[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org
Fri Mar 19 12:49:25 EDT 2010
changeset aa59dfd518c1 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=aa59dfd518c1
summary: don't try OSRCleanup if we don't have it, this is a new function
changeset f87f619fdbec in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=f87f619fdbec
summary: don't add a newline to the full version info
changeset 6e971a2fa393 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6e971a2fa393
summary: start on a some cmake to build osgeo4w packaging
diffstat:
apps/lasinfo.c | 2 +
cmake/modules/BuildOSGeo4W.cmake | 45 ++++++++++++++++++++++++++++++++++++++++
src/las_c_api.cpp | 2 +-
3 files changed, 48 insertions(+), 1 deletions(-)
diffs (74 lines):
diff -r 5e070e3337d1 -r 6e971a2fa393 apps/lasinfo.c
--- a/apps/lasinfo.c Fri Mar 19 08:46:53 2010 -0500
+++ b/apps/lasinfo.c Fri Mar 19 11:43:56 2010 -0500
@@ -406,7 +406,9 @@
#ifdef HAVE_GDAL
/* Various GDAL related cleanups */
+#ifdef OSRCleanup
OSRCleanup();
+#endif
CPLFinderClean();
CPLFreeConfig();
CPLCleanupTLS();
diff -r 5e070e3337d1 -r 6e971a2fa393 cmake/modules/BuildOSGeo4W.cmake
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/cmake/modules/BuildOSGeo4W.cmake Fri Mar 19 11:43:56 2010 -0500
@@ -0,0 +1,45 @@
+# OSGeo4W packaging
+# On success, the macro sets the following variables:
+# GEOTIFF_FOUND = if the library found
+# GEOTIFF_LIBRARIES = full path to the library
+# GEOTIFF_INCLUDE_DIR = where to find the library headers also defined,
+# but not for general use are
+# GEOTIFF_LIBRARY = where to find the PROJ.4 library.
+# GEOTIFF_VERSION = version of library which was found, e.g. "1.2.5"
+# Copyright (c) 2009 Mateusz Loskot <mateusz at loskot.net>
+# Module source: http://github.com/mloskot/workshop/tree/master/cmake/
+# Redistribution and use is allowed according to the terms of the BSD license.
+# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
+if(WIN32)
+ set(DEFAULT_LIB_SUBDIR lib)
+ set(DEFAULT_DATA_SUBDIR .)
+ set(DEFAULT_INCLUDE_SUBDIR include)
+ if (MSVC)
+ set(DEFAULT_BIN_SUBDIR bin)
+ else()
+ set(DEFAULT_BIN_SUBDIR .)
+ endif()
+else()
+ # Common locatoins for Unix and Mac OS X
+ set(DEFAULT_DATA_SUBDIR share/liblas)
+endif()
+ ADD_CUSTOM_COMMAND(
+ OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/foo.c
+ COMMAND ${CMAKE_COMMAND} copy ${CMAKE_CURRENT_SOURCE_DIR}/bar.c ${CMAKE_CURRENT_BINARY_DIR}/foo.c
+ DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/bar.c
+ ADD_EXECUTABLE(foo foo.c)
diff -r 5e070e3337d1 -r 6e971a2fa393 src/las_c_api.cpp
--- a/src/las_c_api.cpp Fri Mar 19 08:46:53 2010 -0500
+++ b/src/las_c_api.cpp Fri Mar 19 11:43:56 2010 -0500
@@ -1572,7 +1572,7 @@
os << " with" << info;
- os << std::endl;
return strdup(os.str().c_str());
More information about the Liblas-commits
