[Liblas-commits] hg: 7 new changesets
liblas-commits at liblas.org
Fri Nov 5 14:34:11 EDT 2010
changeset ec171b17b2dd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ec171b17b2dd
summary: only display summary info if the summary has points
changeset ede177039ee3 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ede177039ee3
summary: revert to using comma- or space-separated quoted strings for --extent and --offset
changeset 8d51159167fd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=8d51159167fd
summary: add space to SEPARATORS
changeset cfaea7180f13 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=cfaea7180f13
summary: revert to using comma- or space-separated values for --extent and --offset. Also add --minx, --miny, etc specializations for filter options
changeset 9e7bc3df43ed in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9e7bc3df43ed
summary: remove references to lasinfo2
changeset 160c3fd97c56 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=160c3fd97c56
summary: make las2oci show help if no LAS file is given
changeset a083ee0f3af5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a083ee0f3af5
summary: update docs
diffstat:
apps/las2oci.cpp | 27 ++----
apps/lasinfo.cpp | 6 +-
apps/laskernel.cpp | 149 +++++++++++++++++++++++++++++++++++-------
apps/laskernel.hpp | 2 +-
doc/utilities/las2las.txt | 52 ++++++++++++--
doc/utilities/las2oci.txt | 42 +++++++++--
doc/utilities/lasinfo.txt | 40 ++++++++---
include/liblas/lasbounds.hpp | 2 +
src/utility.cpp | 5 +
9 files changed, 246 insertions(+), 79 deletions(-)
diffs (truncated from 585 to 300 lines):
diff -r f155552b9405 -r a083ee0f3af5 apps/las2oci.cpp
--- a/apps/las2oci.cpp Thu Nov 04 13:08:42 2010 -0500
+++ b/apps/las2oci.cpp Fri Nov 05 13:26:23 2010 -0500
@@ -666,7 +666,7 @@
("base-table-aux-values", po::value< string >(), "Quoted, comma-separated list of values to add to the SQL that gets executed as part of the point cloud insertion into the base-table-name")
("solid", po::value<bool>()->zero_tokens(), "Define the point cloud's PC_EXTENT geometry gtype as (1,1007,3) instead of the normal (1,1003,3), and use gtype 3008/2008 vs 3003/2003 for BLK_EXTENT geometry values.")
("3d", po::value<bool>()->zero_tokens(), "Use Z values for insertion of all extent (PC_EXTENT, BLK_EXTENT, USER_SDO_GEOM_METADATA) entries")
- ("global-extent", po::value< std::vector<double> >(), "Extent window to define for the PC_EXTENT.\nUse a list, for example, \n --global-extent minx miny maxx maxy\n or \n --global-extent minx miny minz maxx maxy maxz")
+ ("global-extent", po::value< std::vector<double> >(), "Extent window to define for the PC_EXTENT.\nUse a comma-separated or quoted, space-separated list, for example, \n -e minx, miny, maxx, maxy\n or \n -e minx, miny, minz, maxx, maxy, maxz\n -e \"minx miny minz maxx maxy maxz\"")
("cached", po::value<bool>()->zero_tokens(), "Cache the entire file on the first read")
@@ -800,6 +800,7 @@
header = reader.GetHeader();
} else {
std::cerr << "Input LAS file not specified!\n";
+ std::cout << GetInvocationHeader()<<file_options<<transform_options<<filtering_options<<"\n";
return 1;
@@ -971,20 +972,14 @@
if (vm.count("global-extent"))
- std::vector<double> vbounds = vm["global-extent"].as< std::vector<double> >();
+ std::string bounds_string = vm["global-extent"].as< string >();
- liblas::Bounds<double> bounds;
- if (verbose)
- std::cout << "Setting global bounds to : ";
+ boost::char_separator<char> sep(SEPARATORS);
- for (std::vector<double>::const_iterator t = vbounds.begin();
- t != vbounds.end();
- ++t) {
- std::cout << *t;
- std::cout << std::endl;
+ std::vector<double> vbounds;
+ tokenizer tokens(bounds_string, sep);
+ for (tokenizer::iterator t = tokens.begin(); t != tokens.end(); ++t) {
+ vbounds.push_back(atof((*t).c_str()));
if (vbounds.size() == 4)
@@ -1004,10 +999,8 @@
ostringstream oss;
oss << "Bounds must be specified as a 4-tuple or "
"6-tuple, not a "<< vbounds.size()<<"-tuple" << "\n";
- std::cerr << oss.str();
- if (verbose)
- std::cout << "Storing 3D geometries... " << std::endl;
+ throw std::runtime_error(oss.str());
if (vm.count("xmin"))
diff -r f155552b9405 -r a083ee0f3af5 apps/lasinfo.cpp
--- a/apps/lasinfo.cpp Thu Nov 04 13:08:42 2010 -0500
+++ b/apps/lasinfo.cpp Fri Nov 05 13:26:23 2010 -0500
@@ -69,9 +69,9 @@
oss << options;
- oss <<"\nFor more information, see the full documentation for lasinfo2 at:\n";
+ oss <<"\nFor more information, see the full documentation for lasinfo at:\n";
- oss << " http://liblas.org/utilities/lasinfo2.html\n";
+ oss << " http://liblas.org/utilities/lasinfo.html\n";
oss << "----------------------------------------------------------\n";
@@ -115,7 +115,7 @@
try {
- po::options_description file_options("lasinfo2 options");
+ po::options_description file_options("lasinfo options");
po::options_description filtering_options = GetFilteringOptions();
po::options_description header_options = GetHeaderOptions();
diff -r f155552b9405 -r a083ee0f3af5 apps/laskernel.cpp
--- a/apps/laskernel.cpp Thu Nov 04 13:08:42 2010 -0500
+++ b/apps/laskernel.cpp Fri Nov 05 13:26:23 2010 -0500
@@ -255,7 +255,13 @@
po::options_description filtering_options("Filtering options");
filtering_options.add_options()
- ("extent,e", po::value< std::vector<double> >()->multitoken(), "Extent window that points must fall within to keep.\nFor example, \n -e minx miny maxx maxy\n or \n -e minx miny minz maxx maxy maxz")
+ ("extent,e", po::value< string >(), "Extent window that points must fall within to keep.\nUse a comma-separated or quoted, space-separated list, for example, \n -e minx, miny, maxx, maxy\n or \n -e minx, miny, minz, maxx, maxy, maxz\n -e \"minx miny minz maxx maxy maxz\"")
+ ("minx", po::value< double >(), "Extent must be greater than or equal to minx to be kept. \n --minx 1234.0")
+ ("miny", po::value< double >(), "Extent must be greater than or equal to miny to be kept. \n --miny 5678.0")
+ ("minz", po::value< double >(), "Extent must be greater than or equal to minz to be kept. If maxx and maxy are set but not minz *and maxz, all z values are kept. \n --minz 0.0")
+ ("maxx", po::value< double >(), "Extent must be less than or equal to maxx to be kept. \n --maxx 1234.0")
+ ("maxy", po::value< double >(), "Extent must be less than or equal to maxy to be kept. \n --maxy 5678.0")
+ ("maxz", po::value< double >(), "Extent must be less than or equal to maxz to be kept. If maxx and maxy are set but not maxz *and minz, all z values are kept. \n --maxz 10.0")
("thin,t", po::value<boost::uint32_t>()->default_value(0), "Simple decimation-style thinning.\nThin the file by removing every t'th point from the file.")
("last_return_only", po::value<bool>()->zero_tokens(), "Keep last returns (cannot be used with --first_return_only)")
("first_return_only", po::value<bool>()->zero_tokens(), "Keep first returns (cannot be used with --last_return_only")
@@ -294,8 +300,8 @@
transform_options.add_options()
("a_srs", po::value< string >(), "Coordinate system to assign to input LAS file")
("a_vertcs", po::value< std::vector<string> >()->multitoken(), "Override vertical coordinate system information. Use --a_vertcs \"verticalCSType [citation [verticalDatum [verticalUnits]]]\"\nFor example: --a_vertcs 5703 \"North American Vertical Datum of 1988 (NAVD88)\" 5103 9001")
- ("offset", po::value< std::vector<double> >()->multitoken(), "A list of offsets to set on the output file: \n--offset 0 0 0")
- ("scale", po::value< std::vector<double> >()->multitoken(), "A list of scales to set on the output file: \n--scale 0.1 0.1 0.00001")
+ ("offset", po::value< string >(), "A comma-separated or quoted, space-separated list of offsets to set on the output file: \n--offset 0,0,0\n--offset \"1234 5678 91011\"")
+ ("scale", po::value< std::vector<double> >()->multitoken(), "A list of scales to set on the output file. Scales *cannot* be negative, and should always be a negative power of 10 \n--scale 0.1 0.1 0.00001")
("format,f", po::value< string >(), "Set the LAS format of the new file (only 1.0-1.2 supported at this time): \n--format 1.2\n-f 1.1")
("pad-header", po::value< string >(), "Add extra bytes to the existing header")
("min-offset", po::value<bool>()->zero_tokens(), "Set the offset of the header to the minimums of all values in the file. Note that this requires multiple read passes through the file to achieve.")
@@ -314,6 +320,8 @@
std::vector<liblas::FilterPtr> GetFilters(po::variables_map vm, bool verbose)
std::vector<liblas::FilterPtr> filters;
+ liblas::Bounds<double> extent;
+ bool bSetExtent = false;
if (vm.count("keep-classes"))
@@ -409,14 +417,73 @@
liblas::FilterI::eExclusion);
filters.push_back(return_filter);
+ if (vm.count("minx"))
+ double minx = vm["minx"].as< double >();
+ extent.min(0, minx);
+ bSetExtent = true;
+ if (verbose)
+ std::cout << "Setting minx to: " << minx << std::endl;
+ if (vm.count("maxx"))
+ double maxx = vm["maxx"].as< double >();
+ extent.max(0, maxx);
+ if (verbose)
+ std::cout << "Setting maxx to: " << maxx << std::endl;
+ if (vm.count("miny"))
+ double miny = vm["miny"].as< double >();
+ extent.min(1, miny);
+ if (verbose)
+ std::cout << "Setting miny to: " << miny << std::endl;
+ double maxy = vm["maxy"].as< double >();
+ extent.max(1, maxy);
+ if (verbose)
+ std::cout << "Setting maxy to: " << maxy << std::endl;
+ if (vm.count("minz"))
+ double minz = vm["minz"].as< double >();
+ extent.min(2, minz);
+ if (verbose)
+ std::cout << "Setting minz to: " << minz << std::endl;
+ if (vm.count("maxz"))
+ double maxz = vm["maxz"].as< double >();
+ extent.max(2, maxz);
+ if (verbose)
+ std::cout << "Setting maxz to: " << maxz << std::endl;
if (vm.count("extent"))
+ std::string bounds_string = vm["extent"].as< string >();
- std::vector<double> vbounds = vm["extent"].as< std::vector<double> >();
bounds = liblas::Bounds<double>(vbounds[0],
@@ -437,6 +504,15 @@
+ if ( bSetExtent )
+ if (verbose)
+ std::cout << " Growing --extent bounds with those that were set via --[x|y|z][min|max]" << std::endl;
+ bounds.grow(extent);
if (verbose)
@@ -459,6 +535,11 @@
liblas::FilterPtr bounds_filter = MakeBoundsFilter(bounds, liblas::FilterI::eInclusion);
+ // Set to false because we are using this opportunity to set the filter
+ // If it were still true after this point, *another* BoundsFilter would be
+ // added to the filters list at the end of this function
+ if (bSetExtent)
+ bSetExtent = false;
filters.push_back(bounds_filter);
@@ -683,6 +764,15 @@
filters.push_back(valid_filter);
+ // If we have bSetExtent and we haven't turned it off by merging with a --extent
+ // BoundsFilter, make a filter
+ if (bSetExtent)
+ liblas::FilterPtr bounds_filter = MakeBoundsFilter(extent, liblas::FilterI::eInclusion);
+ filters.push_back(bounds_filter);
return filters;
@@ -692,32 +782,37 @@
if (vm.count("offset"))
+ std::string offset_string = vm["offset"].as< string >();
+ if (verbose)
+ std::cout << "Setting offsets to: " << offset_string << std::endl;
+ std::vector<double> offsets;
+ tokenizer tokens(offset_string, sep);
+ bool mins = false;
+ std::string m("min");
+ // Check if the user set --offset min,min,min
+ // FIXME: make this so the user could do --offset min,min,20.00
+ if (!(*t).compare(m))
+ mins = true;
+ continue;
+ else
+ mins = false;
+ offsets.push_back(atof((*t).c_str()));
+ if (offsets.size() != 3)
+ throw std::runtime_error("All three values for setting the offset must be floats, and there must be three values");
- std::vector<double> offsets = vm["offset"].as< std::vector<double> >();
- if (offsets.size() != 3) {
- ostringstream oss;
- oss << "Three arguments must be given to offset. "
- << "--offset x y z";
- throw std::runtime_error(oss.str());
- if (verbose)
- for (std::vector<double>::const_iterator i = offsets.begin();
- i != offsets.end();
- i++)
- oss << *i << " ";
- std::cout << "Setting offsets to: " << oss.str() << std::endl;
header.SetOffset(offsets[0], offsets[1], offsets[2]);
if (vm.count("scale"))
More information about the Liblas-commits
