[Liblas-commits] hg: a few updates. Try to add twitter feed to main
	page
    liblas-commits at liblas.org
    Fri Nov  5 22:43:01 EDT 2010
changeset 7ea6b51408cd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=7ea6b51408cd
summary: a few updates.  Try to add twitter feed to main page
diffstat:
 doc/_templates/indexsidebar.html     |   37 +++++++++++++++++++++++++++++++++++
 doc/_templates/layout.html           |    4 +++
 doc/compilation.txt                  |    4 ++-
 doc/docs.txt                         |    1 +
 doc/images/osgeo4w-select-liblas.png |    0
 doc/index.txt                        |    2 +-
 doc/osgeo4w.txt                      |   11 ++++++++++
 7 files changed, 57 insertions(+), 2 deletions(-)
diffs (124 lines):
diff -r 6743c501ac6b -r 7ea6b51408cd doc/_templates/indexsidebar.html
--- a/doc/_templates/indexsidebar.html	Fri Nov 05 20:24:39 2010 -0500
+++ b/doc/_templates/indexsidebar.html	Fri Nov 05 21:42:52 2010 -0500
@@ -10,6 +10,43 @@
 </p>
 <p>
+<script src="http://widgets.twimg.com/j/2/widget.js" ></script>
+<script type="text/javascript" >
+new TWTR.Widget({
+  version: 2,
+  type: 'profile',
+  rpp: 4,
+  interval: 6000,
+  width: 'auto',
+  height: 300,
+  theme: {
+    shell: {
+      background: '#e2e05a',
+      color: '#050005'
+    tweets: {
+      color: '#000000',
+      links: '#000544'
+  features: {
+    scrollbar: false,
+    loop: false,
+    live: false,
+    hashtags: true,
+    timestamp: true,
+    avatars: false,
+    behavior: 'all'
+}).render().setUser('liblas').start();
+</script>
+</p>
+<p>
 <script type="text/javascript" src="http://www.ohloh.net/p/10742/widgets/project_thin_badge.js"></script>
 </p>
diff -r 6743c501ac6b -r 7ea6b51408cd doc/_templates/layout.html
--- a/doc/_templates/layout.html	Fri Nov 05 20:24:39 2010 -0500
+++ b/doc/_templates/layout.html	Fri Nov 05 21:42:52 2010 -0500
@@ -1,6 +1,9 @@
 {% extends "!layout.html" %}
+{% block extrahead %}
+{{ super() }}
+{% endblock %}
 {% block relbar1 %}
@@ -50,4 +53,5 @@
 </div>
 {% endblock %}
diff -r 6743c501ac6b -r 7ea6b51408cd doc/compilation.txt
--- a/doc/compilation.txt	Fri Nov 05 20:24:39 2010 -0500
+++ b/doc/compilation.txt	Fri Nov 05 21:42:52 2010 -0500
@@ -41,7 +41,9 @@
     The only supported build environment libLAS moving forward from the 1.6
     release is `CMake`_. `Autoconf`_ configuration will be phased out and will
     no longer be updated after the 1.6 release.
+.. _prerequisites:
 Prerequisites
diff -r 6743c501ac6b -r 7ea6b51408cd doc/docs.txt
--- a/doc/docs.txt	Fri Nov 05 20:24:39 2010 -0500
+++ b/doc/docs.txt	Fri Nov 05 21:42:52 2010 -0500
@@ -18,6 +18,7 @@
    :maxdepth: 2
    start
+   Windows Installation <osgeo4w>
    compilation
    tutorial/index
    faq
diff -r 6743c501ac6b -r 7ea6b51408cd doc/images/osgeo4w-select-liblas.png
Binary file doc/images/osgeo4w-select-liblas.png has changed
diff -r 6743c501ac6b -r 7ea6b51408cd doc/index.txt
--- a/doc/index.txt	Fri Nov 05 20:24:39 2010 -0500
+++ b/doc/index.txt	Fri Nov 05 21:42:52 2010 -0500
@@ -3,7 +3,7 @@
 libLAS - LAS 1.0/1.1/1.2 ASPRS LiDAR data translation toolset
 libLAS is a C/C++ library for reading and writing the very common `LAS`
 `LiDAR`_ format. The `ASPRS LAS format`_ is a sequential binary format used to
diff -r 6743c501ac6b -r 7ea6b51408cd doc/osgeo4w.txt
--- a/doc/osgeo4w.txt	Fri Nov 05 20:24:39 2010 -0500
+++ b/doc/osgeo4w.txt	Fri Nov 05 21:42:52 2010 -0500
@@ -8,4 +8,15 @@
 :Author: Howard Butler
 :Contact: hobu.inc at gmail dot com
+This document describes how to install libLAS and its related :ref:`utilities <utilities>`
+using `OSGeo4W`_.  `OSGeo4W`_ is a collection of Windows packages that uses the `Cygwin`_
+installer to manage package dependencies.  libLAS in its fully-featured form
+requires a number of dependencies
+.. seealso::
+    :ref:`Prerequisites` contains a detailed listing of the
+    prerequisites that libLAS needs to provide a full feature set.
 .. _`OSGeo4W`: http://trac.osgeo.org/osgeo4w/
+.. _`Cygwin`: http://www.cygwin.com/
More information about the Liblas-commits
