[Liblas-commits] hg: rough implementation of ColorFetchingTransform
liblas-commits at liblas.org
Thu Nov 11 09:28:25 EST 2010
changeset c84f93be7b8a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=c84f93be7b8a
summary: rough implementation of ColorFetchingTransform
diffstat:
include/liblas/lastransform.hpp | 48 ++++++++++++++++
src/lastransform.cpp | 119 ++++++++++++++++++++++++++++++++++++++++
2 files changed, 167 insertions(+), 0 deletions(-)
diffs (197 lines):
diff -r e7b05df8f778 -r c84f93be7b8a include/liblas/lastransform.hpp
--- a/include/liblas/lastransform.hpp Wed Nov 10 09:40:44 2010 -0600
+++ b/include/liblas/lastransform.hpp Wed Nov 10 11:47:20 2010 -0600
@@ -48,10 +48,15 @@
#include <liblas/export.hpp>
// boost
#include <boost/shared_ptr.hpp>
+#include <boost/array.hpp>
// std
#include <vector>
#include <string>
+#ifdef HAVE_GDAL
+#include <gdal.h>
+#endif
namespace liblas {
/// Defines public interface to LAS transform implementation.
@@ -155,6 +160,49 @@
std::string m_expression;
+class LAS_DLL ColorFetchingTransform: public TransformI
+public:
+ ColorFetchingTransform( std::string const& datasource,
+ std::vector<boost::uint32_t> bands
+ ~ColorFetchingTransform();
+ bool transform(Point& point);
+private:
+#ifdef HAVE_GDAL
+ struct GDALSourceDeleter
+ template <typename T>
+ void operator()(T* ptr)
+ ::GDALClose(ptr);
+#endif
+ liblas::HeaderPtr m_new_header;
+ typedef boost::shared_ptr<void> DataSourcePtr;
+ DataSourcePtr m_ds;
+ std::string m_datasource;
+ std::vector<boost::uint32_t> m_bands;
+ boost::array<double, 6> m_forward_transform;
+ boost::array<double, 6> m_inverse_transform;
+ ColorFetchingTransform(ColorFetchingTransform const& other);
+ ColorFetchingTransform& operator=(ColorFetchingTransform const& rhs);
+ void Initialize();
} // namespace liblas
#endif // ndef LIBLAS_LASTRANSFORM_HPP_INCLUDED
diff -r e7b05df8f778 -r c84f93be7b8a src/lastransform.cpp
--- a/src/lastransform.cpp Wed Nov 10 09:40:44 2010 -0600
+++ b/src/lastransform.cpp Wed Nov 10 11:47:20 2010 -0600
@@ -380,5 +380,124 @@
+#ifdef HAVE_GDAL
+void CPL_STDCALL ColorFetchingTransformGDALErrorHandler(CPLErr eErrClass, int err_no, const char *msg)
+ std::ostringstream oss;
+ if (eErrClass == CE_Failure || eErrClass == CE_Fatal) {
+ oss <<"GDAL Failure number=" << err_no << ": " << msg;
+ throw std::runtime_error(oss.str());
+ } else {
+ return;
+#endif
+ColorFetchingTransform::ColorFetchingTransform(
+ std::string const& datasource,
+ : m_ds(DataSourcePtr())
+ , m_datasource(datasource)
+ , m_bands(bands)
+ Initialize();
+void ColorFetchingTransform::Initialize()
+#ifdef HAVE_GDAL
+ GDALAllRegister();
+ CPLPopErrorHandler();
+ CPLPushErrorHandler(ColorFetchingTransformGDALErrorHandler);
+ m_ds = DataSourcePtr(GDALOpen( m_datasource.c_str(), GA_ReadOnly ), GDALSourceDeleter());
+ // Assume the first three bands are RGB, and not get any more if the
+ // user did not supply any bands
+ if( m_bands.size() == 0 )
+ for( boost::int32_t i = 0; i < GDALGetRasterCount( m_ds.get() ); i++ )
+ if (i > 3) break;
+ m_bands.push_back( i+1 );
+ if (GDALGetGeoTransform( m_ds.get(), &m_forward_transform[0] ) != CE_None )
+ throw std::runtime_error("unable to fetch forward geotransform for raster!");
+ m_forward_transform.assign(0.0);
+ m_inverse_transform.assign(0.0);
+ GDALInvGeoTransform( &m_forward_transform[0], &m_inverse_transform[0] );
+#endif
+bool ColorFetchingTransform::transform(Point& point)
+#ifdef HAVE_GDAL
+ boost::int32_t pixel = 0;
+ boost::int32_t line = 0;
+ double x = point.GetX();
+ double y = point.GetY();
+ pixel = (boost::int32_t) std::floor(
+ m_inverse_transform[0]
+ + m_inverse_transform[1] * x
+ + m_inverse_transform[2] * y );
+ line = (boost::int32_t) std::floor(
+ m_inverse_transform[3]
+ + m_inverse_transform[4] * x
+ + m_inverse_transform[5] * y );
+ if( pixel < 0 || line < 0
+ || pixel >= GDALGetRasterXSize( m_ds.get() )
+ || line >= GDALGetRasterYSize( m_ds.get() )
+ // The x, y is not coincident with this raster, we'll leave whatever
+ // color value might be there alone.
+ return true;
+ boost::array<double, 2> pix;
+ boost::array<liblas::Color::value_type, 3> color;
+ for( std::vector<boost::int32_t>::size_type i = 0;
+ i < m_bands.size(); i++ )
+ GDALRasterBandH hBand = GDALGetRasterBand( m_ds.get(), m_bands[i] );
+ if (hBand == NULL)
+ continue;
+ if( GDALRasterIO( hBand, GF_Read, pixel, line, 1, 1,
+ &pix[0], 1, 1, GDT_CFloat64, 0, 0) == CE_None )
+ color[i] = static_cast<liblas::Color::value_type>(pix[0]);
+ point.SetColor(Color(color));
+ return true;
+#else
+ boost::ignore_unused_variable_warning(point);
+ return true;
+#endif
+ColorFetchingTransform::~ColorFetchingTransform()
+#ifdef HAVE_GDAL
+#endif
More information about the Liblas-commits
