[Liblas-commits] hg: move allocation of blank extra data array up
into the constr...
liblas-commits at liblas.org
Fri May 7 10:15:44 EDT 2010
changeset d452828997c9 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d452828997c9
summary: move allocation of blank extra data array up into the constructor of detail::writer::Point to eliminate unnecessary allocations/writings
diffstat:
include/liblas/detail/writer/point.hpp | 3 +
src/detail/writer/point.cpp | 58 ++++++++++++++++++++-------------
2 files changed, 38 insertions(+), 23 deletions(-)
diffs (112 lines):
diff -r 59f1d3897c0a -r d452828997c9 include/liblas/detail/writer/point.hpp
--- a/include/liblas/detail/writer/point.hpp Wed May 05 11:19:32 2010 -0500
+++ b/include/liblas/detail/writer/point.hpp Fri May 07 09:15:35 2010 -0500
@@ -102,6 +102,9 @@
PointRecord m_record;
PointFormat m_format;
+ liblas::uint8_t* m_blanks;
void project();
void setup();
void fill();
diff -r 59f1d3897c0a -r d452828997c9 src/detail/writer/point.cpp
--- a/src/detail/writer/point.cpp Wed May 05 11:19:32 2010 -0500
+++ b/src/detail/writer/point.cpp Fri May 07 09:15:35 2010 -0500
@@ -52,7 +52,24 @@
void Point::setup()
+ // If we have extra data on each point by virtue of the
+ // base size of the format being smaller than the total byte
+ // size of the format, we should make a buffer of blank data
+ // that we can write into the file as necessary. We make it
+ // here instead of at each ::write() invocation to save the
+ // allocation and writing of the array
+ if (m_format.GetByteSize() != m_format.GetBaseByteSize()) {
+ int16_t size = m_format.GetByteSize() - m_format.GetBaseByteSize();
+ if (size < 0) {
+ throw std::runtime_error("ByteSize of format was less than BaseByteSize, this cannot happen!");
+ m_blanks = new liblas::uint8_t[size];
+ for (int i=0; i < size; ++i) {
+ m_blanks[i] = 0;
Point::Point( std::ostream& ofs,
@@ -63,7 +80,8 @@
m_header(header),
m_point(liblas::Point()),
m_transform(0),
- m_format(header.GetPointFormat())
+ m_format(header.GetPointFormat()),
+ m_blanks(0)
setup();
@@ -77,7 +95,8 @@
m_header(header),
m_transform(transform),
+ m_blanks(0)
setup();
@@ -85,7 +104,8 @@
Point::~Point()
+ if (m_blanks != 0)
+ delete[] m_blanks;
@@ -148,28 +168,20 @@
std::vector<uint8_t> const& data = point.GetExtraData();
- uint16_t size = m_format.GetByteSize() - m_format.GetBaseByteSize();
- if (data.size() == 0) {
- char* blanks = new char[size];
- for (int i=0; i < size; ++i) {
- blanks[i] = '\0';
- detail::write_n(GetStream(), blanks, static_cast<std::streamsize>(size));
- delete[] blanks;
- } else if (data.size() != size){
+ if (size < 0) {
+ if (data.size() == 0) {
+ detail::write_n(GetStream(), m_blanks, static_cast<std::streamsize>(size));
+ } else if (data.size() < size){
int16_t difference = size - data.size();
- if (difference < 0) {
- throw std::runtime_error("Format's base size is larger than it's size. This should not happen!");
- char* blanks = new char[difference];
- for (int i=0; i < difference; ++i) {
- blanks[i] = '\0';
detail::write_n(GetStream(), data.front(), data.size());
- detail::write_n(GetStream(), blanks, static_cast<std::streamsize>(difference));
- delete[] blanks;
+ detail::write_n(GetStream(), m_blanks, static_cast<std::streamsize>(difference));
} else {
detail::write_n(GetStream(), data.front(), static_cast<std::streamsize>(size));
More information about the Liblas-commits
