[Liblas-commits] hg: a few code cleanups to remove dead code
    liblas-commits at liblas.org
    Tue Nov  9 14:47:19 EST 2010
changeset 07104a34d7c6 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=07104a34d7c6
summary: a few code cleanups to remove dead code
diffstat:
 apps/las2oci.cpp |  99 ++++++-------------------------------------------------
 1 files changed, 12 insertions(+), 87 deletions(-)
diffs (133 lines):
diff -r b78f8df2ccda -r 07104a34d7c6 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Mon Nov 08 17:03:46 2010 -0600
+++ b/apps/las2oci.cpp	Tue Nov 09 13:46:53 2010 -0600
@@ -55,117 +55,42 @@
 void SetElements(   OWStatement* statement,
-                    OCIArray* sdo_elem_info,
+                    OCIArray* elem_info,
                     bool bUseSolidGeometry)
-    statement->AddElement(sdo_elem_info, 1);
+    statement->AddElement(elem_info, 1);
     if (bUseSolidGeometry == true) {
         //"(1,1007,3)";
-        statement->AddElement(sdo_elem_info, 1007);
+        statement->AddElement(elem_info, 1007);
     } else {
         //"(1,1003,3)";
-        statement->AddElement(sdo_elem_info, 1003);
+        statement->AddElement(elem_info, 1003);
-    statement->AddElement(sdo_elem_info, 3);
+    statement->AddElement(elem_info, 3);
 void SetOrdinates(   OWStatement* statement,
-                     OCIArray* sdo_ordinates,
+                     OCIArray* ordinates,
                      liblas::Bounds<double> const& extent)
-    statement->AddElement(sdo_ordinates, extent.min(0));
-    statement->AddElement(sdo_ordinates, extent.min(1));
+    statement->AddElement(ordinates, extent.min(0));
+    statement->AddElement(ordinates, extent.min(1));
     if (extent.dimension() > 2)
-        statement->AddElement(sdo_ordinates, extent.min(2));
+        statement->AddElement(ordinates, extent.min(2));
-    statement->AddElement(sdo_ordinates, extent.max(0));
-    statement->AddElement(sdo_ordinates, extent.max(1));
+    statement->AddElement(ordinates, extent.max(0));
+    statement->AddElement(ordinates, extent.max(1));
-        statement->AddElement(sdo_ordinates, extent.max(2));
+        statement->AddElement(ordinates, extent.max(2));
-// bool FillBlock( OWStatement* statement,
-//                 IndexResult& result,
-//                 liblas::Reader* reader,
-//                 blocks* b,
-//                 long index,
-//                 int srid,
-//                 long pc_id,
-//                 long gtype,
-//                 bool bUseSolidGeometry,
-//                 bool bUse3d,
-//                 long nDimensions
-//     // list<SpatialIndex::id_type> const& ids = result.GetIDs();
-//     IDVector const& ids = result.GetIDs();
-//     b->pc_ids[index] = pc_id;
-//     b->srids[index] = (long)srid;
-//     b->block_ids[index] = result.GetID();
-//     b->num_points[index] = (long)ids.size();
-//     std::vector<uint8_t>* blob = new std::vector<uint8_t>;
-//     result.GetData(reader, *blob);
-//     b->blobs[index] = blob;
-//     // // FIXME: null srids not supported
-//     b->srids[index] = srid;
-//     b->gtypes[index] = gtype;
-//     OCIArray* sdo_elem_info=0;
-//     statement->GetConnection()->CreateType(&sdo_elem_info, statement->GetConnection()->GetElemInfoType());
-//     SetElements(statement, sdo_elem_info, bUseSolidGeometry);
-//     b->element_arrays[index] = sdo_elem_info;
-//     OCIArray* sdo_ordinates=0;
-//     statement->GetConnection()->CreateType(&sdo_ordinates, statement->GetConnection()->GetOrdinateType());
-//     SetOrdinates(statement, sdo_ordinates, result.GetBounds());
-//     b->coordinate_arrays[index] = sdo_ordinates;
-//     return true;
-// blocks* CreateBlock(int size)
-//     blocks* b = (blocks*) malloc( sizeof(blocks));
-//     b->pc_ids = (long*) malloc( size * sizeof(long));
-//     b->block_ids = (long*) malloc ( size * sizeof(long));
-//     b->num_points = (long*) malloc ( size * sizeof(long));
-//     b->blobs = (std::vector<uint8_t>**) malloc ( size * sizeof(std::vector<uint8_t>*));
-//     b->locators =(OCILobLocator**) malloc( sizeof(OCILobLocator*) * size );
-//     b->srids = (long*) malloc ( size * sizeof(long));
-//     b->gtypes = (long*) malloc ( size * sizeof(long));
-//     b->element_arrays = (OCIArray**) malloc ( size * sizeof(OCIArray*));
-//     b->coordinate_arrays = (OCIArray**) malloc ( size * sizeof(OCIArray*));
-//     b->size = size;
-//     return b;
 long GetGType(  bool bUse3d,
More information about the Liblas-commits
