[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Fri Jun 18 11:07:13 EDT 2010
changeset 6e77d643eb1f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6e77d643eb1f
summary: typo
changeset 9a061e681940 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9a061e681940
summary: partial fix for #147, seeking off the end of the file
diffstat:
doc/compilation.txt | 2 +-
src/detail/writer/header.cpp | 17 ++++++++++-------
2 files changed, 11 insertions(+), 8 deletions(-)
diffs (51 lines):
diff -r 14da39665f17 -r 9a061e681940 doc/compilation.txt
--- a/doc/compilation.txt Thu Jun 17 20:57:42 2010 -0500
+++ b/doc/compilation.txt Fri Jun 18 10:07:04 2010 -0500
@@ -569,7 +569,7 @@
.. note::
If you are building using `OSGeo4W`_ libraries, you must use the "gdal-dev"
- version, not the base `GDAL`_ build. libLAS requires GDDAL 1.7+ to
+ version, not the base `GDAL`_ build. libLAS requires GDAL 1.7+ to
operate, and this is provided by the "gdal-dev" `OSGeo4W`_ version.
.. note::
diff -r 14da39665f17 -r 9a061e681940 src/detail/writer/header.cpp
--- a/src/detail/writer/header.cpp Thu Jun 17 20:57:42 2010 -0500
+++ b/src/detail/writer/header.cpp Fri Jun 18 10:07:04 2010 -0500
@@ -74,6 +74,8 @@
// Rewrite the georeference VLR entries if they exist
m_header.SetGeoreference();
+ // Figure out how many points we already have.
// Seek to the beginning
GetStream().seekp(0, std::ios::beg);
std::ios::pos_type beginning = GetStream().tellp();
@@ -81,18 +83,19 @@
// Seek to the end
GetStream().seekp(0, std::ios::end);
std::ios::pos_type end = GetStream().tellp();
- // Figure out how many points we already have. Each point record
- // should be 20 bytes long, and header.GetDataOffset tells
- // us the location to start counting points from.
+ // std::ios::off_type size = end - beginning;
+ std::ios::off_type count = (end - static_cast<std::ios::off_type>(m_header.GetDataOffset())) /
+ static_cast<std::ios::off_type>(m_header.GetDataRecordLength());
// This test should only be true if we were opened in both
// std::ios::in *and* std::ios::out, otherwise it should return false
// and we won't adjust the point count.
- if ((beginning != end) && ((uint32_t)end != 0)) {
- uint32_t count = ((uint32_t) end - m_header.GetDataOffset())/m_header.GetDataRecordLength();
- SetPointCount(count);
+ if ((beginning != end) && (end != 0)) {
+ liblas::uint32_t& cnt = GetPointCount();
+ cnt = static_cast<liblas::uint32_t>(count);
+ SetPointCount(cnt);
// Position to the beginning of the file to start writing the header
More information about the Liblas-commits
