[Liblas-commits] hg: 6 new changesets
liblas-commits at liblas.org
Tue Mar 16 13:01:37 EDT 2010
changeset 0f93db236833 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0f93db236833
summary: we don't do anything with the exception, so we don't need to reference it
changeset 7845cc6c99cc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=7845cc6c99cc
summary: Use uint32_t instead of uint16_t for the size. From a practical standpoint, no one's probably going to legitimately use the full extent of either the short or the long for a point format size though
changeset 840292ef18b5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=840292ef18b5
summary: clean up unreferenced warnings
changeset 9949610683c5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9949610683c5
summary: clean up msvc warnings about throwing when extern and bool coersion warnings
changeset 2a5e2f4bf6f8 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2a5e2f4bf6f8
summary: fix uint16_t vs uint32_t coersion when we go from the PointFormat's byte size to the header's point size
changeset 6eb35a2161cd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6eb35a2161cd
summary: fix so it works again
diffstat:
apps/ts2las.cpp | 6 ++--
include/liblas/lasformat.hpp | 2 +-
src/las_c_api.cpp | 64 ++++++++++++++++++++++++-------------------
src/lasheader.cpp | 13 ++++++--
src/lasreader.cpp | 4 +-
src/makefile.vc | 18 +++++------
6 files changed, 58 insertions(+), 49 deletions(-)
diffs (237 lines):
diff -r b1244e1f9b8b -r 6eb35a2161cd apps/ts2las.cpp
--- a/apps/ts2las.cpp Tue Mar 16 00:29:51 2010 +0000
+++ b/apps/ts2las.cpp Tue Mar 16 11:01:01 2010 -0600
@@ -115,7 +115,7 @@
if (( version > 20020715) && (version < 20051231)) return true;
return false;
- catch (std::exception const& e)
+ catch (std::exception const)
return false;
@@ -212,13 +212,13 @@
try {
writer->WritePoint(p);
- } catch (std::exception const& e)
+ } catch (std::exception)
std::cout << "Point writing failed!" << std::endl;
- catch (std::out_of_range const& e) // we reached the end of the file
+ catch (std::out_of_range) // we reached the end of the file
std::cout << "catching out of range error!" ;
return true;
diff -r b1244e1f9b8b -r 6eb35a2161cd include/liblas/lasformat.hpp
--- a/include/liblas/lasformat.hpp Tue Mar 16 00:29:51 2010 +0000
+++ b/include/liblas/lasformat.hpp Tue Mar 16 11:01:01 2010 -0600
@@ -90,7 +90,7 @@
protected:
- liblas::uint16_t m_size;
+ liblas::uint32_t m_size;
liblas::uint8_t m_versionminor;
liblas::uint8_t m_versionmajor;
diff -r b1244e1f9b8b -r 6eb35a2161cd src/las_c_api.cpp
--- a/src/las_c_api.cpp Tue Mar 16 00:29:51 2010 +0000
+++ b/src/las_c_api.cpp Tue Mar 16 11:01:01 2010 -0600
@@ -77,6 +77,36 @@
using namespace liblas;
+#ifdef _WIN32
+#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
+#else
+#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
+#endif
+std::istream* OpenInput(std::string filename)
+ std::ios::openmode const mode = std::ios::in | std::ios::binary;
+ std::istream* istrm = 0;
+ if (compare_no_case(filename.c_str(),"STDIN",5) == 0)
+ istrm = &std::cin;
+ else
+ istrm = new std::ifstream(filename.c_str(), mode);
+ if (!istrm->good())
+ delete istrm;
+ throw std::runtime_error("Reading stream was not able to be created");
+ return istrm;
LAS_C_START
#ifndef _WIN32
@@ -88,11 +118,6 @@
#include <spatialindex/Version.h>
#endif
-#ifdef _WIN32
-#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
-#else
-#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
-#endif
// Error stuff
@@ -191,26 +216,7 @@
return static_cast<int>(errors.size());
-std::istream* OpenInput(std::string filename)
- std::ios::openmode const mode = std::ios::in | std::ios::binary;
- std::istream* istrm = 0;
- if (compare_no_case(filename.c_str(),"STDIN",5) == 0)
- istrm = &std::cin;
- else
- istrm = new std::ifstream(filename.c_str(), mode);
- if (!istrm->good())
- delete istrm;
- throw std::runtime_error("Reading stream was not able to be created");
- return istrm;
LAS_DLL LASReaderH LASReader_Create(const char* filename)
@@ -2070,8 +2076,8 @@
liblas::PointFormat* format = new liblas::PointFormat(version_minor,
version_major,
size,
- (bool)bHasColor,
- (bool)bHasTime );
+ bHasColor != 0,
+ bHasTime != 0 );
return (LASPointFormatH) format;
@@ -2135,7 +2141,7 @@
try {
liblas::PointFormat* format = ((liblas::PointFormat*) hFormat);
- format->Color(static_cast<bool>(bColor));
+ format->Color(bColor != 0);
catch (std::exception const& e) {
LASError_PushError(LE_Failure, e.what(), "LASPointFormat_SetColor");
@@ -2159,7 +2165,7 @@
try {
- format->Time(static_cast<bool>(bTime));
+ format->Time(bTime != 0);
LASError_PushError(LE_Failure, e.what(), "LASPointFormat_SetTime");
diff -r b1244e1f9b8b -r 6eb35a2161cd src/lasheader.cpp
--- a/src/lasheader.cpp Tue Mar 16 00:29:51 2010 +0000
+++ b/src/lasheader.cpp Tue Mar 16 11:01:01 2010 -0600
@@ -709,18 +709,23 @@
// byte size or the pointformat's specified size according to whether
// or not it has color or time (FIXME: or waveform packets once we get to 1.3 )
// The extra space that is available can be used to store LASPoint::GetExtraData.
+ // We trim the format size to uint16_t because that's what the header stores
if (format.HasColor() && format.HasTime()) {
SetDataFormatId(liblas::ePointFormat3);
- SetDataRecordLength(std::max(static_cast<uint32_t>(ePointSize3),format.GetByteSize()));
+ SetDataRecordLength(std::max( static_cast<uint16_t>(ePointSize3),
+ static_cast<uint16_t>(format.GetByteSize())));
} else if (format.HasColor() && !format.HasTime()) {
SetDataFormatId(liblas::ePointFormat2);
- SetDataRecordLength(std::max(static_cast<uint32_t>(ePointSize2),format.GetByteSize()));
+ SetDataRecordLength(std::max( static_cast<uint16_t>(ePointSize2),
} else if (!format.HasColor() && format.HasTime()) {
SetDataFormatId(liblas::ePointFormat1);
- SetDataRecordLength(std::max(static_cast<uint32_t>(ePointSize1),format.GetByteSize()));
+ SetDataRecordLength(std::max( static_cast<uint16_t>(ePointSize1),
} else
SetDataFormatId(liblas::ePointFormat0);
- SetDataRecordLength(std::max(static_cast<uint32_t>(ePointSize0),format.GetByteSize()));
+ SetDataRecordLength(std::max( static_cast<uint16_t>(ePointSize0),
} // namespace liblas
diff -r b1244e1f9b8b -r 6eb35a2161cd src/lasreader.cpp
--- a/src/lasreader.cpp Tue Mar 16 00:29:51 2010 +0000
+++ b/src/lasreader.cpp Tue Mar 16 11:01:01 2010 -0600
@@ -101,7 +101,7 @@
try {
m_point = const_cast<Point*>(&(m_pimpl->ReadNextPoint(m_header)));
return true;
- } catch (std::out_of_range& e) {
+ } catch (std::out_of_range) {
m_point = 0;
return false;
@@ -113,7 +113,7 @@
try {
m_point = const_cast<Point*>(&(m_pimpl->ReadPointAt(n, m_header)));
return true;
m_point = 0;
return false;
diff -r b1244e1f9b8b -r 6eb35a2161cd src/makefile.vc
--- a/src/makefile.vc Tue Mar 16 00:29:51 2010 +0000
+++ b/src/makefile.vc Tue Mar 16 11:01:01 2010 -0600
@@ -7,24 +7,22 @@
LAS_OBJS = \
lasclassification.obj \
lascolor.obj \
+ lasformat.obj \
laswriter.obj \
lasreader.obj \
laserror.obj \
las_c_api.obj \
laspoint.obj \
lasheader.obj \
- lasfile.obj \
lasspatialreference.obj \
lasvariablerecord.obj \
- detail\reader.obj \
- detail\reader10.obj \
- detail\reader11.obj \
- detail\reader12.obj \
- detail\writer.obj \
- detail\writer10.obj \
- detail\writer11.obj \
- detail\writer12.obj \
- detail\file.obj
+ detail\reader\reader.obj \
+ detail\reader\point.obj \
+ detail\reader\header.obj \
+ detail\writer\base.obj \
+ detail\writer\header.obj \
+ detail\writer\point.obj \
+ detail\writer\writer.obj
!IF "$(SPATIALINDEX_HOME)" != "" && EXIST("$(SPATIALINDEX_HOME)")
LAS_OBJS = $(LAS_OBJS) index\index.obj \
More information about the Liblas-commits
