[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Thu Nov 18 12:35:40 EST 2010
changeset 137208488bb0 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=137208488bb0
summary: updates. Demonstrate --color-source and friends
changeset bede54b045bc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=bede54b045bc
summary: regularize command-line arguments to be dash (-) separated instead of underscore (_) separated -- a few remain, however to keep the same spelling as GDAL
diffstat:
apps/laskernel.cpp | 18 +++++-----
doc/utilities/las2las.txt | 84 ++++++++++++++++++++++++++++++++++++++--------
2 files changed, 77 insertions(+), 25 deletions(-)
diffs (188 lines):
diff -r 40ce9d65ecce -r bede54b045bc apps/laskernel.cpp
--- a/apps/laskernel.cpp Thu Nov 18 11:16:00 2010 -0600
+++ b/apps/laskernel.cpp Thu Nov 18 11:35:32 2010 -0600
@@ -262,8 +262,8 @@
("maxy", po::value< double >(), "Extent must be less than or equal to maxy to be kept. \n --maxy 5678.0")
("maxz", po::value< double >(), "Extent must be less than or equal to maxz to be kept. If maxx and maxy are set but not maxz *and minz, all z values are kept. \n --maxz 10.0")
("thin,t", po::value<boost::uint32_t>()->default_value(0), "Simple decimation-style thinning.\nThin the file by removing every t'th point from the file.")
- ("last_return_only", po::value<bool>()->zero_tokens(), "Keep last returns (cannot be used with --first_return_only)")
- ("first_return_only", po::value<bool>()->zero_tokens(), "Keep first returns (cannot be used with --last_return_only")
+ ("last-return-only", po::value<bool>()->zero_tokens(), "Keep last returns (cannot be used with --first-return-only)")
+ ("first-return-only", po::value<bool>()->zero_tokens(), "Keep first returns (cannot be used with --last-return-only")
("keep-returns", po::value< std::vector<boost::uint16_t> >()->multitoken(), "A list of return numbers to keep in the output file: \n--keep-returns 1 2 3")
("drop-returns", po::value< std::vector<boost::uint16_t> >()->multitoken(), "Return numbers to drop.\nFor example, --drop-returns 2 3 4 5")
("valid_only", po::value<bool>()->zero_tokens(), "Keep only valid points")
@@ -314,8 +314,8 @@
("add-schema", po::value<bool>()->zero_tokens(), "Add the liblas.org schema VLR record to the file.")
("delete-vlr", po::value<std::vector<std::string> >()->multitoken(), "Removes VLRs with the given name and id combination. --delete-vlr LASF_Projection 34737")
("add-vlr", po::value<std::vector<std::string> >()->multitoken(), "Add VLRs with the given name and id combination. --add-vlr hobu 1234 \"Description of the VLR\" \"filename.ext\"")
- ("system-identifier", po::value<std::string>(), "Set the SystemID for the file. --system_identifier \"MODIFICATION\"")
- ("generating-software", po::value<std::string>(), "Set the SoftwareID for the file. --generating_software \"liblas.org\"")
+ ("system-identifier", po::value<std::string>(), "Set the SystemID for the file. --system-identifier \"MODIFICATION\"")
+ ("generating-software", po::value<std::string>(), "Set the SoftwareID for the file. --generating-software \"liblas.org\"")
return transform_options;
@@ -737,13 +737,13 @@
- if (vm.count("first_return_only") && vm.count("last_return_only")) {
- throw std::runtime_error( "--first_return_only and --last_return_only cannot "
+ if (vm.count("first-return-only") && vm.count("last-return-only")) {
+ throw std::runtime_error( "--first-return-only and --last-return-only cannot "
"be used simultaneously. Use --keep-returns 1 in "
- "combination with --last_return_only");
+ "combination with --last-return-only");
- if (vm.count("last_return_only")) {
+ if (vm.count("last-return-only")) {
if (verbose)
std::cout << "Keeping last returns only." << std::endl;
std::vector<boost::uint16_t> returns;
@@ -751,7 +751,7 @@
filters.push_back(last_filter);
- if (vm.count("first_return_only")){
+ if (vm.count("first-return-only")){
if (verbose)
std::cout << "Keeping first returns only." << std::endl;
diff -r 40ce9d65ecce -r bede54b045bc doc/utilities/las2las.txt
--- a/doc/utilities/las2las.txt Thu Nov 18 11:16:00 2010 -0600
+++ b/doc/utilities/las2las.txt Thu Nov 18 11:35:32 2010 -0600
@@ -128,7 +128,7 @@
- $ las2las --input in.las --output out.las --last_return_only
+ $ las2las --input in.las --output out.las --last-return-only
extracts all last return points from in.las and stores them to out.las.
@@ -244,6 +244,40 @@
removes all VLRs from in.las when writing the new output.las file.
+Adding color from an image
+It is possible to use las2las to set RGB color information from an
+image and set it on the points. This requires a rewrite of the file and
+in some cases will require changing both the format and point-format of the
+file.
+The following example takes the ``input.las`` file, sets its format to ``1.2``,
+and sets the point format to ``3`` so it can store color information. It
+also re-orders the color bands to have the 3rd band in the image be red, 1st
+band be green, and second band be blue. Additionally, the color values are
+then multiplied by the --color-source-scale factor or 257 to rescale the
+8bit image data to 16bit color data.
+ las2las -i input.las \
+ --color-source image.img \
+ -o output.las \
+ --format 1.2 \
+ --point-format 3 \
+ --color-source-scale 257 \
+ --color-source-bands 3 1 2
+.. note::
+ If the coordinate system of ``image.img`` is not the same as the input
+ coordinate system of the LAS file, you should use GDAL VRTs to cause the
+ image to be warped and reprojected as part of the read process. See
+ http://www.gdal.org/gdal_vrttut.html for more detail.
+.. warning::
+ `GDAL`_ support must be enabled for this to work.
Help listing
@@ -280,10 +314,14 @@
*cannot* be negative, and should always be a
negative power of 10
--scale 0.1 0.1 0.00001
- -f [ --format ] arg Set the LAS format of the new file (only 1.0-1.2
+ -f [ --file-format ] arg Set the LAS format of the new file (only 1.0-1.2
supported at this time):
- --format 1.2
+ --file-format 1.2
-f 1.1
+ --point-format arg Set the LAS point format of the new file (0, 1, 2,
+ 3):
+ --point-format 3
--pad-header arg Add extra bytes to the existing header
--min-offset Set the offset of the header to the minimums of all
values in the file. Note that this requires
@@ -297,19 +335,31 @@
--add-vlr arg Add VLRs with the given name and id combination.
--add-vlr hobu 1234 "Description of the VLR"
"filename.ext"
- --system-identifier arg Set the SystemID for the file. --system_identifier
+ --system-identifier arg Set the SystemID for the file. --system-identifier
"MODIFICATION"
--generating-software arg Set the SoftwareID for the file.
- --generating_software "liblas.org"
- --point-translate arg An expression to translate the X, Y, Z values of
- the point. For example, converting Z units that are
- in meters to feet: --point-translate "x*1.0 y*1.0
- z*3.2808399"
+ --generating-software "liblas.org"
Transformation options:
- --t_srs arg Coordinate system to reproject output LAS file to. Use
- --a_srs or verify that your input LAS file has a
- coordinate system according to lasinfo
+ --t_srs arg Coordinate system to reproject output LAS file to.
+ Use --a_srs or verify that your input LAS file has a
+ coordinate system according to lasinfo
+ --point-translate arg An expression to translate the X, Y, Z values of the
+ point. For example, converting Z units that are in
+ meters to feet: --point-translate "x*1.0 y*1.0
+ z*3.2808399"
+ --color-source arg A string to a GDAL-openable raster data source. Use
+ GDAL VRTs if you want to adjust the data source or
+ set its coordinate system, etc.
+ --color-source "afile.tif"
+ --color-source-bands arg A list of three bands from the --color-source to
+ assign to the R, G, B values for the point
+ --color-source-bands 1 2 3
+ --color-source-scale arg A number used by --color-source to scale the input
+ R, G, B values for the point. For example, to
+ scale the 8 bit color data from an input raster to
+ 16 bit, the 8 bit data should be multiplied by 257.
+ --color-source-scale 256
Filtering options:
-e [ --extent ] arg Extent window that points must fall within to keep.
@@ -340,10 +390,10 @@
-t [ --thin ] arg (=0) Simple decimation-style thinning.
file.
- --last_return_only Keep last returns (cannot be used with
- --first_return_only)
- --first_return_only Keep first returns (cannot be used with
+ --last-return-only Keep last returns (cannot be used with
+ --first-return-only)
+ --first-return-only Keep first returns (cannot be used with
--keep-returns arg A list of return numbers to keep in the output file:
--drop-returns arg Return numbers to drop.
@@ -398,6 +448,8 @@
http://liblas.org/utilities/las2las2.html
.. _`GDAL`: http://www.gdal.org
.. _`LAStools`: http://www.cs.unc.edu/~isenburg/lastools/
\ No newline at end of file
More information about the Liblas-commits
