[Liblas-commits] hg: take in string for global-extent
liblas-commits at liblas.org
Sun Nov 7 16:36:57 EST 2010
changeset 62750a6dd8d7 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=62750a6dd8d7
summary: take in string for global-extent
diffstat:
apps/las2oci.cpp | 2 +-
1 files changed, 1 insertions(+), 1 deletions(-)
diffs (12 lines):
diff -r 9cf76ab01522 -r 62750a6dd8d7 apps/las2oci.cpp
--- a/apps/las2oci.cpp Sat Nov 06 23:12:41 2010 -0500
+++ b/apps/las2oci.cpp Sun Nov 07 15:36:50 2010 -0600
@@ -666,7 +666,7 @@
("base-table-aux-values", po::value< string >(), "Quoted, comma-separated list of values to add to the SQL that gets executed as part of the point cloud insertion into the base-table-name")
("solid", po::value<bool>()->zero_tokens(), "Define the point cloud's PC_EXTENT geometry gtype as (1,1007,3) instead of the normal (1,1003,3), and use gtype 3008/2008 vs 3003/2003 for BLK_EXTENT geometry values.")
("3d", po::value<bool>()->zero_tokens(), "Use Z values for insertion of all extent (PC_EXTENT, BLK_EXTENT, USER_SDO_GEOM_METADATA) entries")
- ("global-extent", po::value< std::vector<double> >(), "Extent window to define for the PC_EXTENT.\nUse a comma-separated or quoted, space-separated list, for example, \n -e minx, miny, maxx, maxy\n or \n -e minx, miny, minz, maxx, maxy, maxz\n -e \"minx miny minz maxx maxy maxz\"")
+ ("global-extent", po::value< std::string >(), "Extent window to define for the PC_EXTENT.\nUse a comma-separated or quoted, space-separated list, for example, \n -e minx, miny, maxx, maxy\n or \n -e minx, miny, minz, maxx, maxy, maxz\n -e \"minx miny minz maxx maxy maxz\"")
("cached", po::value<bool>()->zero_tokens(), "Cache the entire file on the first read")
More information about the Liblas-commits
