[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jun 15 16:02:28 EDT 2010
changeset 73a24d23839a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=73a24d23839a
summary: ignore osgeo4w stuff
changeset 924eafa59d52 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=924eafa59d52
summary: bump versions to 1.6.0
changeset 4cfbd9f38310 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=4cfbd9f38310
summary: more osgeo4w packaging
diffstat:
 .hgignore                         |    1 +
 CMakeLists.txt                    |   10 +++-
 cmake/modules/BuildOSGeo4W.cmake  |  112 +++++++++++++++++++++++++------------
 include/liblas/capi/las_version.h |    4 +-
 python/setup.py                   |    2 +-
 5 files changed, 89 insertions(+), 40 deletions(-)
diffs (227 lines):
diff -r 30464a12bc58 -r 4cfbd9f38310 .hgignore
--- a/.hgignore	Tue Jun 15 09:50:10 2010 -0500
+++ b/.hgignore	Tue Jun 15 15:02:20 2010 -0500
@@ -91,3 +91,4 @@
 *.mshark
 Testing/
 README.txt
+osgeo4w/
diff -r 30464a12bc58 -r 4cfbd9f38310 CMakeLists.txt
--- a/CMakeLists.txt	Tue Jun 15 09:50:10 2010 -0500
+++ b/CMakeLists.txt	Tue Jun 15 15:02:20 2010 -0500
@@ -14,7 +14,7 @@
 # Version information
 SET(CPACK_PACKAGE_VERSION_MAJOR "1")
-SET(CPACK_PACKAGE_VERSION_MINOR "3")
+SET(CPACK_PACKAGE_VERSION_MINOR "6")
 SET(CPACK_PACKAGE_VERSION_PATCH "0")
 if(WIN32)
@@ -121,6 +121,14 @@
     endif()
 endif(WIN32)
+if (APPLE)
+    set(SO_EXT dylib)
+elseif(WIN32)
+    set(SO_EXT dll)
+else()
+    set(SO_EXT so)
+endif(APPLE)
 # Search for dependencies
diff -r 30464a12bc58 -r 4cfbd9f38310 cmake/modules/BuildOSGeo4W.cmake
--- a/cmake/modules/BuildOSGeo4W.cmake	Tue Jun 15 09:50:10 2010 -0500
+++ b/cmake/modules/BuildOSGeo4W.cmake	Tue Jun 15 15:02:20 2010 -0500
@@ -4,7 +4,7 @@
-MESSAGE(STATUS "   Building osgeo4w binaries")
+MESSAGE(STATUS "Building osgeo4w binaries")
 set(OSGEO4W_DIR osgeo4w)
 set(OSGEO4W_LIB_DIR ${OSGEO4W_DIR}/lib)
 set(OSGEO4W_LIB_BIN_DIR ${OSGEO4W_DIR}/lib/bin)
@@ -12,8 +12,10 @@
 set(OSGEO4W_DEVEL_INCLUDE_DIR ${OSGEO4W_DEVEL_DIR}/include)
 set(OSGEO4W_DEVEL_INCLUDE_LIBLAS_DIR ${OSGEO4W_DEVEL_INCLUDE_DIR}/liblas)
 set(OSGEO4W_DEVEL_LIB_DIR ${OSGEO4W_DEVEL_DIR}/lib)
+set(OSGEO4W_DEVEL_BIN_DIR ${OSGEO4W_DEVEL_DIR}/bin)
 set(OSGEO4W_PYTHON_DIR ${OSGEO4W_DIR}/apps/python25/lib/site-packages/liblas)
+set(OSGEO4W_PACKAGES ${OSGEO4W_DIR}/packages)
 set(OSGEO4W_DIRECTORIES
@@ -24,62 +26,100 @@
     ${OSGEO4W_DEVEL_INCLUDE_LIBLAS_DIR}
     ${OSGEO4W_DEVEL_LIB_DIR}
-    ${OSGEO4W_PYTHON_DIR})
+    ${OSGEO4W_PYTHON_DIR}
+    ${OSGEO4W_DEVEL_BIN_DIR}
+    ${OSGEO4W_PACKAGES})
-add_custom_target(BuildOSGeo4WDirectories
+add_custom_target(make_osgeo4w_directories
   COMMAND ${CMAKE_COMMAND} -E echo "Building OSGeo4W install directories")
-macro (MAKE_OSGEO4W_DIRECTORIES)
+macro (make_directories)
+    add_custom_command(
+      TARGET make_osgeo4w_directories
+      COMMAND ${CMAKE_COMMAND} -E  remove_directory  ${libLAS_SOURCE_DIR}/osgeo4w DEPENDS osgeo4w
    foreach(directory ${OSGEO4W_DIRECTORIES})
     STRING(REGEX REPLACE "/" "_" target "${directory}" )
-    add_custom_target(${target}
-      COMMAND ${CMAKE_COMMAND} -E make_directory ${directory} )
+      COMMAND ${CMAKE_COMMAND} -E make_directory ${directory}
-      add_dependencies( BuildOSGeo4WDirectories ${target} )
    endforeach()
+endmacro(make_directories)
-endmacro(MAKE_OSGEO4W_DIRECTORIES)
-if (APPLE)
-    set(SO_EXT dylib)
-elseif(WIN32)
-    set(SO_EXT dll)
-else()
-    set(SO_EXT so)
-endif(APPLE)
-set(OSGEO4W_FILES
-    ${LIBLAS_BUILD_OUTPUT_DIRECTORY};${OSGEO4W_LIB_BIN_DIR}
-    ${libLAS_SOURCE_DIR};${OSGEO4W_DEVEL_INCLUDE_LIBLAS_DIR}
+# add_custom_target(CopyOSGeo4WFiles
+#   COMMAND ${CMAKE_COMMAND} -E echo "Copying OSGeo4W files...")
-add_custom_target(CopyOSGeo4WFiles
-  COMMAND ${CMAKE_COMMAND} -E echo "Copying OSGeo4W files...")
-add_dependencies( CopyOSGeo4WFiles BuildOSGeo4WDirectories   )
+add_custom_target(copy ALL COMMENT "Copying OSGeo4W files")
+add_dependencies( copy make_osgeo4w_directories   )
-macro (COPY_OSGEO4W_DIRECTORIES source destination)
-   message(STATUS "Copying ${source} to ${destination}...")
-    STRING(REGEX REPLACE "/" "_" target "${destination}" )
+macro(copy_files GLOBPAT DESTINATION  )
+    MESSAGE(STATUS "   Copying ${GLOBPAT} to ${DESTINATION}")
+    file(GLOB_RECURSE COPY_FILES
+         RELATIVE ${CMAKE_CURRENT_SOURCE_DIR}
+        ${GLOBPAT})
+#    MESSAGE(STATUS "   files to copy ${COPY_FILES}  ${DESTINATION}")
+  foreach(FILENAME ${COPY_FILES})
+    set(SRC "${FILENAME}")
+        set(DST "${DESTINATION}")
-    add_custom_target(copy_${target}
-      COMMAND ${CMAKE_COMMAND} -E copy_directory ${source} ${destination})
+      TARGET copy
+      COMMAND ${CMAKE_COMMAND} -E copy ${SRC} ${DST}
+  endforeach(FILENAME)
+endmacro(copy_files)
-      add_dependencies( CopyOSGeo4WFiles copy_${target} )
+add_custom_target(tar
+  COMMAND ${CMAKE_COMMAND} -E echo "Tarring OSGeo4W install")
+add_dependencies( tar copy   )
-endmacro(COPY_OSGEO4W_DIRECTORIES source destination)
+macro (tar_directories source destination base_path)
-MAKE_OSGEO4W_DIRECTORIES()
-COPY_OSGEO4W_DIRECTORIES(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/ ${OSGEO4W_LIB_BIN_DIR}/)
-COPY_OSGEO4W_DIRECTORIES(${libLAS_SOURCE_DIR}/include/liblas ${OSGEO4W_DEVEL_INCLUDE_LIBLAS_DIR}/)
-COPY_OSGEO4W_DIRECTORIES(${libLAS_SOURCE_DIR}/python/liblas/*.py ${OSGEO4W_PYTHON_DIR}/)
+    MESSAGE(STATUS "   Tarring ${source} to ${destination}")
+      TARGET tar
+      COMMAND ${CMAKE_COMMAND} -E chdir ${source} cmake -E tar czf  ${destination} ${base_path}/
+endmacro(tar_directories)
+make_directories()
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/las* ${OSGEO4W_DEVEL_BIN_DIR}/  )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*[.${SO_EXT}] ${OSGEO4W_DEVEL_BIN_DIR}/  )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*.lib ${OSGEO4W_DEVEL_LIB_DIR}/  )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*.a ${OSGEO4W_DEVEL_LIB_DIR}/  )
+copy_files(./include/liblas/* ${OSGEO4W_DEVEL_INCLUDE_LIBLAS_DIR}/  )
+copy_files(./python/liblas/*.py ${OSGEO4W_PYTHON_DIR}/  )
+tar_directories(${OSGEO4W_DEVEL_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}.tar.gz bin)
+tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-python-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}.tar.gz apps)
+tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-devel-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}.tar.gz devel)
+add_custom_target(osgeo4w
+  COMMAND ${CMAKE_COMMAND} -E echo "Making OSGeo4W build")
+add_custom_command(
+  TARGET osgeo4w
+add_dependencies( osgeo4w tar   )
diff -r 30464a12bc58 -r 4cfbd9f38310 include/liblas/capi/las_version.h
--- a/include/liblas/capi/las_version.h	Tue Jun 15 09:50:10 2010 -0500
+++ b/include/liblas/capi/las_version.h	Tue Jun 15 15:02:20 2010 -0500
@@ -44,7 +44,7 @@
 #ifndef LIBLAS_VERSION_MAJOR
 #define LIBLAS_VERSION_MAJOR    1
-#define LIBLAS_VERSION_MINOR    3
+#define LIBLAS_VERSION_MINOR    6
 #define LIBLAS_VERSION_REV      0
 #define LIBLAS_VERSION_BUILD    0
 #endif
@@ -58,7 +58,7 @@
 #endif
 #ifndef LIBLAS_RELEASE_NAME
-#define LIBLAS_RELEASE_NAME     "1.3.0"
+#define LIBLAS_RELEASE_NAME     "1.6.0"
 #endif
 #endif /* LAS_VERSION_H_INCLUDED */
diff -r 30464a12bc58 -r 4cfbd9f38310 python/setup.py
--- a/python/setup.py	Tue Jun 15 09:50:10 2010 -0500
+++ b/python/setup.py	Tue Jun 15 15:02:20 2010 -0500
@@ -18,7 +18,7 @@
 import os
-version = '1.3.0'
+version = '1.6.0'
 if os.name == 'nt':
     # Windows NT library
More information about the Liblas-commits mailing list
