[Liblas-commits] hg: Modified descriptions of iterator operators.
liblas-commits at liblas.org
Tue Nov 16 19:07:44 EST 2010
changeset c1c8a1f8c061 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=c1c8a1f8c061
summary: Modified descriptions of iterator operators.
diffstat:
include/liblas/lasindex.hpp | 6 +++---
1 files changed, 3 insertions(+), 3 deletions(-)
diffs (24 lines):
diff -r 54c162c138f2 -r c1c8a1f8c061 include/liblas/lasindex.hpp
--- a/include/liblas/lasindex.hpp Tue Nov 16 16:53:10 2010 -0700
+++ b/include/liblas/lasindex.hpp Tue Nov 16 17:06:57 2010 -0700
@@ -492,9 +492,9 @@
boost::uint8_t MinMinorVersion(void) {return(2);};
public:
- /// n=0 or n=1 gives next sequence with no gap, n>1 skips n-1 filter-compliant points, n<0 skips backwards
+ /// n=0 or n=1 gives next sequence with no gap, n>1 skips n-1 filter-compliant points, n<0 jumps backwards n compliant points
const std::vector<boost::uint32_t>& advance(boost::int32_t n);
- /// returns filter-compliant points beginning with the nth compliant point, 0 and 1 return first set of compliant points
+ /// returns filter-compliant points as though the first point returned is element n in a zero-based array
const std::vector<boost::uint32_t>& operator()(boost::int32_t n);
/// returns next set of filter-compliant points with no skipped points
inline const std::vector<boost::uint32_t>& operator++() {return (advance(1));}
@@ -512,7 +512,7 @@
inline const std::vector<boost::uint32_t>& operator-=(boost::int32_t n) {return (advance(-n));}
/// returns set of filter-compliant points beginning n points backwards from the end of the last set, for n<0 acts like +()
inline const std::vector<boost::uint32_t>& operator-(boost::int32_t n) {return (advance(-n));}
inline const std::vector<boost::uint32_t>& operator[](boost::int32_t n) {return ((*this)(n));}
/// tests viability of index for filtering with iterator
bool ValidateIndexVersion(boost::uint8_t VersionMajor, boost::uint8_t VersionMinor) {return (VersionMajor > MinMajorVersion() || (VersionMajor == MinMajorVersion() && VersionMinor >= MinMinorVersion()));};
More information about the Liblas-commits
