[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org
Mon Nov 1 20:17:34 EDT 2010
changeset 0ffb3912366e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0ffb3912366e
summary: avoid geo_gtiffp.h and cpl_serv.h in lasspatialreference.hpp
changeset 94c43e41b2cd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=94c43e41b2cd
summary: update to latest from GDAL, fixes some cross heap issues
changeset ff4948e28c32 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ff4948e28c32
summary: forced merge
diffstat:
.hgignore | 1 +
hobu-config.bat | 9 +-
include/liblas/iterator.hpp | 3 +
include/liblas/lasbounds.hpp | 13 ++++-
include/liblas/lasspatialreference.hpp | 6 +-
src/gt_wkt_srs.cpp | 90 +++++++++++++++++++++++----------
src/lasspatialreference.cpp | 24 +++++---
7 files changed, 100 insertions(+), 46 deletions(-)
diffs (truncated from 342 to 300 lines):
diff -r 5283f808adf4 -r ff4948e28c32 .hgignore
--- a/.hgignore Mon Nov 01 15:53:50 2010 -0500
+++ b/.hgignore Mon Nov 01 19:17:19 2010 -0500
@@ -75,6 +75,7 @@
test/data/*.dat
test/data/*.idx
.dirstamp
+*.dir
CMakeScripts
libLAS.xcodeproj
build/libLAS.build
diff -r 5283f808adf4 -r ff4948e28c32 hobu-config.bat
--- a/hobu-config.bat Mon Nov 01 15:53:50 2010 -0500
+++ b/hobu-config.bat Mon Nov 01 19:17:19 2010 -0500
@@ -1,14 +1,14 @@
@echo off
-REM set G="NMake Makefiles"
-set G="Visual Studio 9 2008"
+set G="NMake Makefiles"
+REM set G="Visual Studio 9 2008"
set LIBLAS=D:\liblas
set OSGEO4W=C:\OSGeo4W
set BOOST=D:\boost\boost_1_44
set ORACLE_HOME=%OSGEO4W%
REM set BUILD_TYPE=RelWithDebInfo
-REM set BUILD_TYPE=Debug
-set BUILD_TYPE=Release
+set BUILD_TYPE=Debug
+REM set BUILD_TYPE=Release
set PATH=%OSGEO4W%\apps\gdal-dev\bin;%OSGEO4W%\bin;%PATH%
@@ -26,4 +26,5 @@
-DORACLE_INCLUDE_DIR=%ORACLE_HOME%\include ^
-DORACLE_OCI_LIBRARY=%ORACLE_HOME%\lib\oci.lib ^
-DCMAKE_BUILD_TYPE=%BUILD_TYPE% ^
+ -DCMAKE_VERBOSE_FILE=OFF
%LIBLAS%
\ No newline at end of file
diff -r 5283f808adf4 -r ff4948e28c32 include/liblas/iterator.hpp
--- a/include/liblas/iterator.hpp Mon Nov 01 15:53:50 2010 -0500
+++ b/include/liblas/iterator.hpp Mon Nov 01 19:17:19 2010 -0500
@@ -307,6 +307,9 @@
/// Public specialization of LASWriter output iterator for liblas::LASPoint type.
typedef writer_iterator<Point> laswriter_iterator;
+template class LAS_DLL reader_iterator<Point>;
+template class LAS_DLL writer_iterator<Point>;
} // namespace liblas
#endif // LIBLAS_ITERATOR_HPP_INCLUDED
diff -r 5283f808adf4 -r ff4948e28c32 include/liblas/lasbounds.hpp
--- a/include/liblas/lasbounds.hpp Mon Nov 01 15:53:50 2010 -0500
+++ b/include/liblas/lasbounds.hpp Mon Nov 01 19:17:19 2010 -0500
@@ -159,6 +159,13 @@
if (v > max)
max = v;
+ void grow(Range const& r)
+ grow(r.min);
+ grow(r.max);
T length() const
return max - min;
@@ -166,7 +173,7 @@
template <typename T>
-class LAS_DLL Bounds
+class Bounds
public:
@@ -578,6 +585,10 @@
+template class LAS_DLL liblas::Range<double>;
+template class LAS_DLL liblas::Bounds<double>;
#endif // ndef LIBLAS_LASBOUNDS_HPP_INCLUDED
diff -r 5283f808adf4 -r ff4948e28c32 include/liblas/lasspatialreference.hpp
--- a/include/liblas/lasspatialreference.hpp Mon Nov 01 15:53:50 2010 -0500
+++ b/include/liblas/lasspatialreference.hpp Mon Nov 01 19:17:19 2010 -0500
@@ -54,9 +54,9 @@
#ifdef HAVE_GDAL
#include <ogr_srs_api.h>
#include <cpl_port.h>
-#include <cpl_serv.h>
-#include <geo_tiffp.h>
-#define CPL_ERROR_H_INCLUDED
+//#include <cpl_serv.h>
+//#include <geo_tiffp.h>
+//#define CPL_ERROR_H_INCLUDED
#include <geo_normalize.h>
#include <geovalues.h>
#include <ogr_spatialref.h>
diff -r 5283f808adf4 -r ff4948e28c32 src/gt_wkt_srs.cpp
--- a/src/gt_wkt_srs.cpp Mon Nov 01 15:53:50 2010 -0500
+++ b/src/gt_wkt_srs.cpp Mon Nov 01 19:17:19 2010 -0500
@@ -1,5 +1,5 @@
- * $Id: gt_wkt_srs.cpp 20480 2010-08-28 21:20:15Z rouault $
+ * $Id$
* Project: GeoTIFF Driver
* Purpose: Implements translation between GeoTIFF normalized projection
@@ -42,7 +42,7 @@
#include "xtiffio.h"
#include "cpl_multiproc.h"
-CPL_CVSID("$Id: gt_wkt_srs.cpp 20480 2010-08-28 21:20:15Z rouault $")
+CPL_CVSID("$Id$")
CPL_C_START
int CPL_DLL VSIFCloseL( FILE * );
@@ -65,6 +65,12 @@
CPLErr CPL_DLL GTIFWktFromMemBuf( int nSize, unsigned char *pabyBuffer,
char **ppszWKT, double *padfGeoTransform,
int *pnGCPCount, GDAL_GCP **ppasGCPList );
+#undef CSVReadParseLine
+char CPL_DLL **CSVReadParseLine( FILE *fp);
+#undef CSLDestroy
+void CPL_DLL CPL_STDCALL CSLDestroy(char **papszStrList);
CPL_C_END
TIFF* VSI_TIFFOpen(const char* name, const char* mode);
@@ -102,6 +108,24 @@
char **ppszAngularUnits);
+/* GTIFToCPLRecyleString() */
+/* This changes a string from the libgeotiff heap to the GDAL */
+/* heap. */
+static void GTIFToCPLRecycleString( char **ppszTarget )
+ if( *ppszTarget == NULL )
+ return;
+ char *pszTempString = CPLStrdup(*ppszTarget);
+ GTIFFreeMemory( *ppszTarget );
+ *ppszTarget = pszTempString;
/* WKTMassageDatum() */
/* Massage an EPSG datum name into WMT format. Also transform */
@@ -114,14 +138,7 @@
int i, j;
char *pszDatum;
-/* First copy string and allocate with our CPLStrdup() to so we */
-/* know when we are done this function we will have a CPL */
-/* string, not a GTIF one. */
- pszDatum = CPLStrdup(*ppszDatum);
- GTIFFreeMemory( *ppszDatum );
- *ppszDatum = pszDatum;
+ pszDatum = *ppszDatum;
if (pszDatum[0] == '\0')
return;
@@ -179,11 +196,11 @@
/* For example:
- GTCitationGeoKey (Ascii,215): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 20480 $ $Date: 2010-08-28 17:20:15 -0400 (Sat, 28 Aug 2010) $\nProjection Name = UTM\nUnits = meters\nGeoTIFF Units = meters"
+ GTCitationGeoKey (Ascii,215): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision$ $Date$\nProjection Name = UTM\nUnits = meters\nGeoTIFF Units = meters"
- GeogCitationGeoKey (Ascii,267): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 20480 $ $Date: 2010-08-28 17:20:15 -0400 (Sat, 28 Aug 2010) $\nUnable to match Ellipsoid (Datum) to a GeographicTypeGeoKey value\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
+ GeogCitationGeoKey (Ascii,267): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision$ $Date$\nUnable to match Ellipsoid (Datum) to a GeographicTypeGeoKey value\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
- PCSCitationGeoKey (Ascii,214): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 20480 $ $Date: 2010-08-28 17:20:15 -0400 (Sat, 28 Aug 2010) $\nUTM Zone 10N\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
+ PCSCitationGeoKey (Ascii,214): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision$ $Date$\nUTM Zone 10N\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
@@ -354,23 +371,36 @@
&& hGTIF != NULL
&& GTIFKeyGet( hGTIF, GeogCitationGeoKey, szGCSName, 0,
sizeof(szGCSName)) )
- GetGeogCSFromCitation(szGCSName, sizeof(szGCSName),
- GeogCitationGeoKey,
- &pszGeogName, &pszDatumName,
- &pszPMName, &pszSpheroidName,
- &pszAngularUnits);
+ GetGeogCSFromCitation(szGCSName, sizeof(szGCSName),
+ GeogCitationGeoKey,
+ &pszGeogName, &pszDatumName,
+ &pszPMName, &pszSpheroidName,
+ &pszAngularUnits);
+ else
+ GTIFToCPLRecycleString( &pszGeogName );
if( !pszDatumName )
GTIFGetDatumInfo( psDefn->Datum, &pszDatumName, NULL );
+ GTIFToCPLRecycleString( &pszDatumName );
if( !pszSpheroidName )
GTIFGetEllipsoidInfo( psDefn->Ellipsoid, &pszSpheroidName, NULL, NULL );
+ GTIFToCPLRecycleString( &pszSpheroidName );
else
GTIFKeyGet(hGTIF, GeogSemiMajorAxisGeoKey, &(psDefn->SemiMajor), 0, 1 );
GTIFKeyGet(hGTIF, GeogInvFlatteningGeoKey, &dfInvFlattening, 0, 1 );
if( !pszPMName )
- GTIFGetPMInfo( psDefn->PM, &pszPMName, NULL );
+ GTIFGetPMInfo( psDefn->PM, &pszPMName, NULL );
+ GTIFToCPLRecycleString( &pszPMName );
else
GTIFKeyGet(hGTIF, GeogPrimeMeridianLongGeoKey, &(psDefn->PMLongToGreenwich), 0, 1 );
@@ -379,6 +409,8 @@
GTIFGetUOMAngleInfo( psDefn->UOMAngle, &pszAngularUnits, NULL );
if( pszAngularUnits == NULL )
pszAngularUnits = CPLStrdup("unknown");
+ else
+ GTIFToCPLRecycleString( &pszAngularUnits );
else
@@ -386,8 +418,8 @@
aUnitGot = TRUE;
- if( pszDatumName != NULL ) /* was a GTIFFreeMemory'able string */
- WKTMassageDatum( &pszDatumName ); /* now a CPLFree'able string */
+ if( pszDatumName != NULL )
+ WKTMassageDatum( &pszDatumName );
dfSemiMajor = psDefn->SemiMajor;
if( dfSemiMajor == 0.0 )
@@ -408,9 +440,10 @@
if(!pszGeogName || strlen(pszGeogName) == 0)
- GTIFFreeMemory(pszGeogName); /* was a GTIFFreeMemory'able string */
- pszGeogName = CPLStrdup( pszDatumName ); /* now a CPLFree'able string */
+ CPLFree(pszGeogName);
+ pszGeogName = CPLStrdup( pszDatumName );
if(aUnitGot)
oSRS.SetGeogCS( pszGeogName, pszDatumName,
pszSpheroidName, dfSemiMajor, dfInvFlattening,
@@ -437,9 +470,9 @@
CPLFree( pszGeogName );
CPLFree( pszDatumName );
- GTIFFreeMemory( pszPMName );
- GTIFFreeMemory( pszSpheroidName );
- GTIFFreeMemory( pszAngularUnits );
+ CPLFree( pszSpheroidName );
+ CPLFree( pszPMName );
+ CPLFree( pszAngularUnits );
/* Handle projection parameters. */
@@ -895,6 +928,7 @@
char **papszTokens;
int nReturn = KvUserDefined;
/* Do we know it as a built in? */
@@ -909,7 +943,7 @@
return Datum_WGS84;
else if( EQUAL(pszOGCName,"WGS72") || EQUAL(pszOGCName,"WGS_1972") )
return Datum_WGS72;
/* Open the table if possible. */
More information about the Liblas-commits
