r fbb7f83ddd6e CMakeLists.txt
--- a/CMakeLists.txt Mon Jun 07 21:38:50 2010 -0500
+++ b/CMakeLists.txt Tue Jun 08 11:57:27 2010 -0600
@@ -62,11 +62,10 @@
# General build settings
-if(NOT CMAKE_BUILD_TYPE)
- set(CMAKE_BUILD_TYPE Debug CACHE STRING
- "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel"
- FORCE)
-endif()
+# Default to release mode
+set(CMAKE_BUILD_TYPE Release CACHE STRING
+ "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel"
+ FORCE)
set(BUILD_PEDANTIC TRUE CACHE BOOL "Choose compilation in pedantic or relaxed mode")
diff -r 1111988c675c -r fbb7f83ddd6e include/liblas/detail/reader/reader.hpp
--- a/include/liblas/detail/reader/reader.hpp Mon Jun 07 21:38:50 2010 -0500
+++ b/include/liblas/detail/reader/reader.hpp Tue Jun 08 11:57:27 2010 -0600
@@ -110,7 +110,7 @@
public:
- CachedReaderImpl(std::istream& ifs, liblas::uint64_t cache_size);
+ CachedReaderImpl(std::istream& ifs, std::size_t cache_size);
// ~CachedReaderImpl();
liblas::Header const& ReadHeader();
@@ -132,13 +132,14 @@
void CacheData(liblas::uint32_t position, const liblas::Header& header);
- liblas::uint64_t m_cache_size;
- std::vector<bool> m_mask;
+ std::vector<uint8_t>::size_type m_cache_size;
+ std::vector<uint8_t> m_mask;
- liblas::uint64_t m_cache_start_position;
- liblas::uint64_t m_cache_read_position;
+ std::vector<uint8_t>::size_type m_cache_start_position;
+ std::vector<uint8_t>::size_type m_cache_read_position;
std::vector<liblas::Point> m_cache;
// class ReaderFactory
diff -r 1111988c675c -r fbb7f83ddd6e include/liblas/lasfilter.hpp
--- a/include/liblas/lasfilter.hpp Mon Jun 07 21:38:50 2010 -0500
+++ b/include/liblas/lasfilter.hpp Tue Jun 08 11:57:27 2010 -0600
@@ -61,7 +61,7 @@
BoundsFilter(double minx, double miny, double maxx, double maxy);
BoundsFilter(double minx, double miny, double maxx, double maxy, double minz, double maxz);
bool filter(const Point& point);
- void SetKeep(bool bKeep) {return;}
+ void SetKeep(bool bKeep) {detail::ignore_unused_variable_warning(bKeep); return;}
private:
double mins[3];
double maxs[3];
diff -r 1111988c675c -r fbb7f83ddd6e src/detail/reader/reader.cpp
--- a/src/detail/reader/reader.cpp Mon Jun 07 21:38:50 2010 -0500
+++ b/src/detail/reader/reader.cpp Tue Jun 08 11:57:27 2010 -0600
@@ -258,7 +258,7 @@
m_current = n+1;
-CachedReaderImpl::CachedReaderImpl(std::istream& ifs , liblas::uint64_t size) :
+CachedReaderImpl::CachedReaderImpl(std::istream& ifs , std::size_t size) :
ReaderImpl(ifs), m_cache_size(size), m_cache_start_position(0), m_cache_read_position(0)
@@ -281,7 +281,7 @@
// Mark all positions as uncached and build up the mask
// to the size of the number of points in the file
for (uint32_t i = 0; i < header.GetPointRecordsCount(); ++i) {
- m_mask.push_back(false);
+ m_mask.push_back(0);
@@ -293,11 +293,12 @@
int32_t old_cache_start_position = m_cache_start_position;
m_cache_start_position = position;
- uint32_t left_to_cache = std::min(m_cache_size, header.GetPointRecordsCount() - m_cache_start_position);
+ std::vector<uint8_t>::size_type header_size = static_cast<std::vector<uint8_t>::size_type>(header.GetPointRecordsCount());
+ std::vector<uint8_t>::size_type left_to_cache = std::min(m_cache_size, header_size - m_cache_start_position);
- uint32_t to_mark = std::max(m_cache_size, static_cast<liblas::uint64_t>(left_to_cache));
+ std::vector<uint8_t>::size_type to_mark = std::max(m_cache_size, left_to_cache);
for (uint32_t i = 0; i < to_mark; ++i) {
- m_mask[old_cache_start_position + i] = false;
+ m_mask[old_cache_start_position + i] = 0;
// if these aren't equal, we've hopped around with ReadPointAt
@@ -311,7 +312,7 @@
for (uint32_t i = 0; i < left_to_cache; ++i)
try {
- m_mask[m_current] = true;
+ m_mask[m_current] = 1;
m_cache[i] = ReaderImpl::ReadNextPoint(header);
} catch (std::out_of_range&) {
// cached to the end
@@ -332,7 +333,7 @@
// std::cout << std::endl;
- if (m_mask[position] == true) {
+ if (m_mask[position] == 1) {
m_cache_read_position = position;
return m_cache[cache_position];
} else {
@@ -353,7 +354,7 @@
throw std::runtime_error(out);
if (static_cast<uint32_t>(cache_position) > m_cache.size()) {
std::ostringstream output;
output << "ReadCachedPoint:: cache position: "
@@ -373,7 +374,6 @@
- return m_cache[cache_position];
@@ -412,13 +412,13 @@
if (m_mask.size() > 0) {
- // Mark old points as uncached
- m_mask[m_cache_start_position + i] = false;
+ m_mask[m_cache_start_position + i] = 0;
m_cache_start_position = 0;
@@ -444,11 +444,12 @@
void CachedReaderImpl::SetOutputSRS(const SpatialReference& srs, const liblas::Header& header)
// We need to wipe out the cache if we've set the output srs.
ReaderImpl::SetOutputSRS(srs, header);
diff -r 1111988c675c -r fbb7f83ddd6e src/gt_citation.cpp
--- a/src/gt_citation.cpp Mon Jun 07 21:38:50 2010 -0500
+++ b/src/gt_citation.cpp Tue Jun 08 11:57:27 2010 -0600
@@ -35,12 +35,16 @@
#include "geovalues.h"
#include "ogr_spatialref.h"
+// Ignore warning about redifinition. We need to use
+// the new windows functions for this. We'll only
+// warn on MSVC with /W4
+#pragma warning( 4: 4005)
#if defined(WIN32)
# define EQUALN(a,b,n) (_strnicmp(a,b,n)==0)
# define EQUAL(a,b) (_stricmp(a,b)==0)
#endif
+#pragma warning( default: 4005)
#define nCitationNameTypes 9
typedef enum
More information about the Liblas-commits
