[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Jun 30 14:00:45 EDT 2010
changeset ecfe8d357fe6 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ecfe8d357fe6
summary: support reading minor version [0-3]
changeset abe68fe6a1a4 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=abe68fe6a1a4
summary: finish up implementing FilterI and TransformI, and reimplement reprojection machinery to use TransformI framework #184
diffstat:
 include/liblas/detail/reader/point.hpp  |   10 --
 include/liblas/detail/reader/reader.hpp |   24 ++---
 include/liblas/detail/writer/writer.hpp |   13 +--
 include/liblas/lasreader.hpp            |   19 ++++-
 include/liblas/lastransform.hpp         |   34 ++++++++
 include/liblas/laswriter.hpp            |   26 ++++++-
 include/liblas/liblas.hpp               |   13 +--
 python/tests/SRS-GDAL.txt               |    2 +-
 src/detail/reader/point.cpp             |   53 +------------
 src/detail/reader/reader.cpp            |  124 ++++---------------------------
 src/detail/writer/writer.cpp            |   82 +--------------------
 src/lasreader.cpp                       |  124 +++++++++++++++++++++++++++----
 src/lastransform.cpp                    |   94 ++++++++++++++++++++++++
 src/laswriter.cpp                       |  110 +++++++++++++++++++++++++++-
 test/unit/lasheader_test.cpp            |    6 +-
 15 files changed, 425 insertions(+), 309 deletions(-)
diffs (truncated from 1180 to 300 lines):
diff -r 77b2979fc354 -r abe68fe6a1a4 include/liblas/detail/reader/point.hpp
--- a/include/liblas/detail/reader/point.hpp	Tue Jun 29 14:22:54 2010 -0500
+++ b/include/liblas/detail/reader/point.hpp	Wed Jun 30 13:00:33 2010 -0500
@@ -51,11 +51,6 @@
 #include <liblas/lasformat.hpp>
-#ifndef HAVE_GDAL
-    typedef struct OGRCoordinateTransformationHS *OGRCoordinateTransformationH;
-    typedef struct OGRSpatialReferenceHS *OGRSpatialReferenceH;
-#endif
 // std
 #include <iosfwd>
@@ -66,9 +61,6 @@
 public:
     Point(std::istream& ifs, const liblas::Header& header);
-    Point(  std::istream& ifs,
-            const liblas::Header& header,
-            OGRCoordinateTransformationH transform);
     virtual ~Point();
     std::istream& GetStream() const;
@@ -90,11 +82,9 @@
     std::istream& m_ifs;
     const liblas::Header& m_header;
     liblas::Point m_point;
-    OGRCoordinateTransformationH m_transform;
     PointFormat m_format;
-    void project();
     void setup();
     void fill(PointRecord& record);
diff -r 77b2979fc354 -r abe68fe6a1a4 include/liblas/detail/reader/reader.hpp
--- a/include/liblas/detail/reader/reader.hpp	Tue Jun 29 14:22:54 2010 -0500
+++ b/include/liblas/detail/reader/reader.hpp	Wed Jun 30 13:00:33 2010 -0500
@@ -51,12 +51,6 @@
 #include <iosfwd>
-#ifndef HAVE_GDAL
-#endif
 namespace liblas { namespace detail {
 class ReaderImpl : public ReaderI
@@ -74,9 +68,9 @@
     void Reset(liblas::Header const& header);
-    void SetSRS(const SpatialReference& srs, const liblas::Header& header);
-    void SetInputSRS(const SpatialReference& srs);
-    void SetOutputSRS(const SpatialReference& srs, const liblas::Header& header);
+    // void SetSRS(const SpatialReference& srs, const liblas::Header& header);
+    // void SetInputSRS(const SpatialReference& srs);
+    // void SetOutputSRS(const SpatialReference& srs, const liblas::Header& header);
 protected:
     void CreateTransform();
@@ -89,11 +83,11 @@
     uint32_t m_size;
     uint32_t m_current;
-    SpatialReference m_out_srs;
-    SpatialReference m_in_srs;
-    OGRSpatialReferenceH m_in_ref;
-    OGRSpatialReferenceH m_out_ref;
+    // SpatialReference m_out_srs;
+    // SpatialReference m_in_srs;
+    // OGRCoordinateTransformationH m_transform;
+    // OGRSpatialReferenceH m_in_ref;
+    // OGRSpatialReferenceH m_out_ref;
     detail::reader::Point* m_point_reader;
     detail::reader::Header* m_header_reader;
@@ -116,7 +110,7 @@
     liblas::Header const& ReadHeader();
     liblas::Point const& ReadNextPoint(const liblas::Header& header);
     liblas::Point const& ReadPointAt(std::size_t n, const liblas::Header& header);
     void Seek(std::size_t n, const liblas::Header& header);
diff -r 77b2979fc354 -r abe68fe6a1a4 include/liblas/detail/writer/writer.hpp
--- a/include/liblas/detail/writer/writer.hpp	Tue Jun 29 14:22:54 2010 -0500
+++ b/include/liblas/detail/writer/writer.hpp	Wed Jun 30 13:00:33 2010 -0500
@@ -64,26 +64,17 @@
     std::ostream& GetStream() const;
 protected:
     PointRecord m_record;
     std::ostream& m_ofs;
     writer::Point* m_point_writer;
     writer::Header* m_header_writer;
 private:
-    void CreateTransform();
+    // void CreateTransform();
     liblas::uint32_t m_pointCount;
     // block copying operations
diff -r 77b2979fc354 -r abe68fe6a1a4 include/liblas/lasreader.hpp
--- a/include/liblas/lasreader.hpp	Tue Jun 29 14:22:54 2010 -0500
+++ b/include/liblas/lasreader.hpp	Wed Jun 30 13:00:33 2010 -0500
@@ -50,6 +50,8 @@
 #include <liblas/laspoint.hpp>
 #include <liblas/lasvariablerecord.hpp>
 #include <liblas/lasspatialreference.hpp>
+#include <liblas/lastransform.hpp>
 // std
@@ -144,8 +146,19 @@
     /// keep a point that was read from the file.  Filters have *no*
     /// effect for reading data at specific locations in the file.
     /// They only affect reading ReadNextPoint-style operations
+    /// Filters are applied *before* transforms.
     void SetFilters(std::vector<liblas::FilterI*>* filters) {m_filters = filters;}
+    /// Sets transforms to apply to points.  Points are transformed in
+    /// place *in the order* of the transform list.
+    /// Filters are applied *before* transforms.  If an input/output SRS
+    /// is set on the reader, the reprojection transform will happen *first*
+    /// before any other transforms are applied.  This transform is a
+    /// special case.  You can define your own reprojection transforms and add
+    /// it to the list, but be sure to not issue a SetOutputSRS to trigger
+    /// the internal transform creation
+    void SetTransforms(std::vector<liblas::TransformI*>* transforms) {m_transforms = transforms;}
 private:
     // Blocked copying operations, declared but not defined.
@@ -164,8 +177,12 @@
     bool bCustomHeader;
     std::vector<liblas::FilterI*>* m_filters;
+    std::vector<liblas::TransformI*>* m_transforms;
-    // std::istream& m_ifs;
+    liblas::TransformI* m_reprojection_transform;
+    SpatialReference m_out_srs;
+    SpatialReference m_in_srs;
diff -r 77b2979fc354 -r abe68fe6a1a4 include/liblas/lastransform.hpp
--- a/include/liblas/lastransform.hpp	Tue Jun 29 14:22:54 2010 -0500
+++ b/include/liblas/lastransform.hpp	Wed Jun 30 13:00:33 2010 -0500
@@ -47,13 +47,47 @@
 #include <liblas/detail/fwd.hpp>
 #include <liblas/liblas.hpp>
+#include <liblas/lasspatialreference.hpp>
 #include <vector>
 namespace liblas
+// class TransformI
+// public:
+//     virtual bool transform(Point& point) = 0;
+//     virtual ~TransformI() {};
+#ifndef HAVE_GDAL
+    typedef struct OGRCoordinateTransformationHS *OGRCoordinateTransformationH;
+    typedef struct OGRSpatialReferenceHS *OGRSpatialReferenceH;
+#endif
+class ReprojectionTransform: public TransformI
+public:
+    ReprojectionTransform(const SpatialReference& inSRS, const SpatialReference& outSRS);
+    bool transform(Point& point);
+    ~ReprojectionTransform();
+private:
+    OGRCoordinateTransformationH m_transform;
+    OGRSpatialReferenceH m_in_ref;
+    OGRSpatialReferenceH m_out_ref;
+    ReprojectionTransform(ReprojectionTransform const& other);
+    ReprojectionTransform& operator=(ReprojectionTransform const& rhs);
 } // namespace liblas
diff -r 77b2979fc354 -r abe68fe6a1a4 include/liblas/laswriter.hpp
--- a/include/liblas/laswriter.hpp	Tue Jun 29 14:22:54 2010 -0500
+++ b/include/liblas/laswriter.hpp	Wed Jun 30 13:00:33 2010 -0500
@@ -45,6 +45,8 @@
 #include <liblas/lasversion.hpp>
 #include <liblas/lasheader.hpp>
+#include <liblas/lasfilter.hpp>
@@ -94,6 +96,21 @@
     bool SetSRS(const SpatialReference& ref);
     bool SetInputSRS(const SpatialReference& ref);
     bool SetOutputSRS(const SpatialReference& ref);
+    /// Sets filters that are used to determine wither or not to
+    /// keep a point that before we write it
+    void SetFilters(std::vector<liblas::FilterI*>* filters) {m_filters = filters;}
+    /// is set on the writer, the reprojection transform will happen *first*
 private:
@@ -105,8 +122,15 @@
     Header m_header;
     detail::PointRecord m_record;
-    // std::ostream& m_ofs;
+    std::vector<liblas::FilterI*>* m_filters;
diff -r 77b2979fc354 -r abe68fe6a1a4 include/liblas/liblas.hpp
--- a/include/liblas/liblas.hpp	Tue Jun 29 14:22:54 2010 -0500
+++ b/include/liblas/liblas.hpp	Wed Jun 30 13:00:33 2010 -0500
@@ -160,8 +160,6 @@
     virtual void Seek(std::size_t n, const Header& header) = 0;
     virtual void Reset(const Header& header) = 0;
-    virtual void SetInputSRS(const SpatialReference& srs) = 0;
-    virtual void SetOutputSRS(const SpatialReference& srs, const Header& header) = 0;
     virtual std::istream& GetStream() const = 0;
@@ -176,9 +174,6 @@
     virtual void UpdateHeader(const Header& header) = 0;
     virtual void WritePoint(const Point& point, const Header& header) = 0;
     virtual std::ostream& GetStream() const = 0;
     virtual ~WriterI() {};
@@ -207,12 +202,12 @@
     FilterI(FilterType t) : m_type(t) {}
-    private:
+private:
More information about the Liblas-commits mailing list
