[Liblas-commits] hg: note about using gdal-dev for OSGeo4W
liblas-commits at liblas.org
Fri Nov 19 15:08:21 EST 2010
changeset eabee705e0c1 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=eabee705e0c1
summary: note about using gdal-dev for OSGeo4W
diffstat:
doc/compilation.txt | 4 ++++
1 files changed, 4 insertions(+), 0 deletions(-)
diffs (14 lines):
diff -r 95a18f4a486a -r eabee705e0c1 doc/compilation.txt
--- a/doc/compilation.txt Fri Nov 19 13:47:32 2010 -0600
+++ b/doc/compilation.txt Fri Nov 19 14:08:14 2010 -0600
@@ -106,6 +106,10 @@
* GDAL 1.7+ is required.
+.. note::
+ If you are using `OSGeo4W`_ as your provider of GDAL, you must use the
+ ``gdal-dev`` package, which is GDAL 1.8 as of 11/19/2010.
`libgeotiff`_
More information about the Liblas-commits
