[Liblas-commits] hg: add rewritten las2txt. Keep las2txt-old around
for those wh...
liblas-commits at liblas.org
Wed Nov 24 15:15:31 EST 2010
changeset 249e428e53cc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=249e428e53cc
summary: add rewritten las2txt. Keep las2txt-old around for those who still may be using it
diffstat:
apps/CMakeLists.txt | 19 +-
apps/las2txt.cpp | 614 ++++++++++++++++++++++++++++++++++++++++++++++++++++
2 files changed, 628 insertions(+), 5 deletions(-)
diffs (truncated from 676 to 300 lines):
diff -r 1c7248d4623e -r 249e428e53cc apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Tue Nov 23 14:25:43 2010 -0600
+++ b/apps/CMakeLists.txt Wed Nov 24 14:15:17 2010 -0600
@@ -19,6 +19,7 @@
set(LASMERGE lasmerge)
set(LAS2LAS las2las)
set(LAS2LAS_OLD las2las-old)
+set(LAS2TXT_OLD las2txt-old)
set(LAS2TXT las2txt)
set(TXT2LAS txt2las)
set(TS2LAS ts2las)
@@ -47,8 +48,8 @@
endif()
set(LIBLAS_UTILITIES
- ${LASINFO_OLD} ${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT} ${TXT2LAS}
- ${LAS2OGR} ${LAS2OCI} ${LAS2LAS} ${LAS2LAS_OLD} ${LASBLOCK} ${TS2LAS})
+ ${LASINFO_OLD} ${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT_OLD} ${TXT2LAS}
+ ${LAS2OGR} ${LAS2OCI} ${LAS2LAS} ${LAS2LAS_OLD} ${LASBLOCK} ${TS2LAS} ${LAS2TXT} )
# TODO: Experimental and requires testing --mloskot
# Generate user-specific settings for Visual Studio project
@@ -82,6 +83,8 @@
link_directories(${Boost_LIBRARY_DIRS})
+# add_executable(lasschematest lasschematest.cpp laskernel.cpp)
+# target_link_libraries(lasschematest ${APPS_CPP_DEPENDENCIES} ${LIBXML2_LIBRARIES})
# Build lasinfo
if(LASINFO_OLD)
@@ -97,6 +100,7 @@
target_link_libraries(${LAS2LAS_OLD} ${LIBLAS_C_LIB_NAME})
endif()
if(LAS2LAS)
add_executable(${LAS2LAS} las2las.cpp laskernel.cpp)
target_link_libraries(${LAS2LAS} ${APPS_CPP_DEPENDENCIES} )
@@ -108,10 +112,15 @@
endif()
# Build las2txt
+if(LAS2TXT_OLD)
+ set(LAS2TXT_OLD_SRC lascommon.c ${LAS2TXT}.c)
+ add_executable(${LAS2TXT_OLD} ${LAS2TXT_OLD_SRC})
+ target_link_libraries(${LAS2TXT_OLD} ${LIBLAS_C_LIB_NAME})
+endif()
if(LAS2TXT)
- set(LAS2TXT_SRC lascommon.c ${LAS2TXT}.c)
- add_executable(${LAS2TXT} ${LAS2TXT_SRC})
- target_link_libraries(${LAS2TXT} ${LIBLAS_C_LIB_NAME})
+ add_executable( ${LAS2TXT} las2txt.cpp laskernel.cpp )
+ target_link_libraries(${LAS2TXT} ${APPS_CPP_DEPENDENCIES} )
endif()
# Build txt2las
diff -r 1c7248d4623e -r 249e428e53cc apps/las2txt.cpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/apps/las2txt.cpp Wed Nov 24 14:15:17 2010 -0600
@@ -0,0 +1,614 @@
+ * Project: libLAS -- C/C++ read/write library for LAS LIDAR data
+ * Purpose: LAS translation to ASCII text with optional configuration
+ * Author: Martin Isenburg isenburg at cs.unc.edu
+ * Author: Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler, hobu.inc at gmail.com
+ * See LICENSE.txt in this source distribution for more information.
+#include <liblas/liblas.hpp>
+#include "laskernel.hpp"
+#include <liblas/utility.hpp>
+#include <boost/cstdint.hpp>
+#include <boost/foreach.hpp>
+#include <boost/array.hpp>
+#include <boost/lexical_cast.hpp>
+#include <string>
+using namespace liblas;
+using namespace std;
+#ifdef _WIN32
+#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
+#else
+#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
+#endif
+std::string GetLabels(std::string const& parse_string,
+ std::string const& delimiter)
+ std::ostringstream output;
+ boost::uint32_t i = 0;
+ for (;;)
+ switch (parse_string[i])
+ /* // the x coordinate */
+ case 'x':
+ output << "\"X\"";
+ break;
+ /* // the y coordinate */
+ case 'y':
+ output << "\"Y\"";
+ break;
+ /* // the z coordinate */
+ case 'z':
+ output << "\"Z\"";
+ break;
+ /* // the raw x coordinate */
+ case 'X':
+ output << "\"Raw X\"";
+ break;
+ /* // the raw y coordinate */
+ case 'Y':
+ output << "\"Raw Y\"";
+ break;
+ /* // the raw z coordinate */
+ case 'Z':
+ output << "\"Raw Z\"";
+ break;
+ /* // the gps-time */
+ case 't':
+ output << "\"Time\"";
+ break;
+ /* // the intensity */
+ case 'i':
+ output << "\"Intensity\"";
+ break;
+ /* the scan angle */
+ case 'a':
+ output << "\"Scan Angle\"";
+ break;
+ /* the number of the return */
+ case 'r':
+ output << "\"Return Number\"";
+ break;
+ /* the classification */
+ case 'c':
+ output << "\"Classification\"";
+ break;
+ /* the classification name */
+ case 'C':
+ output << "\"Classification Name\"";
+ break;
+ /* the user data */
+ case 'u':
+ output << "\"User Data\"";
+ break;
+ /* the number of returns of given pulse */
+ case 'n':
+ output << "\"Number of Returns\"";
+ break;
+ /* the red channel color */
+ case 'R':
+ output << "\"Red\"";
+ break;
+ /* the green channel color */
+ case 'G':
+ output << "\"Green\"";
+ break;
+ /* the blue channel color */
+ case 'B':
+ output << "\"Blue\"";
+ break;
+ case 'M':
+ output << "\"ID\"";
+ break;
+ case 'p':
+ output << "\"Point Source ID\"";
+ break;
+ /* the edge of flight line flag */
+ case 'e':
+ output << "\"Flight Line Edge\"";
+ break;
+ /* the direction of scan flag */
+ case 'd':
+ output << "\"Scan Direction\"";
+ break;
+ i++;
+ if (parse_string[i])
+ output << delimiter;
+ else
+ output << std::endl;
+ break;
+ return output.str();
+std::string GetPointString( std::string const& parse_string,
+ std::string const& delimiter,
+ liblas::Point const& p,
+ boost::array<boost::uint32_t, 4> precisions,
+ boost::uint32_t index)
+ output.setf(std::ios_base::fixed, std::ios_base::floatfield);
+ liblas::Color const& c = p.GetColor();
+ for (;;)
+ case 'x':
+ output.precision(precisions[0]); //x precision
+ output << p.GetX();
+ // lidardouble2string(printstring, LASPoint_GetX(p)); fprintf(file_out, "%s", printstring);
+ break;
+ case 'y':
+ output.precision(precisions[1]); //y precision
+ output << p.GetY();
+ break;
+ case 'z':
+ output.precision(precisions[2]); //z precision
+ output << p.GetZ();
+ break;
+ case 'X':
+ output << p.GetRawX();
+ break;
+ case 'Y':
+ output << p.GetRawY();
+ break;
+ case 'Z':
+ output << p.GetRawZ();
+ break;
+ case 't':
+ output.precision(precisions[3]); //t precision
+ output << p.GetTime();
+ break;
+ case 'i':
+ output << p.GetIntensity();
+ break;
+ case 'a':
+ output << p.GetScanAngleRank();
+ break;
+ case 'r':
+ output << p.GetReturnNumber();
+ break;
+ case 'c':
+ output << p.GetClassification().GetClass();
+ break;
+ case 'C':
+ output << p.GetClassification().GetClassName();
+ break;
+ case 'u':
+ output << p.GetUserData();
+ break;
+ case 'n':
+ output << p.GetNumberOfReturns();
+ break;
+ case 'R':
+ output << c.GetRed();
+ break;
+ case 'G':
+ output << c.GetGreen();
+ break;
More information about the Liblas-commits
