[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Thu Mar 18 09:53:14 EDT 2010
changeset ca4ae67525dc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ca4ae67525dc
summary: wave goodbye to makefile.vc. You have served us well, but now you are replaced with cmake.
changeset 2456f9f073e6 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2456f9f073e6
summary: ignore .sln and .vcproj files
diffstat:
.hgignore | 2 +
makefile.vc | 84 --------------------
nmake.opt | 227 --------------------------------------------------------
src/makefile.vc | 71 -----------------
4 files changed, 2 insertions(+), 382 deletions(-)
diffs (truncated from 407 to 300 lines):
diff -r f787b5fa07f7 -r 2456f9f073e6 .hgignore
--- a/.hgignore Wed Mar 17 20:13:00 2010 -0500
+++ b/.hgignore Thu Mar 18 07:52:51 2010 -0600
@@ -25,6 +25,8 @@
*.suo
*.swp
*.user
+*.vcproj
+*.sln
.deps
.DS_Store
.libs
diff -r f787b5fa07f7 -r 2456f9f073e6 makefile.vc
--- a/makefile.vc Wed Mar 17 20:13:00 2010 -0500
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,84 +0,0 @@
-# $Id$
-# Main libLAS makefile for use with NMAKE and Microsoft Visual C++
-LAS_ROOT = .
-!INCLUDE nmake.opt
-CC= cl
-LINK= link
-default: src_dir apps_dir
-src_dir:
- cd src
- $(MAKE) /f makefile.vc
- cd ..
-apps_dir:
- cd apps
- cd ..
-clean:
- -del *.bak
- -del *.lib
- -del *.obj
- -del *.pdb
- cd src
- $(MAKE) /f makefile.vc clean
- cd ..
- cd apps
- cd ..
- -rmdir /s /q osgeo4w
- -rmdir /s /q $(BINDIR)
- -rmdir /s /q packages
-install: src_dir apps_dir
- -mkdir $(BINDIR)
- -mkdir $(LAS_HOME)\packages
- -mkdir $(BINDIR)\lib
- -mkdir $(BINDIR)\include\liblas
- -mkdir $(OSGEO4W_DIR)
- -mkdir $(OSGEO4W_DIR)\lib
- -mkdir $(OSGEO4W_DIR)\devel
- -mkdir $(OSGEO4W_DIR)\lib\bin
- -mkdir $(OSGEO4W_DIR)\devel\include
- -mkdir $(OSGEO4W_DIR)\devel\include\liblas
- -mkdir $(OSGEO4W_DIR)\devel\lib
- -mkdir $(OSGEO4W_DIR)\apps\python25\lib\site-packages\liblas
- cd src
- $(MAKE) /f makefile.vc install
- cd ..
- cd apps
- cd ..
- xcopy /y /r /d /f src\liblas_i.lib $(BINDIR)\lib
- xcopy /y /r /d /f src\liblas_i.lib $(OSGEO4W_DIR)\devel\lib
- xcopy /y /r /d /f src\liblas.lib $(BINDIR)\lib
- xcopy /y /r /d /f src\liblas.lib $(OSGEO4W_DIR)\devel\lib
- xcopy /y /r /d /f src\Version.rc $(BINDIR)\include\liblas
- xcopy /y /r /d /f src\Version.rc $(OSGEO4W_DIR)\devel\include\liblas
- xcopy /y /r /d /f /s include\liblas $(BINDIR)\include\liblas
- xcopy /y /r /d /f /s include\liblas $(OSGEO4W_DIR)\devel\include\liblas
- xcopy /y /r /d /f /s python\liblas\*.py $(OSGEO4W_DIR)\apps\python25\lib\site-packages\liblas
-package: install
- cd $(LAS_HOME)/osgeo4w/lib
- C:\cygwin\bin\tar.exe cvf ../../packages/liblas-$(PACKAGE_VERSION).tar *
- c:\cygwin\bin\bzip2.exe -f /cygdrive/c/cvs/liblas/trunk/packages/liblas-$(PACKAGE_VERSION).tar
- C:\cygwin\bin\tar.exe cvf ../packages/liblas-python-$(PACKAGE_VERSION).tar apps
- c:\cygwin\bin\bzip2.exe -f /cygdrive/c/cvs/liblas/trunk/packages/liblas-python-$(PACKAGE_VERSION).tar
- cd $(LAS_HOME)/osgeo4w/devel
- C:\cygwin\bin\tar.exe cvf ../../packages/liblas-devel-$(PACKAGE_VERSION).tar *
- c:\cygwin\bin\bzip2.exe -f /cygdrive/c/cvs/liblas/trunk/packages/liblas-devel-$(PACKAGE_VERSION).tar
- cd $(LAS_HOME)/
- xcopy /y /r /d /f /s c:\osgeo4w\bin\geotiff.dll $(BINDIR)
- xcopy /y /r /d /f /s c:\osgeo4w\bin\libtiff.dll $(BINDIR)
- xcopy /y /r /d /f /s c:\osgeo4w\bin\jpeg_osgeo.dll $(BINDIR)
- xcopy /y /r /d /f /s c:\osgeo4w\bin\zlib_osgeo.dll $(BINDIR)
- c:\cygwin\bin\zip.exe -r packages/liblas-$(PACKAGE_VERSION)-win32.zip bin
\ No newline at end of file
diff -r f787b5fa07f7 -r 2456f9f073e6 nmake.opt
--- a/nmake.opt Wed Mar 17 20:13:00 2010 -0500
@@ -1,227 +0,0 @@
-# $Id$
-# nmake.opt - main configuration file for NMAKE makefiles
-!MESSAGE *** libLAS Build Configuration ***
-!INCLUDE <ntwin32.mak>
-# For convenience, user may put custom settings to private mynmake.opt
-# and use EXT_NMAKE_OPT option while calling nmake.exe, as follows:
-# nmake -f makefile.vc EXT_NMAKE_OPT=mynmake.opt
-!IFDEF EXT_NMAKE_OPT
-!MESSAGE *** Setting EXT_NMAKE_OPT $(EXT_NMAKE_OPT)
-!INCLUDE $(EXT_NMAKE_OPT)
-!ENDIF
-# libLAS package settings
-LAS_LIB = liblas.lib
-LAS_DLL = liblas1.dll
-LAS_LIB_DLL = liblas_i.lib
-# only used for filenames of packages
-PACKAGE_VERSION = 1.3.0
-!MESSAGE *** Setting PACKAGE_VERSION $(PACKAGE_VERSION)
-# Set BUILD_DEBUG balue to YES if you want to make debug build
-# and to prepare not optimized binaries.
-!IFNDEF BUILD_DEBUG
-BUILD_DEBUG = NO
-!ENDIF
-!MESSAGE *** Setting BUILD_DEBUG $(BUILD_DEBUG)
-# libLAS include directories
-INCLUDES = -I$(LAS_ROOT)/include -I$(LAS_ROOT)/include/liblas/capi
-!MESSAGE *** Setting libLAS INCLUDE to -I$(LAS_ROOT)/include -I$(LAS_ROOT)/include/liblas/capi
-# GeoTIFF Support
-# Uncomment the folling line to build GeoTIFF support for reading and
-# writing LAS files with Coordinate Systems information.
-# comment out GEOTIFF_HOME if you are building against a GDAL source tree
-!IFNDEF GEOTIFF_HOME
-GEOTIFF_HOME=C:\OSGeo4W
-!ENDIF
-!IF "$(GEOTIFF_HOME)" != "" && EXIST("$(GEOTIFF_HOME)")
-!MESSAGE *** GeoTIFF support enabled
-!MESSAGE *** Setting GEOTIFF_HOME $(GEOTIFF_HOME)
-GEOTIFF_LIB = $(GEOTIFF_HOME)\lib\geotiff_i.lib
-GEOTIFF_INCLUDE = -I$(GEOTIFF_HOME)\include
-INCLUDES = $(INCLUDES) $(GEOTIFF_INCLUDE)
-!ELSE
-GEOTIFF_HOME=""
-!MESSAGE *** Support of GeoTIFF has been disabled (GEOTIFF_HOME not set)
-!ENDIF
-# GDAL/OGR Support
-# Uncomment the following line to build OGR support for the las2ogr command
-# and WKT SRS support
-#USE_GDAL_SOURCE_TREE=YES
-#GDAL_HOME=C:\cvs\buildkit\gdal
-!IFNDEF GDAL_HOME
-GDAL_HOME=C:\OSGeo4W
-!ENDIF
-!IF "$(GDAL_HOME)" != "" && EXIST("$(GDAL_HOME)")
-!MESSAGE *** GDAL/OGR support enabled
-!MESSAGE *** Setting GDAL_HOME $(GDAL_HOME)
-GDAL_LIB = $(GDAL_HOME)\lib\gdal_i.lib
-GDAL_INCLUDE = -I$(GDAL_HOME)\include
-!IF "$(USE_GDAL_SOURCE_TREE)" == "YES"
-GDAL_LIB = $(GDAL_HOME)\gdal_i.lib
-GDAL_INCLUDE = -I$(GDAL_HOME)\port -I$(GDAL_HOME)\frmts\gtiff\libgeotiff -I$(GDAL_HOME)\frmts\gtiff\libtiff -I$(GDAL_HOME)\ogr -I$(GDAL_HOME)\gcore
-GEOTIFF_INCLUDE = -I$(GEOTIFF_HOME)\frmts\gtiff\libgeotiff
-!ENDIF
-INCLUDES = $(INCLUDES) $(GDAL_INCLUDE)
-!ELSE
-GDAL_HOME=""
-!MESSAGE *** Support of GDAL/OGR has been disabled (GDAL_HOME not set)
-!ENDIF
-# Spatial Indexing Support
-SPATIALINDEX_HOME=C:\cvs\buildkit\spatialindex
-!IF "$(SPATIALINDEX_HOME)" != "" && EXIST("$(SPATIALINDEX_HOME)")
-!MESSAGE *** Spatial indexing support enabled
-!MESSAGE *** Setting SPATIALINDEX_HOME $(SPATIALINDEX_HOME)
-SPATIALINDEX_LIB = $(SPATIALINDEX_HOME)\spatialindex.lib
-SPATIALINDEX_INCLUDE = -I$(SPATIALINDEX_HOME)\include
-INCLUDES = $(INCLUDES) $(SPATIALINDEX_INCLUDE)
-!ELSE
-SPATIALINDEX_HOME=""
-!ENDIF
-EX_LIBS = $(GDAL_LIB) $(GEOTIFF_LIB) $(SPATIALINDEX_LIB)
-# Distribution directories
-LAS_HOME=C:\cvs\liblas\trunk
-BINDIR=$(LAS_HOME)\bin
-OSGEO4W_DIR = $(LAS_HOME)\osgeo4w
-PYDLL_DIR = $(LAS_HOME)\python
-# Derive version of Visual C++ being used from NMAKE if not specified
-# WARNING:
-# If we should expect variety of NMAKE build versions, tests below may fail
-# and we will need to fall back to setting MSVCVER as command line parameter.
-!IF "$(_NMAKE_VER)" == ""
-MSVCVER = 4.0
-!ERROR *** Failed to determine version of Visual C++
-!ELSEIF "$(_NMAKE_VER)" == "162"
-MSVCVER = 5.0
-!ERROR *** Detected Visual C++ 5.0 - NOT SUPPORTED
-!ELSEIF "$(_NMAKE_VER)" == "6.00.8168.0"
-MSVCVER = 6.0
-!ERROR *** Detected Visual C++ 6.0 - NOT SUPPORTED
-!ELSEIF "$(_NMAKE_VER)" == "7.00.9466"
-MSVCVER = 7.0
-!ELSEIF "$(_NMAKE_VER)" == "7.10.3077"
-MSVCVER = 7.1
-!ELSEIF "$(_NMAKE_VER)" == "8.00.50727.42"
-MSVCVER = 8.0
-!ELSEIF "$(_NMAKE_VER)" == "8.00.50727.762"
-MSVCVER = 8.0
-!ELSEIF "$(_NMAKE_VER)" == "9.00.21022.08"
-MSVCVER = 9.0
-!ELSEIF "$(_NMAKE_VER)" == "9.00.30729.01"
-MSVCVER = 9.0
-!ELSE
-MSVCVER = 0.0
-!ENDIF
-!IF "$(MSVCVER)" == "0.0"
-!MESSAGE *** Cannot determined Visual C++ version
-!ERROR *** Aborting make job
-!ELSE
-!MESSAGE *** Using Microsoft NMAKE version $(_NMAKE_VER)
-!MESSAGE *** Using Microsoft Visual C++ version $(MSVCVER)
-!ENDIF
-# Compilation flags for Release and Debug modes
-!IF "$(BUILD_DEBUG)" == "YES"
-OPTFLAGS= /nologo /MDd /EHsc /Z7 /W4 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /DDEBUG /D_DEBUG /Fd$(LAS_ROOT)\las.pdb
-LAS_LIB = liblas_d.lib
-LAS_DLL = liblas_d1.dll
-LAS_LIB_DLL = libl1as_i.lib
-!ELSE
-# You may need to remove /GR if you are statically linking libLAS
-OPTFLAGS=/nologo /MD /EHsc /Ox /GR /W3 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /DNDEBUG
-!ENDIF
-# Check if multiple process build available
-!IF "$(MSVCVER)" == "9.0"
-MPFLAGS=/MP
-!MESSAGE *** Using /MP flag with number of effective processors
-!ELSE
-MPFLAGS=""
-!ENDIF
-CFLAGS= $(MPFLAGS) $(OPTFLAGS) $(INCLUDES)
-CFLAGS = $(CFLAGS) /DHAVE_LIBGEOTIFF=1
-!ENDIF
More information about the Liblas-commits
