[Liblas-commits] hg: satisfy the PEP 8 gods
liblas-commits at liblas.org
Tue May 11 11:43:33 EDT 2010
changeset efa1e69f369b in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=efa1e69f369b
summary: satisfy the PEP 8 gods
diffstat:
python/liblas/__init__.py | 2 +-
python/liblas/color.py | 80 ++++---
python/liblas/core.py | 154 +++++++++-----
python/liblas/file.py | 261 ++++++++++++++----------
python/liblas/format.py | 123 ++++++-----
python/liblas/guid.py | 75 +++---
python/liblas/header.py | 474 ++++++++++++++++++++++++++-------------------
python/liblas/point.py | 370 +++++++++++++++++++++--------------
python/liblas/srs.py | 111 +++++----
python/liblas/vlr.py | 75 +++---
10 files changed, 998 insertions(+), 727 deletions(-)
diffs (truncated from 3135 to 300 lines):
diff -r b0e958797e3e -r efa1e69f369b python/liblas/__init__.py
--- a/python/liblas/__init__.py Fri May 07 10:53:37 2010 -0500
+++ b/python/liblas/__init__.py Tue May 11 10:43:22 2010 -0500
@@ -15,4 +15,4 @@
import header
import vlr
import color
-import srs
\ No newline at end of file
+import srs
diff -r b0e958797e3e -r efa1e69f369b python/liblas/color.py
--- a/python/liblas/color.py Fri May 07 10:53:37 2010 -0500
+++ b/python/liblas/color.py Tue May 11 10:43:22 2010 -0500
@@ -10,39 +10,40 @@
* Copyright (c) 2009, Howard Butler
* All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
* conditions are met:
- * * Redistributions of source code must retain the above copyright
+ * * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided
+ * * Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided
* with the distribution.
- * * Neither the name of the Martin Isenburg or Iowa Department
- * of Natural Resources nor the names of its contributors may be
- * used to endorse or promote products derived from this software
+ * * Neither the name of the Martin Isenburg or Iowa Department
+ * of Natural Resources nor the names of its contributors may be
+ * used to endorse or promote products derived from this software
* without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
- * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
- * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
- * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
- * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
- * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
* OF SUCH DAMAGE.
import core
import ctypes
class Color(object):
def __init__(self, red=0, green=0, blue=0, owned=True, handle=None):
@@ -52,10 +53,11 @@
:type green: integer
:keyword blue: Blue value for the point
:type blue: integer
- :keyword owned: flag to denote whether or not the instance owns its shadow
+ :keyword owned: flag to denote whether or not the instance owns
+ its shadow
:type owned: boolean
:keyword handle: raw ctypes object
>>> from liblas import color
>>> c = color.Color()
>>> c.red
@@ -72,33 +74,36 @@
124
>>> c.blue
125
.. note::
- RGB values should always be normalized to 16 bit values. For example,
- when encoding an 8 bit per channel pixel, multiply each channel value
- by 256 prior to storage in these fields. This normalization allows
- color values from different camera bit depths to be accurately merged.
+ RGB values should always be normalized to 16 bit values. For
+ example, when encoding an 8 bit per channel pixel, multiply each
+ channel value by 256 prior to storage in these fields. This
+ normalization allows color values from different camera bit depths
+ to be accurately merged.
if handle:
self.handle = handle
else:
self.handle = core.las.LASColor_Create()
if red:
self.red = red
if green:
self.green = green
if blue:
self.blue = blue
self.owned = owned
def __del__(self):
if self.owned:
if self.handle and core:
core.las.LASColor_Destroy(self.handle)
def get_red(self):
return core.las.LASColor_GetRed(self.handle)
def set_red(self, value):
return core.las.LASColor_SetRed(self.handle, value)
doc = "Red value of the color triple"
@@ -106,13 +111,15 @@
def get_green(self):
return core.las.LASColor_GetGreen(self.handle)
def set_green(self, value):
return core.las.LASColor_SetGreen(self.handle, value)
doc = "Green value of the color triple"
green = property(get_green, set_green, None, doc)
def get_blue(self):
return core.las.LASColor_GetBlue(self.handle)
def set_blue(self, value):
return core.las.LASColor_SetBlue(self.handle, value)
doc = "Blue value of the color triple"
@@ -120,13 +127,13 @@
def __iter__(self):
"""Iterator support. Values are returned in [R,G,B] order
>>> for i in c:
... print i
123
124
125
>>> list(c)
[123, 124, 125]
@@ -142,4 +149,3 @@
if not b:
b = True
yield self.blue
diff -r b0e958797e3e -r efa1e69f369b python/liblas/core.py
--- a/python/liblas/core.py Fri May 07 10:53:37 2010 -0500
+++ b/python/liblas/core.py Tue May 11 10:43:22 2010 -0500
@@ -7,45 +7,50 @@
* Author: Howard Butler, hobu.inc at gmail.com
- * Copyright (c) 2008, Howard Butler
+ * Copyright (c) 2009, Howard Butler
* OF SUCH DAMAGE.
-import atexit, os, re, sys
+import atexit
+import os
+import re
+import sys
import ctypes
from ctypes.util import find_library
from ctypes import PyDLL
class LASException(Exception):
"libLAS exception, indicates a libLAS-related error."
pass
@@ -54,56 +59,65 @@
def check_return(result, func, cargs):
"Error checking for LASError calls"
if result != 0:
- msg = 'LASError in "%s": %s' % (func.__name__, las.LASError_GetLastErrorMsg() )
+ msg = 'LASError in "%s": %s' % (func.__name__,
+ las.LASError_GetLastErrorMsg())
las.LASError_Reset()
raise LASException(msg)
return True
def check_void(result, func, cargs):
"Error checking for void* returns"
if not bool(result):
return result
def check_void_done(result, func, cargs):
"Error checking for void* returns that might be empty with no error"
if las.LASError_GetErrorCount():
return result
def check_value(result, func, cargs):
"Error checking proper value returns"
count = las.LASError_GetErrorCount()
if count != 0:
return result
More information about the Liblas-commits
